查看: 541|回复: 1
OV2640图像上传到云端OneNet
    2018-6-27 00:07
    发表于 2019-1-12 19:27 | 显示全部楼层 |阅读模式
    原贴:零知板+OV2640图像上传到云端OneNet ESP8266 wifi EDP协议
    http://www.lingzhilab.com/forum.php?mod=viewthread&tid=911&fromuid=2
    (出处: 零知实验室)
    本实验使用之前的零知增强板OV2640获取图像,ESP8266 WIFI传输等试验知识,我们把获取的图像传输到云端OneNet平台。
    1、硬件连接:
    零知增强板自带OV2640摄像头接口,直接接入即可;零知-增强板与ESP8266模块连接进行wifi传输,可以使用串口也可以使用SPI方式,本次实验使用SPI接口,接线方式查看之前的零知增强板+WIFI模块传输实验。
    2、代码编写
    零知增强板获取图像数据的代码请查看之前的帖子,这里重点是上传数据到云端,主要分为:建立客户端,连接EDP服务器,向平台请求连接,向云端上传数据。具体代码如下:
    WiFiSPI example: esp8266连接AP,UDP传输数据
    电路连接:
       1. On ESP8266 must be running (flashed) WiFiSPIESP application.
       2. Connect the Arduino to the following pins on the esp8266:
                ESP8266         |
        GPIO    NodeMCU   Name  |   Lingzhi Enhanced Board
         15       D8       SS   |   53
         13       D7      MOSI  |   51
         12       D6      MISO  |   50
         14       D5      SCK   |   52
    #include "WiFiSpi.h"
    #include "WiFiSpiUdp.h"
    #include "cJSON.h"
    #include "Common.h"
    #include "EdpKit.h"
    #include "camera.h"
    #include <fsmc_lcd.h>
    CAMERA_DCMI_INTERFACE camera;
    unsigned int localPort = 80;
    //OneNet平台相关参数
    char API_KEY[]        =        "API key";//你的oneNet上的api key
    char DEVICE_ID[]=        "device id";                                        //你的设备ID
    #define JPG_DATA        "ov2640_jpg"
    #define EDPserver        "jjfaedp.hedevice.com"
    #define        ssid                "lingzhilab"//换成自己的wifi热点
    #define        password        "lingzhilab.com"
    //char udpServerIP[] = "183.230.40.34";
    char serverIP[] = "192.168.0.126";//for testing
    int edpServerPort = 876;
    WiFiSpiClient client;
    uint8_t connect_server_flag = 0;
    #ifdef JPEG_OUTPUT_MODE
    uint32_t jpeg_buf[jpeg_buf_size];        //JPEG数据缓存buf
    extern volatile uint8_t jpeg_data_ok;
    extern volatile uint32_t jpeg_data_len;
    #endif
    void connectEDP();
    void sendPacket(uint8_t *jpg_data, uint32_t len);//发送一帧的图像
      // initialize serial for debugging
      // initialize the ESP module
      WiFiSpi.init();
      // 检查是否连接了运行SPIWifi程序的8266模块
      if (WiFiSpi.status() == WL_NO_SHIELD) {
        Serial.println("WiFi shield not present");
        // don't continue
        while (true);
      int status = WL_IDLE_STATUS;
      // attempt to connect to WiFi network
      while (status != WL_CONNECTED) {
        Serial.print("Attempting to connect to wifi with SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network
        status = WiFiSpi.begin(ssid, password);
      // 已经连接到wifi
      Serial.println("You're connected to the network");
      if (client.connect(EDPserver, edpServerPort)) {
        Serial.println("connected to server");
      }else{
            Serial.println("connect server failed");
              while(1);
     //开启camera,这里传输jpg图像
            camera.begin(OV2640_DEVICE_ID);
            camera.setOutSize(240,320);
            camera.startCapture((uint32_t)&jpeg_buf);
    #endif
     //请求连接EDP服务器
            connectEDP();
            uint8_t *p;
            //发送摄像头数据
            if(jpeg_data_ok==1)        //
                    p=(uint8_t*)jpeg_buf;
                    Serial.println("send one frame data...");
                    //去掉开头的无效数据,有时候前面一堆0,??
