查看: 516|回复: 5
[未解决] arduino 求大神帮忙看下这段程序有什么要修改的
    2018-11-10 13:34
    发表于 2019-1-11 14:04 | 显示全部楼层 |阅读模式
      pinMode(driver1, OUTPUT);
      pinMode(startbutton, INPUT);
      time = 0;
      condition = 0;
      if (condition == 0 && digitalRead(startbutton) == HIGH){
        digitalWrite(driver1, HIGH);
        condition = 1;
      if (condition == 1) {
        while (timer < 50000){
          if (digitalRead(sensor1) == HIGH){
            digitalWrite(driver1, LOW);
            timer = 50000;
            condition = 0;
          delayMicroseconds(1);
          tmer = timer + 1;
      if (condition == 1){
        condition = 0;
        timer = 0;
    2019-5-31 10:51
  • 签到天数: 305 天
    发表于 2019-1-11 21:01 | 显示全部楼层
    你想问什么
    2018-11-10 13:34
     楼主| 发表于 2019-1-13 11:55 | 显示全部楼层
    michael_llh 发表于 2019-1-11 21:01
    你想问什么
    就是void setup()前面要加些什么程序才算正确。这段程序验证的时候显示有好多东西都不在范围内。
    这是错误信息:
    Arduino:1.8.8 (Windows 7), 开发板:"Arduino/Genuino Uno"
    C:\Users\Administrator\Desktop\sketch_jan06a\sketch_jan06a.ino: In function 'void setup()':
    sketch_jan06a:2:11: error: 'driver1' was not declared in this scope
    sketch_jan06a:3:11: error: 'startbutton' was not declared in this scope
    sketch_jan06a:4:3: error: 'time' was not declared in this scope
       time = 0;
    sketch_jan06a:5:3: error: 'condition' was not declared in this scope
       condition = 0;
    C:\Users\Administrator\Desktop\sketch_jan06a\sketch_jan06a.ino: In function 'void loop()':
    sketch_jan06a:8:7: error: 'condition' was not declared in this scope
    sketch_jan06a:8:37: error: 'startbutton' was not declared in this scope
    sketch_jan06a:9:18: error: 'driver1' was not declared in this scope
    sketch_jan06a:13:7: error: 'condition' was not declared in this scope
    sketch_jan06a:14:12: error: 'timer' was not declared in this scope
    sketch_jan06a:15:23: error: 'sensor1' was not declared in this scope
    sketch_jan06a:16:22: error: 'driver1' was not declared in this scope
    sketch_jan06a:21:7: error: 'tmer' was not declared in this scope
           tmer = timer + 1;
    sketch_jan06a:25:7: error: 'condition' was not declared in this scope
    sketch_jan06a:28:5: error: 'timer' was not declared in this scope
         timer = 0;
    exit status 1
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    2019-5-31 10:51
  • 签到天数: 305 天
    发表于 2019-1-13 17:50 | 显示全部楼层
    这是 ...
    这些东西你没有定义所以提示错误,比如说第一个错误,程序不知道这个driver1是什么,看你的代码没有定义这个变量是什么
    2018-11-10 13:34
     楼主| 发表于 2019-1-18 13:16 | 显示全部楼层
    michael_llh 发表于 2019-1-13 17:50
    这些东西你没有定义所以提示错误,比如说第一个错误,程序不知道这个driver1是什么,看你的代码没有定义 ...
    那要咋定义 int  x=y吗?如果是的话要怎么写。谢谢
    2019-5-31 10:51
  • 签到天数: 305 天
    发表于 2019-1-19 20:35 | 显示全部楼层
    要看你要做什么啊,我怎么知道你要实现什么??
    比如说一定引脚的定义的是:A1 (这个A1是已经所包含的硬件头文件中已经定义的引脚)
    然后你定义成自己可识别的名字,比如:int driver = A1;
    然后你就可以使用driver这个变量了
    先把基础的编程搞清楚吧
    做了一个定时喂鱼的装置
    做了一个定时喂鱼的装置
    快放假了,怕鱼饿瘦了做了这么个控制,每天定时投鱼粮。用ESP8266编写,web设定参数,
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    arduino +MPU6050控制云台相机匀速转动(接受付费)!
    最近在调试云台(用的有刷直流减速电机挂大相机的那种),发现相机在往下移动时往往速
    光敏电阻检测环境光实验
    光敏电阻检测环境光实验
    基于Esp8266的点阵时钟
    基于Esp8266的点阵时钟
