查看: 209|回复: 5
[未解决] 求助!!Arduino编译无法成功
发表于 2019-2-11 01:11 | 显示全部楼层 |阅读模式
从1.6.8更新到1.8.8就一直无法编译成功了。
WIN10系统,Arduino UNO,串口检查了没问题,空程序还是blink都不行,各种方法都试了,接连弄了十多个小时,还是解决不了,求大佬指点!!
[img]file:///C:\Users\87238\AppData\Roaming\Tencent\Users\872388589\TIM\WinTemp\RichOle\MS3VPKI`}`9%G%CQNQ~[LGP.png[/img]
[img]file:///C:\Users\87238\AppData\Roaming\Tencent\Users\872388589\TIM\WinTemp\RichOle\MS3VPKI`}`9%G%CQNQ~[LGP.png[/img]void setup() {
Arduino:1.8.8 (Windows 10), 开发板:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\87238\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\87238\AppData\Local\Temp\arduino_build_845952 -warnings=none -build-cache C:\Users\87238\AppData\Local\Temp\arduino_cache_194062 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\87238\AppData\Local\Temp\untitled116357924.tmp\sketch_feb11a\sketch_feb11a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\87238\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\87238\AppData\Local\Temp\arduino_build_845952 -warnings=none -build-cache C:\Users\87238\AppData\Local\Temp\arduino_cache_194062 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\87238\AppData\Local\Temp\untitled116357924.tmp\sketch_feb11a\sketch_feb11a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_845952\\sketch\\sketch_feb11a.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\87238\AppData\Local\Temp\arduino_build_845952\sketch\sketch_feb11a.ino.cpp
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_845952\\sketch\\sketch_feb11a.ino.cpp" -o "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_845952\\preproc\\ctags_target_for_gcc_minus_e.cpp"
avr-g++: error: device-specs/specs-atmega328p: No such file or directory
exit status 1
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\87238\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\87238\AppData\Local\Temp\arduino_build_187489 -warnings=none -build-cache C:\Users\87238\AppData\Local\Temp\arduino_cache_194062 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\87238\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path C:\Users\87238\AppData\Local\Temp\arduino_build_187489 -warnings=none -build-cache C:\Users\87238\AppData\Local\Temp\arduino_cache_194062 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_187489\\sketch\\Blink.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\87238\AppData\Local\Temp\arduino_build_187489\sketch\Blink.ino.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_187489\\sketch\\Blink.ino.cpp" -o "C:\\Users\\87238\\AppData\\Local\\Temp\\arduino_build_187489\\preproc\\ctags_target_for_gcc_minus_e.cpp"
exit status 1
 楼主| 发表于 2019-2-11 17:40 | 显示全部楼层
求帮助啊啊啊啊啊啊啊!!!!
    2019-1-29 14:07
    发表于 2019-2-12 07:51 | 显示全部楼层
    你是不是用的中文路径啊.不行就卸载掉IDE 重新安装下看看.
    2019-2-1 08:59
    发表于 2019-2-12 09:05 | 显示全部楼层
    C:\\Users\\87238\\AppData\\Local\\Arduino15\\下找到preferences.txt
    修改
    compiler.cache_core=ture
    compiler.cache_core=false
    发表于 2019-2-12 21:52 | 显示全部楼层
    avr-g++: error: device-specs/specs-atmega328p: No such file or directory 这行不是报错的信息吗
    找不到specs-atmega328p 这个文件,去hardware\tools\avr\lib\gcc\avr\5.4.0\device-specs目录下看看有没有这个文件,没有的话,重装个IDE吧
     楼主| 发表于 2019-2-12 22:36 | 显示全部楼层
    找不到 ...
    这个文件是有的。而且我尝试了各种版本的arduino ide 他全都是这个问题。
    KittenBot杯第六届开源硬件开发大赛启动啦
    KittenBot杯第六届开源硬
    求助,Due使用问题。
    求助,Due使用问题。
    如图,Due没有SPI库和Wire库。
    arduino+onenet+edp协议
    每次在edp.c这里报错,请问这是什么问题?(这一句本身应该没有问题的)
    一文教你选择Arduino开发板,小白进
    一文教你选择Arduino开发
    能够与arduino结合的嵌入式视觉识别模块
    能够与arduino结合的嵌入
    该视觉识别模块是我司于2018年新推出的产品,处理器采用双核MCU,面向创客以及steam
