查看: 2141|回复: 3
求助,编译问题!
    2020-4-16 13:55
    发表于 2019-1-25 12:03 | 显示全部楼层 |阅读模式
    Arduino:1.8.5 (Windows 7), 开发板:"WeMos D1 R1, 80 MHz, Flash, Enabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT:HT(unsigned char, unsigned char, unsigned char)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:13: multiple definition of `DHT:HT(unsigned char, unsigned char, unsigned char)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:12: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::begin()':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:25: multiple definition of `DHT::begin()'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:24: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::convertCtoF(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:68: multiple definition of `DHT::convertCtoF(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:64: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::convertFtoC(float)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:73: multiple definition of `DHT::convertFtoC(float)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:69: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::computeHeatIndex(float, float, bool)':
    "Blinker.h" 对应多个库
    已使用: E:\arduino-1.8.5\libraries\Blinker
    未使用:C:\Users\rain\Documents\Arduino\libraries\blinker-library-master
    "DHT.h" 对应多个库
    已使用: C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:103: multiple definition of `DHT::computeHeatIndex(float, float, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:92: first defined here
    未使用:E:\arduino-1.8.5\libraries\DHT_sensor_library
    "Hash.h" 对应多个库
    已使用: C:\Users\rain\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\Hash
    未使用:E:\arduino-1.8.5\libraries\Hash
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::expectPulse(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:255: multiple definition of `DHT::expectPulse(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:237: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::read(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:134: multiple definition of `DHT::read(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:123: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::readTemperature(bool, bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:36: multiple definition of `DHT::readTemperature(bool, bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:35: first defined here
    c:/users/rain/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\DHT-sensor-library-master\DHT.cpp.o: in function `DHT::readHumidity(bool)':
    C:\Users\rain\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.cpp:76: multiple definition of `DHT::readHumidity(bool)'; libraries\Blinker\modules\dht\DHT.cpp.o:E:\arduino-1.8.5\libraries\Blinker\src\modules\dht/DHT.cpp:72: first defined here
    collect2.exe: error: ld returned 1 exit status
    exit status 1
    为开发板 WeMos D1 R1 编译时出错。
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    exit status 1
    这是什么错误?
    2020-4-16 13:55
     楼主| 发表于 2019-1-25 12:04 | 显示全部楼层
    * Download latest Blinker library here:
    * https://github.com/blinker-iot/blinker-library/archive/master.zip
    * Blinker is a cross-hardware, cross-platform solution for the IoT.
    * It provides APP, device and server support,
    * and uses public cloud services for data transmission and storage.
    * It can be used in smart home, data monitoring and other fields
    * to help users build Internet of Things projects better and faster.
    * Make sure installed 2.5.0 or later ESP8266/Arduino package,
    * if use ESP8266 with Blinker.
    * https://github.com/esp8266/Arduino/releases
    * Docs: https://doc.blinker.app/
    *       https://github.com/blinker-iot/blinker-doc/wiki
    * Blinker 库下载地址:
    * Blinker 是一套跨硬件、跨平台的物联网解决方案,提供APP端、设备端、
    * 服务器端支持,使用公有云服务进行数据传输存储。可用于智能家居、
    * 数据监测等领域,可以帮助用户更好更快地搭建物联网项目。
    * 如果使用 ESP8266 接入 Blinker,
    * 请确保安装了 2.5.0 或更新的 ESP8266/Arduino 支持包。
    * 文档: https://doc.blinker.app/
    #define BLINKER_WIFI
    BlinkerNumber HUMI("humi");
    BlinkerNumber TEMP("temp");
    // Download Adafruit DHT-sensor-library library here:
    // https://github.com/adafruit/DHT-sensor-library
    #include <DHT.h>
    #define DHTPIN 2
    //#define DHTTYPE DHT11   // DHT 11
    #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
    //#define DHTTYPE DHT21   // DHT 21 (AM2301)
    DHT dht(DHTPIN, DHTTYPE);
    uint32_t read_time = 0;
    float humi_read, temp_read;
        Blinker.vibrate();
        Blinker.print(BlinkerTime);
    void heartbeat()
        HUMI.print(humi_read);
        TEMP.print(temp_read);
        BLINKER_DEBUG.stream(Serial);
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.attachData(dataRead);
        dht.begin();
        if (read_time == 0 || (millis() - read_time) >= 2000)
            read_time = millis();
            float h = dht.readHumidity();
            if (isnan(h) || isnan(t)) {
                BLINKER_LOG("Failed to read from DHT sensor!");
                return;
            float hic = dht.computeHeatIndex(t, h, false);
            humi_read = h;
            temp_read = t;
            BLINKER_LOG("Humidity: ", h, " %");
            BLINKER_LOG("Temperature: ", t, " *C");
            BLINKER_LOG("Heat index: ", hic, " *C");
    这个DHT.WIFI的例子
    发表于 2019-1-25 12:20 | 显示全部楼层
    把blinker库完全删除后重新下载
    2020-4-16 13:55
     楼主| 发表于 2019-1-25 13:20 | 显示全部楼层
    跪谢三水大神啊!
    求大神看看哪里有问题,设
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    Arduino 求助 串口接收数据不正确,数据丢失问题
    Arduino 求助 串口接收数
