查看: 7508|回复: 6
[使用文档] [Arduino物联网开发实战4]天猫精灵控制2
    发表于 2019-1-17 14:34 | 显示全部楼层 |阅读模式
    对于照明设备,除了可以查询其状态外,还可以改变其状态。
    详见:天猫精灵blinker接口文档
    可以修改各回调函数中的内容,以响应不同的指令。完整示例如下:
    #define BLINKER_WIFI
    #define BLINKER_ALIGENIE_LIGHT
    #define PIN            13
    #define NUMPIXELS      24
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
    #define RGB_1 "RGBKey"
    BlinkerRGB WS2812(RGB_1);
    uint8_t colorR, colorG, colorB, colorW;
    bool wsState;
    String wsMode = BLINKER_CMD_COMMON;
    void pixelShow()
        pixels.setBrightness(colorW);
        for(int i = 0; i < NUMPIXELS; i++){
            pixels.setPixelColor(i, colorR, colorG, colorB);
        pixels.show();
    void ws2812_callback(uint8_t r_value, uint8_t g_value, uint8_t b_value, uint8_t bright_value)
        BLINKER_LOG("R value: ", r_value);
        BLINKER_LOG("G value: ", g_value);
        BLINKER_LOG("B value: ", b_value);
        BLINKER_LOG("Rrightness value: ", bright_value);
        colorR = r_value;
        colorG = g_value;
        colorB = b_value;
        colorW = bright_value;
        pixelShow();
    String getColor()
        uint32_t color = colorR << 16 | colorG << 8 | colorB;
        switch (color)
            case 0xFF0000 :
                return "Red";
            case 0xFFFF00 :
                return "Yellow";
            case 0x0000FF :
                return "Blue";
            case 0x00FF00 :
                return "Green";
            case 0xFFFFFF :
                return "White";
            case 0x000000 :
                return "Black";
            case 0x00FFFF :
                return "Cyan";
            case 0x800080 :
                return "Purple";
            case 0xFFA500 :
                return "Orange";
            default :
                return "White";
    void aligeniePowerState(const String & state)
            BlinkerAliGenie.print();
            wsState = true;
            if (colorW == 0) colorW = 255;
            wsState = false;
        pixelShow();
    void aligenieColor(const String & color)
        BLINKER_LOG("need set color: ", color);
        if (color == "Red") {
            colorR = 255;
            colorG = 0;
            colorB = 0;
        else if (color == "Yellow") {
            colorR = 255;
            colorG = 255;
            colorB = 0;
        else if (color == "Blue") {
            colorR = 0;
            colorG = 0;
            colorB = 255;
        else if (color == "Green") {
            colorR = 0;
            colorG = 255;
            colorB = 0;
        else if (color == "White") {
            colorR = 255;
            colorG = 255;
            colorB = 255;
        else if (color == "Black") {
            colorR = 0;
            colorG = 0;
            colorB = 0;
        else if (color == "Cyan") {
            colorR = 0;
            colorG = 255;
            colorB = 255;
        else if (color == "Purple") {
            colorR = 128;
            colorG = 0;
            colorB = 128;
        else if (color == "Orange") {
            colorR = 255;
            colorG = 165;
            colorB = 0;
        if (wsState == false) {
            wsState = true;
            colorW = 255;
        if (colorW == 0) {
            colorW = 255;
        pixelShow();
        BlinkerAliGenie.color(color);
    void aligenieMode(const String & mode)
        BLINKER_LOG("need set mode: ", mode);
        if (mode == BLINKER_CMD_ALIGENIE_READING) {
            // Your mode function
        else if (mode == BLINKER_CMD_ALIGENIE_MOVIE) {
        else if (mode == BLINKER_CMD_ALIGENIE_SLEEP) {
        else if (mode == BLINKER_CMD_ALIGENIE_HOLIDAY) {
        else if (mode == BLINKER_CMD_ALIGENIE_MUSIC) {
        else if (mode == BLINKER_CMD_ALIGENIE_COMMON) {
        wsMode = mode;
        BlinkerAliGenie.mode(mode);
    void aligenieCancelMode(const String & cmode)
        BLINKER_LOG("need cancel mode: ", cmode);
        if (cmode == BLINKER_CMD_ALIGENIE_READING) {
        else if (cmode == BLINKER_ALIGENIE_CMD_MOVIE) {
