新手小白一枚,最近在做课程设计。看了社区的一个帖子后自己根据原文作者思路写的,按键函数被我自己改了一些算法,简单一点也方便后续加功能。原文作者用的12864是四行中文显示,1602是两行字符显示。再次感谢原文作者的帖子,这是链接(Arduino 用LCD12864做的多级菜单显示功能 https://www.arduino.cn/forum.php ... 6308&fromuid=170791(出处: Arduino中文社区))
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
int c, var;
int KEY = 9;
int KEY2 = 10;
int KEY3 = 11;
int KEY_NUM1 = 0;
int KEY_NUM2 = 0;
int KEY_NUM3 = 0;
lcd.setCursor(0, 0);
lcd.print("20163907");
lcd.setCursor(0, 1);
lcd.print("Zed'program");
lcd.begin(16, 2);
pinMode(KEY, INPUT);
pinMode(KEY2, INPUT);
pinMode(KEY3, INPUT);
var = 2;//初始化界面
lcd.clear();
ScanKey(); //按键函数
ScanKey2();
ScanKey3();
switch (var)
case 0:
lcd.setCursor(0, c);
lcd.print(">");
lcd.setCursor(1, 0);
lcd.print("gongneng1-1 ");
lcd.setCursor(1, 1);
lcd.print("gongneng1-2 ");
case 1:
lcd.print(">");
lcd.print("gongneng2-1 ");
lcd.print("gongneng2-2 ");
case 2:
lcd.print(">");
lcd.print("gongneng1");
lcd.print("gongneng2");
case 3:
lcd.print(">");
lcd.print("gongneng3-1");
lcd.print("gongneng3-2");
case 4:
lcd.print(">");
lcd.print("gongneng3");
void ScanKey() {//菜单选择
KEY_NUM1 = 0; //清空变量
if (digitalRead(KEY) == HIGH) //有按键按下
delay(20); //延时去抖动
KEY_NUM1 = 1; //变量设置为1
while (digitalRead(KEY) == HIGH); //等待按键松手
if (KEY_NUM1 == 1) //是否按键按下
c = c + 1; lcd.clear();
if (c > 1) {
lcd.clear();
switch (var) {
case 0:
c = 0; break;
case 1:
c = 0; break;
case 2:
c = 0; var = 4; break;
case 3:
c = 0; break;
case 4:
c = 0; var = 2; break;
void ScanKey2() {//确定按键
KEY_NUM2 = 0; //清空变量
if (digitalRead(KEY2) == HIGH) //有按键按下
delay(20); //延时去抖动
KEY_NUM2 = 1; //变量设置为1
while (digitalRead(KEY2) == HIGH); //等待按键松手
if (KEY_NUM2 == 1) //是否按键按下 算法更改后子菜单确认就不会返回主菜单 也方便后续子菜单功能添加。
lcd.clear();
switch (var) {
case 0:
case 1:
case 2:
var = c; c = 0; break;
case 3:
c = 0; break;
case 4:
c = 0; var = 3; break;
void ScanKey3() {//返回按键定义
KEY_NUM3 = 0; //清空变量
if (digitalRead(KEY3) == HIGH) //有按键按下
delay(20); //延时去抖动
KEY_NUM3 = 1; //变量设置为1
while (digitalRead(KEY3) == HIGH); //等待按键松手
if (KEY_NUM3 == 1) //是否按键按下
var = 2; c = 0; lcd.clear();
一级菜单
二级菜单
