查看: 886|回复: 3
请问哪里有Arduino开发ESP32的编程手册
发表于 2019-1-11 17:03 | 显示全部楼层 |阅读模式
就是用来查看各种API的手册。
比如I/O类有:pinMode();  这个函数
然后Math有:abs();
还有个问题就是,ESP32有个API,ledcSetup(),ledcWrite()
我查不到这个API的信息
    2019-2-1 08:59
    发表于 2019-1-31 13:53 | 显示全部楼层
    https://github.com/espressif/arduino-esp32/blob/master/cores/esp32/esp32-hal-ledc.h
    2019-2-1 08:59
    发表于 2019-1-31 14:00 | 显示全部楼层
    \Arduinohardware\espressif\esp32\libraries\ESP32\examples\AnalogOut\LEDCSoftwareFade 下的示例 就是LEDC(可编程PWM)的使用示例。
    2019-2-1 08:59
    发表于 2019-1-31 14:03 | 显示全部楼层
    LEDC Software Fade
    This example shows how to software fade LED
    using the ledcWrite function.
    Code adapted from original Arduino Fade example:
    https://www.arduino.cc/en/Tutorial/Fade
    This example code is in the public domain.
    // use first channel of 16 channels (started from zero)
    #define LEDC_CHANNEL_0     0
    // use 13 bit precission for LEDC timer
    #define LEDC_TIMER_13_BIT  13
    // use 5000 Hz as a LEDC base frequency
    #define LEDC_BASE_FREQ     5000
    // fade LED PIN (replace with LED_BUILTIN constant for built-in LED)
    #define LED_PIN            2
    int brightness = 0;    // how bright the LED is
    int fadeAmount = 5;    // how many points to fade the LED by
    // Arduino like analogWrite
    // value has to be between 0 and valueMax
    void ledcAnalogWrite(uint8_t channel, uint32_t value, uint32_t valueMax = 255) {
      // calculate duty, 8191 from 2 ^ 13 - 1
      uint32_t duty = (8191 / valueMax) * min(value, valueMax);
      // write duty to LEDC
      ledcWrite(channel, duty);
      // Setup timer and attach timer to a led pin
      ledcSetup(LEDC_CHANNEL_0, LEDC_BASE_FREQ, LEDC_TIMER_13_BIT);
      ledcAttachPin(LED_PIN, LEDC_CHANNEL_0);
      // set the brightness on LEDC channel 0
      ledcAnalogWrite(LEDC_CHANNEL_0, brightness);
      // change the brightness for next time through the loop:
      brightness = brightness + fadeAmount;
      // reverse the direction of the fading at the ends of the fade:
      if (brightness <= 0 || brightness >= 255) {
        fadeAmount = -fadeAmount;
      // wait for 30 milliseconds to see the dimming effect
      delay(30);
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    智能物联网花盆
    智能物联网花盆
    呼吸灯实验
    呼吸灯实验
    Arduino Uno 无法上传程序
    Arduino Uno 无法上传程序