                    bool start_flag = false;
                    int start_index = 0;
                    for(int i=0; i<jpeg_data_len*4; i++)
                            if(p == 0xff)
                                    if(p[i+1] == 0xd8)
                                            start_index = i;
                                            start_flag = true;
                    //valid frame
                    if(start_flag)
                            sendPacket(p+start_index, jpeg_data_len*4-start_index);
                    jpeg_data_ok=2;        //
            delay(3000);
    void connectEDP()
    /*利用sdk 中EdpKit.h 中PacketConnect1 方法封包连接协议*/
            EdpPacket* send_pkg = PacketConnect1(DEVICE_ID,API_KEY);
            /*发送连接协议包数据*/
            //int ret = DoSend (sockfd, send_pkg->_data, send_pkg->_write_pos);
              int size = send_pkg->_write_pos;
              Serial.print("send size:");
              Serial.println(size);
              client.write(send_pkg->_data, send_pkg->_write_pos);
            /*使用完后必须删除send_pkg , 否则会造成内存泄漏*/
            DeleteBuffer(&send_pkg);
    // send an packet to server
              Serial.println("send jpg");
              char text2[]="{\"ds_id\": \"ov2640_jpg\"}";
              cJSON *desc_json;
              desc_json=cJSON_Parse(text2);
              EdpPacket* send_pkg = PacketSavedataBin(NULL, desc_json, jpg_data, len, 0);
              Serial.println("buff size:");
              Serial.print("jpg_buff:");Serial.println(len);
              Serial.print("packet_size:");Serial.println(send_pkg->_write_pos);
              uint8_t *send_buff = send_pkg->_data;
              uint32_t send_len = send_pkg->_write_pos;
              int packetLen = 1024;
              int t = 0;
              for(t=0; t< send_len/packetLen; t++)
                      Serial.print("ofset:");Serial.println(t*packetLen);
                      Serial.print("lenth:");Serial.println(packetLen);
                     client.write(send_buff+t*packetLen, packetLen);
              Serial.print("lenth:");Serial.println(send_len-packetLen*t);
              client.write(send_buff+t*packetLen, send_len-packetLen*t);
              Serial.println("send done");
    上述代码中,请更改自己的wifi热点连接,以及在OneNet平台建立设备时的API key和设备ID号。
    3、OneNet 平台建立设备和应用进行数据显示
    详细的做法请查看这篇文章:
    OneNet云平台显示摄像头数据详细操作教程 EDP OV2640 ESP8266
    4、测试验证
    在云平台建立好应用和设备后,先用平台提供的调试工具调试好,再使用零知平台设备发送数据进行显示:
    上述步骤正确完成后,我们在零知IDE串口中看到如下信息:
    2018-6-27 00:07
     楼主| 发表于 2019-1-12 19:28 | 显示全部楼层
    云端效果:
    BLE胸带+GPS墨水屏运动心率表
    BLE胸带+GPS墨水屏运动心
    参赛项目: BLE胸带+GPS墨水屏运动心率表 参赛组员: 沧海笑1122 项目简介: 我喜欢
    基于树莓派的水滴摄影控制器(更新中)
    基于树莓派的水滴摄影控制
    【项目名称】基于树莓派的水滴摄影控制器(更新中) 状态:已完成 资料正在整理更
    如何实现避障小车和机械臂的组合
    如何实现避障小车和机械臂
    学校有科创杯比赛,想出了一个题目,但是一直无法实现,想请教大神指点指点 想达成的
    arduino nano 上传出错保这个错怎么办呀
    arduino nano 上传出错保
    基于Esp8266的点阵时钟
    基于Esp8266的点阵时钟
