查看: 140|回复: 1
零知增强板-WIFI网络图像传输 OV2460 ESP8266 SPI传输
    2018-6-27 00:07
    发表于 2019-1-11 17:24 | 显示全部楼层 |阅读模式
    http://www.lingzhilab.com/forum. ... d&tid=909&fromuid=2
    (出处: 零知实验室)
    本次实验主要使用零知增强板+ESP8266无线模块+OV2640,将摄像头数据通过WIFI传输到上位机进行显示,程序有很多地方需要优化,这里仅仅抛砖引玉,提供一个网络传输图像的大体思路。
    1、硬件连接
    ESP8266与零知增强板连接如下:(参照之前ESP8266 SPI方式传输文章)
    零知增强板与OV2640/OV7670摄像头连接:
    零知增强板上自带摄像头接口,请直接接入摄像头模块,这里使用的是OV2640摄像头进行试验。
    2、软件代码编写
    (1)零知平台代码,本次实验使用UDP进行传输,零知板上的ESP8266作为UDP客户端与上位机进行通信,主要代码如下:
    /*WiFiSPI example: esp8266连接AP,UDP传输数据
    电路连接:
       1. On ESP8266 must be running (flashed) WiFiSPIESP application.
       2. Connect the Arduino to the following pins on the esp8266:
                ESP8266         |
        GPIO    NodeMCU   Name  |   Lingzhi Enhanced Board
         15       D8       SS   |   53
         13       D7      MOSI  |   51
         12       D6      MISO  |   50
         14       D5      SCK   |   52
    #include "WiFiSpi.h"
    #include "WiFiSpiUdp.h"
    #include "camera.h"
    #include <fsmc_lcd.h>
    CAMERA_DCMI_INTERFACE camera;
    #ifdef JPEG_OUTPUT_MODE
    uint32_t jpeg_buf[jpeg_buf_size];        //JPEG数据缓存buf
    extern volatile uint8_t jpeg_data_ok;
    extern volatile uint32_t jpeg_data_len;
    #endif
    unsigned int localPort = 8081;
    #define        ssid                "lingzhilab"//换成自己的wifi热点
    #define        password        "lingzhilab.com"
    char udpServerIP[] = "192.168.0.126";
    int serverPort = 8081;
    #define PACKET_SIZE 512
    byte packetBuffer[PACKET_SIZE];
    const int UDP_TIMEOUT = 2000;
    WiFiSpiUdp udpClient;
    WiFiSpiClient client;
    uint8_t connect_server_flag = 0;
      // initialize serial for debugging
      Serial3.begin(460800);//camera data
      // initialize the ESP module
      WiFiSpi.init();
      // 检查是否连接了运行SPIWifi程序的8266模块
      if (WiFiSpi.status() == WL_NO_SHIELD) {
        Serial.println("WiFi shield not present");
        // don't continue
        while (true);
      int status = WL_IDLE_STATUS;
      // attempt to connect to WiFi network
      while (status != WL_CONNECTED) {
        Serial.print("Attempting to connect to WPA SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network
        status = WiFiSpi.begin(ssid, password);
      // you're connected now, so print out the data
      Serial.println("You're connected to the network");
      udpClient.begin(localPort);
      //camera begin
            camera.begin(OV2640_DEVICE_ID);
            camera.setOutSize(800,600);
            camera.startCapture((uint32_t)&jpeg_buf);
    #endif
      sendPacket(udpServerIP); // send an packet to server
      // wait ten seconds before asking for the time again
      //delay(100);
    int i;
    uint8_t *p;
    void sendPacket(char *server)
            //send camera data process
                    if(jpeg_data_ok==1)        //
                            p=(uint8_t*)jpeg_buf;
    //                        Serial.println("send one frame data...");
                            int times = jpeg_data_len*4/1024;
                            int retlen = jpeg_data_len*4 - 1024*times;
                            int x = 0;
                            for(x=0; x<times; x++)
                                    udpClient.beginPacket(server, serverPort);
                                    udpClient.write(p+1024*x,1024);
                                    udpClient.endPacket();
                            udpClient.write(p+1024*x,retlen);
                            jpeg_data_ok=2;        //
    上述代码中,需要替换自己的WIFI热点名字和密码。
    (2)上位机代码编写:
    参考这里,源码开放下载,根据自己需求进行更改即可:OV2640网络摄像头上位机+串口摄像头 调试工具源码。
    3、测试验证
    将模块按照步骤1正确连线后,将代码验证后上传到零知平台,然后就可以在上位机通过WIFI查看摄像头数据了,这里仅传输JPG格式图像,数据量较少,有时候会出现图像不完整的情况,因此需要一定的优化已达到更好的效果。
    附件:完整工程和库请到原文下载。
    上位机源码请到:OV2640网络摄像头上位机+串口摄像头 调试工具源码 这里下载。
    2018-6-27 00:07
     楼主| 发表于 2019-1-11 17:34 | 显示全部楼层
    硬件连线图:
    KittenBot杯第六届开源硬件开发大赛启动啦
    KittenBot杯第六届开源硬
    游戏机和开发板脑洞一下;这个本来就是开源的。
    游戏机和开发板脑洞一下;
    新人求助,关于舵机和限位开关。
    新人求助,关于舵机和限位
    基于MWC开源飞控DIY关键总结分享:
    基于MWC开源飞控DIY关键总
    有关函数返回值的问题
    有关函数返回值的问题
