查看: 422|回复: 1
[未解决] 中断异常
发表于 2019-4-13 20:45 | 显示全部楼层 |阅读模式
为啥我这个程序只能中断一次,下一次没反应了
#include <Keypad.h>
#include <Wire.h>
int mykey;
int key=2;
unsigned int data=0;
unsigned char frist_one;
unsigned char frist_two;
unsigned char shu_frist;
unsigned char shu_two;
unsigned char shu_three;
unsigned char shu_end;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {10,9, 8, 7}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6,5, 4, 3}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
    void blink()
        digitalWrite(13,!digitalRead(13));
        skey();
void setup(){
    pinMode(13,OUTPUT);
    attachInterrupt(0,blink,CHANGE);
void readKeyboard()
  bgn:
  char customKey = customKeypad.getKey();
  if (customKey!=NO_KEY){
switch(customKey)
case '1' : data=1;break;
case '2' : data=2;break;
case '3' : data=3;break;
case '4':data=4;break;
case '5':data=5;break;
case '6':data=6;break;
case '7':data=7;break;
case '8':data=8;break;
case '9':data=9;break;
case '0':data=10;break;
case '*':data=11;break;
case '#':data=12;break;
case 'A' : data=13;break;
case 'B' : data=14;break;
case 'C':data=15;break;
case 'D':data=16;break;
default:break;
goto bgn;
  void skey()
   readKeyboard();
    if(data==11)
        shu_frist=1;
      if(shu_frist==1)//绗竴浣�
      { bga:
        if((data==1)|| (data==2)||(data==3)||(data==4)|| (data==5)|| (data==6)|| (data==7)|| (data==8)|| (data==9)|| (data==10))
             frist_one=data;
             Serial.print(frist_one);
             shu_frist=0;
             shu_two=1;
       if(shu_two==1)//绗﹀彿
        if((data==13)|| (data==14)|| (data==15)|| (data==16))
             shu_two=0;
             shu_three=1;
        if(shu_three==1)//绗笁浣�
         if((data==1)||(data==2)||(data==3)||(data==4)||(data==5)||(data==6)||(data==7)||(data==8)||(data==9)||(data==10))
             frist_two=data;
             Serial.print(frist_two);
             shu_three=0;
             shu_end=1;
        if(shu_end==1)//璁$畻
         if(data==12)
        {     mykey=frist_one*10+frist_two;
              Serial.println(mykey);
             shu_end=0;
Arduino使用电阻分压测量电池电压问题
Arduino使用电阻分压测量
上传一个蓝牙串口助手,安卓版的
上传一个蓝牙串口助手,安
/* 本软件为蓝牙串口通讯工具,可与蓝牙模块(如:HC-05)建立连接,进行串口通讯,可
蓝牙串口助手 1.3 beta 1测试版
蓝牙串口助手 1.3 beta 1
在之前版本的基础上增加了视觉相关功能: 颜色跟踪模式及人脸跟踪模式, 增加了发
萌新跪求arduinoUNO板对接无线模块(如何接和程序)
萌新跪求arduinoUNO板对接
