楼主: 奈何col
[使用文档] [Arduino物联网开发实战2]数据反馈
    2019-1-25 10:53
    发表于 2019-1-24 16:01 | 显示全部楼层
    嗯,是的,2个库都下了,还是不行!
    2019-1-25 10:53
    发表于 2019-1-24 16:10 | 显示全部楼层
    Arduino:1.8.5 (Windows 7), 开发板:"WeMos D1 R1, 80 MHz, Flash, Enabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
    找到无效库在 C:\Users\rain\Documents\Arduino\libraries\LiquidCrystal_I2C: C:\Users\rain\Documents\Arduino\libraries\LiquidCrystal_I2C
    Archiving built core (caching) in: C:\Users\rain\AppData\Local\Temp\arduino_cache_950569\core\core_esp8266_esp8266_d1_xtal_80,vt_flash,exception_enabled,eesz_4M,ip_lm2f,dbg_Disabled,lvl_None____,wipe_none,baud_921600_ab0977f063207184ee2c2e7514633234.a
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT:HT(unsigned char, unsigned char, unsigned char)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:12: multiple definition of `DHT:HT(unsigned char, unsigned char, unsigned char)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:12: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::begin()':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:24: multiple definition of `DHT::begin()'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:24: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::convertCtoF(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:64: multiple definition of `DHT::convertCtoF(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:64: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::convertFtoC(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:69: multiple definition of `DHT::convertFtoC(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:69: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::computeHeatIndex(float, float, bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:92: multiple definition of `DHT::computeHeatIndex(float, float, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:92: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::expectPulse(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:237: multiple definition of `DHT::expectPulse(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:237: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::read(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:123: multiple definition of `DHT::read(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:123: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::readTemperature(bool, bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:35: multiple definition of `DHT::readTemperature(bool, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:35: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT_sensor_library\DHT.cpp.o: in function `DHT::readHumidity(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library/DHT.cpp:72: multiple definition of `DHT::readHumidity(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:C:\Users\rain\Documents\Arduino\libraries\Blinker\src\modules\dht/DHT.cpp:72: first defined here
    collect2.exe: error: ld returned 1 exit status
    "Ticker.h" 对应多个库
    已使用: C:\Users\rain\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\Ticker
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\Ticker
    "EEPROM.h" 对应多个库
    已使用: C:\Users\rain\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\EEPROM
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\EEPROM
    "DHT.h" 对应多个库
    已使用: C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library
    未使用:C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\DHT-sensor-library-master
    "Hash.h" 对应多个库
    已使用: C:\Users\rain\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\Hash
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\Hash
    "Blinker.h" 对应多个库
    已使用: C:\Users\rain\Documents\Arduino\libraries\Blinker
    未使用:C:\Users\rain\Documents\Arduino\libraries\blinker-library-master
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\blinker_library_master
    未使用:E:\arduino\ESPduino\arduino-1.8.5\arduino-1.8.5\libraries\blinker-library-master
    exit status 1
    为开发板 WeMos D1 R1 编译时出错。
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    你的blinker库不是最新的  详情 回复 发表于 2019-1-24 17:26
     楼主| 发表于 2019-1-24 17:26 | 显示全部楼层
    宇之枫海云 发表于 2019-1-24 16:10
    Arduino:1.8.5 (Windows 7), 开发板:"WeMos D1 R1, 80 MHz, Flash, Enabled, 4M (no SPIFFS), v2 Lower Me ...
    你的blinker库不是最新的
    2019-1-25 10:53
    发表于 2019-1-24 18:16 | 显示全部楼层
    fatal error: Adafruit_Sensor.h: No such file or directory
      #include <Adafruit_Sensor.h>
    compilation terminated.
    exit status 1
    这个应该是最致命的错误,怎么破?老铁!!!
    2019-1-25 10:53
    发表于 2019-1-24 18:31 | 显示全部楼层
    现在是最新的了,还是不行!
    不清楚你现在用的是不是最新,但之前的肯定不是最新,如果还有问题,请帖出报错  详情 回复 发表于 2019-1-24 23:17
     楼主| 发表于 2019-1-24 23:17 | 显示全部楼层
    宇之枫海云 发表于 2019-1-24 18:31
    现在是最新的了,还是不行!
    2019-1-25 10:53
    发表于 2019-1-25 09:49 | 显示全部楼层
    In file included from C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp:22:0:
    C:\Users\rain\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
    exit status 1
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    还是一样啊!郁闷了
    2019-1-25 10:53
    发表于 2019-1-25 10:05 | 显示全部楼层
    昨天没更新库之前,自带DHT的测试还能通过,现在自带的也通过不了了!
    fatal error: Adafruit_Sensor.h: No such file or directory 说明你没有用帖子里的库,用帖子里附件的库  详情 回复 发表于 2019-1-25 11:17
     楼主| 发表于 2019-1-25 11:17 | 显示全部楼层
    2019-1-25 10:53
    发表于 2019-1-25 11:50 | 显示全部楼层
    嗯,是的帖子里的可以了,但是现在报新的故障了!!!
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT:HT(unsigned char, unsigned char, unsigned char)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:13: multiple definition of `DHT:HT(unsigned char, unsigned char, unsigned char)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:12: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::begin()':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:25: multiple definition of `DHT::begin()'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:24: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::convertCtoF(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:68: multiple definition of `DHT::convertCtoF(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:64: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::convertFtoC(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:73: multiple definition of `DHT::convertFtoC(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:69: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::computeHeatIndex(float, float, bool)':
    "Blinker.h" 对应多个库
    已使用: E:\arduino-1.8.5\libraries\Blinker
    "DHT.h" 对应多个库
    已使用: C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:103: multiple definition of `DHT::computeHeatIndex(float, float, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:92: first defined here
    未使用:E:\arduino-1.8.5\libraries\DHT_sensor_library
    "Hash.h" 对应多个库
    未使用:E:\arduino-1.8.5\libraries\Hash
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::expectPulse(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:255: multiple definition of `DHT::expectPulse(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:237: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::read(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:134: multiple definition of `DHT::read(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:123: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::readTemperature(bool, bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:36: multiple definition of `DHT::readTemperature(bool, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:35: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::readHumidity(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:76: multiple definition of `DHT::readHumidity(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:72: first defined here
    exit status 1
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    1.提示:libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:12: first defined here 因为你IDE libraries里有老版本的blinker库 2.fatal error: Adafruit_Sens  详情 回复 发表于 2019-1-25 12:21
    求ESP8266+0.96oled的天气代码
    新人求助
    新人求助
    仿真出错!显示原因是这个,但是找不到该出错文件
    用Arduino制作支持ROS机器人操作系统的7轴机械臂
    用Arduino制作支持ROS机器
    参赛项目:[/backcolor] 用Arduino制作支持ROS机器人操作系统的7轴机械臂[/backcolor
    为拍月亮而生的便携望远镜系统。
    为拍月亮而生的便携望远镜
    参赛项目: 便携望远镜系统 参赛组员: 1人 布丁:嵌入式软件、上位机软件、电路、结
    光敏电阻检测环境光实验
    光敏电阻检测环境光实验
