查看: 237|回复: 0
[未解决] arduino温湿度串口监视器显示问题
发表于 2019-4-23 00:34 来自手机 | 显示全部楼层 |阅读模式
本人刚学arduino,遇到一些技术问题,希望大佬们帮我看一下程序,具体就是温湿度开始一直为零,后面好久才出示数,而且用手摸dht11传感器反应也不灵敏,解决了问题一定重谢
程序如下
#include <Wire.h>
#include "dht.h"
#include <Servo.h> //引入lib
Servo myservo;  // 创建一个伺服电机对象
dht DHT;
#define DHT11_PIN 8
//#define DHT21_PIN 5
//#define DHT22_PIN 12
#define Buzzer 11
#define LED 13
#define ADDRESS_BH1750FVI 0x23    //ADDR="L" for this module
#define ONE_TIME_H_RESOLUTION_MODE 0x20
//One Time H-Resolution Mode:
//Resolution = 1 lux //Measurement time (max.) = 180ms
//Power down after each measurement
#define A1 2      //引脚命名
#define B1 3
#define C1 4
#define D1 5
byte highByte = 0;
byte lowByte = 0;
unsigned int sensorOut = 0;
unsigned int illuminance = 0;
float wendu=0,shidu=0;
myservo.attach(9);
myservo.write(10);
Wire.begin();
  pinMode(Buzzer,OUTPUT);   //蜂鸣器为IO输出     digitalWrite(Buzzer,LOW); //蜂鸣器初始为不鸣叫     BuzzerDi();
  pinMode(LED,OUTPUT);
digitalWrite(LED,0);
pinMode(A1,OUTPUT);   //设置引脚为输出引脚  pinMode(B1,OUTPUT);
pinMode(C1,OUTPUT);
pinMode(D1,OUTPUT);
motordoz(50);
motordof(50);
if(DHT.read11(DHT11_PIN)==0)
wendu=DHT.temperature;
   shidu=DHT.humidity;
   }       Wire.beginTransmission(ADDRESS_BH1750FVI); //"notify" the matching device     Wire.write(ONE_TIME_H_RESOLUTION_MODE);
//set operation mode
     Wire.endTransmission();
   delay(5);
Wire.requestFrom(ADDRESS_BH1750FVI, 2); //ask Arduino to read back 2 bytes from the sensor
highByte = Wire.read();  // get the high byte
lowByte = Wire.read(); // get the low byte
    sensorOut = (highByte<<8)|lowByte;
   illuminance = sensorOut/1.2;
Serial.print(illuminance);
Serial.print(" lux");
Serial.print(wendu);
  Serial.print(",\t");
     Serial.println(shidu);
  if(wendu>45)motordoz(50);
  else if(wendu<35)motordof(50);
  digitalWrite(A1,0);    //A1引脚高电平        digitalWrite(B1,LOW);
   digitalWrite(C1,LOW);
    digitalWrite(D1,LOW);
  if(shidu>70)myservo.write(170);    if(shidu<30)myservo.write(10);
if(wendu>45)BuzzerDi();
   if(illuminance>2000)
    digitalWrite(LED,1);
delay(5);
void BuzzerDi()
digitalWrite(Buzzer,HIGH);     //蜂鸣器响  delay(200);                     //延时20ms  digitalWrite(Buzzer,LOW);       //蜂鸣器关闭
delay(200);
void motordoz(int s)
Phase_A();      //设置A相位
delay(s);      //改变延时可改变旋转速度
  Phase_B();      //设置B相位
delay(s);
Phase_C();      //设置C相位
delay(s);
Phase_D();      //设置D相位
delay(s);
void motordof(int s)
Phase_D();      //设置A相位
Phase_C();      //设置B相位
delay(s);
  Phase_B();      //设置C相位
  delay(s);
Phase_A();      //设置D相位
delay(s);
void Phase_A()
digitalWrite(A1,HIGH);    //A1引脚高电平   digitalWrite(B1,LOW);
void Phase_B()
{  digitalWrite(A1,LOW);
digitalWrite(B1,HIGH);    //B1引脚高电平   digitalWrite(C1,LOW);
void Phase_C()
  digitalWrite(C1,HIGH);    //C1引脚高电平   digitalWrite(D1,LOW);
void Phase_D()
  digitalWrite(D1,HIGH);    //D1引脚高电平
74HC595的疑惑终于解开
74HC595的疑惑终于解开
【Arduino】37种传感器系列实验(1)---干簧管模块
【Arduino】37种传感器系
37款传感器的提法,在网络上广泛流传,其实Arduino能够兼容的传感器模块肯定是不止37
开贴讲讲NRF24L01P,让你
体验OneNET4.0,一起来拼开发板
体验OneNET4.0,一起来拼
一、 活动时间2019年04月09日-2019年6月30日 二、活动链接1.登录Arduino中文社区账
