查看: 285|回复: 5
[未解决] 为什么我下面的程序不按顺序执行,求大佬解惑
    2019-1-11 14:32
    发表于 2019-1-11 14:28 | 显示全部楼层 |阅读模式
    if (fsrReading>500){
    shear();
    delay(2000);
    motorreset();
    delay(time);
    shearreset();
    delay(2000);
    motorstop();
    shearstop();
    想实现在满足if条件的时候,先执行shear();两秒后再执行motorreset();按顺序执行,可是为什么实现的结果是循环执行shear(),后面的程不执行?
    我在想是不是因为在执行shear()语句时,if条件一直没有变,只有在执行motorreset()后if条件才会变化,所以导致循环执行shear?
    想问一下大佬如果想在满足if条件后,想先执行shear,再执行motorreset()以及后面的内容,应该怎么写呢?
    2018-12-6 11:03
  • 签到天数: 29 天
    发表于 2019-1-11 17:51 | 显示全部楼层
    既然怀疑了,你首先得把shear()代码贴出来。
    2019-1-11 14:32
     楼主| 发表于 2019-1-11 18:04 | 显示全部楼层
    int fsrPin = 0;
    float fsrReading;          // pressure=A0 接口
    #define CLK 11
    #define CW 8
    #define EN 7             //Motor
    const int TrigPin = 19;
    const int EchoPin = 18;
    float cm;
    int motor1 = 5;
    int motor2 = 9;
    int motor1reset = 6;
    int motor2reset = 10;
    unsigned long start;
    unsigned long whole;
    unsigned long time;
    int pina;
    pinMode(CLK,OUTPUT);
    pinMode(CW,OUTPUT);
    pinMode(EN,OUTPUT);
    pinMode(TrigPin, OUTPUT);
    pinMode(EchoPin, INPUT);
    pinMode(motor1, OUTPUT);
    pinMode(motor2, OUTPUT);
    pinMode(motor1reset, OUTPUT);
    pinMode(motor2reset, OUTPUT);
    distance(cm);
    pressure(fsrReading);
    start = millis();
    if (cm>=3&cm<=4)
    if(fsrReading<500){
      digitalWrite(CW,HIGH);              //Motor forward-rotating
      for(int i=0;i<200;++i)
    digitalWrite(CLK,HIGH);//逆时针(正转),无细分,半流,200脉冲/转,步距角1.8度,500KHZ
    delayMicroseconds(500);
    digitalWrite(CLK,LOW);
    else{
    digitalWrite(EN,LOW);
    whole = millis();
    time=whole - start;
    if (fsrReading>500&cm>=3&cm<=4){
    shear();
    motorreset();
    shearreset();
    delay(2000);
    else{
    motorstop();
    shearstop();
    float distance(float &a){
      digitalWrite(TrigPin, LOW); //低高低电平发一个短时间脉冲去TrigPin
      delayMicroseconds(2);
      digitalWrite(TrigPin, HIGH);
      delayMicroseconds(10);
    a = pulseIn(EchoPin, HIGH) / 58; //将回波时间换算成cm
    Serial.print(cm);
    Serial.print("cm");//串口输出
    Serial.println();
    return a;
    float pressure(float &b){
       b = analogRead(fsrPin);
    //   Serial.print("pressure = ");
    //   Serial.println(fsrReading);            //printf pressure
       return b;
    void shear(){
    digitalWrite(5,HIGH);
    digitalWrite(6,LOW);
    digitalWrite(9,HIGH);
    digitalWrite(10,LOW);
    delay(2000);
    void motorreset(){
    digitalWrite(CW,LOW);
    delay(time);
    void shearreset(){
    digitalWrite(5,LOW);
    digitalWrite(6,HIGH);
    digitalWrite(9,LOW);
    digitalWrite(10,HIGH);
    delay(2000);
    void motorstop(){
    void shearstop(){
    2019-1-11 14:32
     楼主| 发表于 2019-1-11 18:07 | 显示全部楼层
    _北国 发表于 2019-1-11 18:04
    int fsrPin = 0;
    #define CLK 11
    完整代码,大佬们帮我看下,前面一部分没有问题,就是贴出来的if语句里出问题了,想先执行shear();结束执行motorreset,
    void shear(){
    delay(2000);
    2019-1-11 14:32
     楼主| 发表于 2019-1-11 18:09 | 显示全部楼层
    楼下完整代码,大佬帮我看下,shear程序里是两个直流电机转动2秒,两秒后motorreset(另一个步进电机转动)执行,
    发表于 2019-1-11 20:52 | 显示全部楼层
    这么牛逼的写法。。。。。
    为什么这个库已经装好了可是在调用的时候却没有显示
    为什么这个库已经装好了可
    为什么这个库已经装好了可是在调用的时候却没有显示求解决
    BlinkerAT固件不能用
    BlinkerAT固件不能用
    求助,die端口出问题,只显示com13 com14,识别不了开发板,.....
    求助,die端口出问题,只
    求助,die端口出问题,只显示com13 com14,识别不了开发板,无法上传。 之前正常没事
    UART 传输(字符)不稳定,如何解决数据错位和乱码的情况
    UART 传输(字符)不稳定
    #寂寞單親媽媽 小孩剛斷奶 還有奶水喲
    #寂寞單親媽媽 小孩剛斷奶
    #寂寞單親媽媽 小孩剛斷奶 還有奶水喲 美玲164.D.27y 一節4000 兩節7000+送絲襪
