查看: 198|回复: 7
8266编译不过如果可以解决发红包
发表于 2019-1-7 19:31 | 显示全部楼层 |阅读模式
C:\Users\xuansir\Documents\Arduino\sketch_jan07f\sketch_jan07f.ino: In function 'void button1_callback(const String&)':
sketch_jan07f:38:18: error: 'D3' was not declared in this scope
     digitalWrite(D3, HIGH);
sketch_jan07f:43:18: error: 'D3' was not declared in this scope
     digitalWrite(D3, LOW);
C:\Users\xuansir\Documents\Arduino\sketch_jan07f\sketch_jan07f.ino: In function 'void setup()':
sketch_jan07f:50:13: error: 'D3' was not declared in this scope
     pinMode(D3, OUTPUT);
sketch_jan07f:54:29: error: no matching function for call to 'BlinkerESPMQTT::begin(char [11], char [11])'
     Blinker.begin(ssid, pswd);
C:\Users\xuansir\Documents\Arduino\sketch_jan07f\sketch_jan07f.ino:54:29: note: candidates are:
In file included from C:\Users\xuansir\Documents\Arduino\libraries\Blinker\src/Blinker.h:149:0,
                 from C:\Users\xuansir\Documents\Arduino\sketch_jan07f\sketch_jan07f.ino:23:
C:\Users\xuansir\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:34:14: note: void BlinkerESPMQTT::begin(const char*)
         void begin(const char* _auth)
C:\Users\xuansir\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:34:14: note:   candidate expects 1 argument, 2 provided
C:\Users\xuansir\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:63:14: note: void BlinkerESPMQTT::begin(const char*, const char*, const char*)
         void begin( const char* _auth,
C:\Users\xuansir\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:63:14: note:   candidate expects 3 arguments, 2 provided
C:\Users\xuansir\Documents\Arduino\sketch_jan07f\sketch_jan07f.ino: In function 'void loop()':
sketch_jan07f:63:56: error: 'class BlinkerESPMQTT' has no member named 'readString'
         BLINKER_LOG2("Blinker.readString(): ", Blinker.readString());
sketch_jan07f:63:68: error: 'BLINKER_LOG2' was not declared in this scope
exit status 1
exit status 1
    2018-9-19 20:22
  • 签到天数: 47 天
    发表于 2019-1-7 19:44 | 显示全部楼层
    你这个板子没有D3,或者你选的开发板没有D3,看看啥板子,上面印的啥,直接写上面印的数字即可
    如果你觉得以上内容帮到了你,你可以打赏支持作者
     楼主| 发表于 2019-1-7 19:53 | 显示全部楼层
    开发板可以看图
     楼主| 发表于 2019-1-7 19:54 | 显示全部楼层
    coloz 发表于 2019-1-7 19:44
    你这个板子没有D3,或者你选的开发板没有D3,看看啥板子,上面印的啥,直接写上面印的数字即可 ...
    这开发版有D3口
    发表于 2019-1-7 20:20 | 显示全部楼层
    heysir 发表于 2019-1-7 19:54
    这开发版有D3口
    写得有不代表你ide选的板子定义的有
    2019-1-8 09:03
  • 签到天数: 21 天
    发表于 2019-1-8 09:02 | 显示全部楼层
    还没有解决吗?    怀疑你的编译板子选错了;参考我的:
    发表于 2019-1-8 13:27 | 显示全部楼层
    肯定是没选板子类型的,选Generic ESP8266 Module 再编译就可以了。
    2019-1-16 09:30
  • 签到天数: 8 天
    发表于 2019-1-16 09:36 | 显示全部楼层
    D3,你应该填写0
    KittenBot杯第六届开源硬件开发大赛启动啦
    KittenBot杯第六届开源硬
    游戏机和开发板脑洞一下;这个本来就是开源的。
    游戏机和开发板脑洞一下;
    新人求助,关于舵机和限位开关。
    新人求助,关于舵机和限位
    基于MWC开源飞控DIY关键总结分享:
    基于MWC开源飞控DIY关键总
    有关函数返回值的问题
    有关函数返回值的问题
