查看: 576|回复: 1
[未解决] 求助矩阵键盘中断
发表于 2019-4-13 10:38 | 显示全部楼层 |阅读模式
#include <Keypad.h>
#include <Wire.h>
char a,b;
int flag=2;
int led=13;
int mykey[2];
int A,B,c=0,d,e,state=LOW;
const byte ROWS = 4; //four rows
const byte COLS = 3; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
    pinMode(flag,INPUT);
attachInterrupt(0,blink,CHANGE);
digitalWrite(flag,state);
pinMode(led,OUTPUT);
  int array1()
{ if(a==hexaKeys[0][0]){A=1;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[0][1]){A=2;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[0][2]){A=3;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[1][0]){A=4;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[1][1]){A=5;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[1][2]){A=6;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[2][0]){A=7;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[2][1]){A=8;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[2][2]){A=9;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[3][0]){A=10;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[3][1]){A=0;Serial.print("A=");Serial.println(A);}
      else if(a==hexaKeys[3][2]){A=11;Serial.print("A=");Serial.println(A);}
     void blink()
  digitalWrite(led,state);
  array1();
void loop(){
  a=customKeypad.getKey();
  if(a!=NO_KEY)
{ state=!state;
这样为啥实现不了中断,改了不知道多久了,实在不会了,谢谢各位大神帮忙
ESP32能烧录程序但是不能启动
ESP32能烧录程序但是不能
电路图3如下1,能烧录程序但是不能启动,3.3V供电正常
SpiderRobot 蜘蛛
SpiderRobot 蜘蛛
点灯·blinker-app智动化