        else if (cmode == BLINKER_ALIGENIE_CMD_SLEEP) {
        else if (cmode == BLINKER_ALIGENIE_CMD_HOLIDAY) {
        else if (cmode == BLINKER_ALIGENIE_CMD_MUSIC) {
        else if (cmode == BLINKER_ALIGENIE_CMD_COMMON) {
        wsMode = BLINKER_CMD_COMMON; // new mode
        BlinkerAliGenie.mode(wsMode); // must response
    void aligenieBright(const String & bright)
        BLINKER_LOG("need set brightness: ", bright);
        if (bright == BLINKER_CMD_MAX) {
            colorW = 255;
        else if (bright == BLINKER_CMD_MIN) {
            colorW = 0;
        else {
            colorW = bright.toInt();
        BLINKER_LOG("now set brightness: ", colorW);
        pixelShow();
        BlinkerAliGenie.brightness(colorW);
    void aligenieRelativeBright(int32_t bright)
        BLINKER_LOG("need set relative brightness: ", bright);
        if (colorW + bright < 255 && colorW + bright >= 0) {
            colorW += bright;
        pixelShow();
        BlinkerAliGenie.brightness(bright);
    void aligenieColoTemp(int32_t colorTemp)
        BLINKER_LOG("need set colorTemperature: ", colorTemp);
        BlinkerAliGenie.colorTemp(colorTemp);
    void aligenieRelativeColoTemp(int32_t colorTemp)
        BLINKER_LOG("need set relative colorTemperature: ", colorTemp);
    void aligenieQuery(int32_t queryCode)
        switch (queryCode)
                BlinkerAliGenie.powerState(wsState ? "on" : "off");
                BlinkerAliGenie.color(getColor());
                BlinkerAliGenie.colorTemp(50);
            case BLINKER_CMD_QUERY_COLOR_NUMBER :
                BLINKER_LOG("AliGenie Query Color");
            case BLINKER_CMD_QUERY_MODE_NUMBER :
                BLINKER_LOG("AliGenie Query Mode");
            case BLINKER_CMD_QUERY_COLORTEMP_NUMBER :
                BLINKER_LOG("AliGenie Query ColorTemperature");
            case BLINKER_CMD_QUERY_BRIGHTNESS_NUMBER :
                BLINKER_LOG("AliGenie Query Brightness");
            default :
        Blinker.vibrate();
        Blinker.print(BlinkerTime);
        BLINKER_DEBUG.stream(Serial);
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.attachData(dataRead);
        BlinkerAliGenie.attachPowerState(aligeniePowerState);
        BlinkerAliGenie.attachColor(aligenieColor);
        BlinkerAliGenie.attachMode(aligenieMode);
        BlinkerAliGenie.attachCancelMode(aligenieCancelMode);
        BlinkerAliGenie.attachBrightness(aligenieBright);
        BlinkerAliGenie.attachRelativeBrightness(aligenieRelativeBright);
        BlinkerAliGenie.attachColorTemperature(aligenieColoTemp);
        BlinkerAliGenie.attachRelativeColorTemperature(aligenieRelativeColoTemp);
        BlinkerAliGenie.attachQuery(aligenieQuery);
        pinMode(14, OUTPUT);
        digitalWrite(14, HIGH);
        pinMode(15, OUTPUT);
        digitalWrite(15, HIGH);
        colorR = 255;
        colorG = 255;
        colorB = 255;
        colorW = 0;
        wsState = true;
        pixels.begin();
        WS2812.attach(ws2812_callback);
        pixelShow();
        pixels.show();
    更详细的文档,可见
    https://diandeng.tech/doc/tmallgenie
    2020-2-18 20:31
  • 签到天数: 8 天
    发表于 2019-1-17 21:57 | 显示全部楼层
    iiiiiiiiiiiiiiiiiiiiiiiiiiiiii
    2019-11-22 11:05
  • 签到天数: 11 天
    发表于 2019-11-19 20:09 | 显示全部楼层
    blinker有没有办法和手机进行字符串的通信呢?
    可以  详情 回复 发表于 2019-11-19 22:46
     楼主| 发表于 2019-11-19 22:46 | 显示全部楼层
    可以
    2019-11-22 11:05
  • 签到天数: 11 天
    发表于 2019-11-20 09:31 | 显示全部楼层
    应该用哪个函数啊
    2019-11-22 11:05
  • 签到天数: 11 天
    发表于 2019-11-20 09:34 | 显示全部楼层
    看了看手机端没有可以输入字符的组件啊
    我想可以用手机发送一段字符串,8266收到后在再回一段字符串
    调试组件,或者直接用按键自定义方式  详情 回复 发表于 2019-11-20 14:28
     楼主| 发表于 2019-11-20 14:28 | 显示全部楼层
    trip 发表于 2019-11-20 09:34
    看了看手机端没有可以输入字符的组件啊
    我想可以用手机发送一段字符串,8266收到后在再回一段字符串 ...
    调试组件,或者直接用按键自定义方式
    [Arduino物联网开发实战2]数据反馈
    [Arduino物联网开发实战2]
    小爱同学开电脑 esp8266 12f
    小爱同学开电脑 esp8266 1
    1.mini D1 wifi ESP-12F N ESP8266开发板 2.1路 5V继电器模块 高电平触发 3.AMS1117-3
    服务器平台又挂了么,显示服务器未响应了
    服务器平台又挂了么,显示
    数据读不回来了
