查看: 144|回复: 1
blinker中的button-wifi例程
    2019-5-7 20:44
    发表于 2019-5-12 23:52 | 显示全部楼层 |阅读模式
    blinker中的button-wifi例程控制小车,每次程序打开app进入控制页面,按钮按住(press状态)然后松开(pressup状态)松开不起作用,任意点击一个按钮才会出现松开状态(pressup)。后面再按住,松开就正常了,请问问题出在哪里?
     * Download latest Blinker library here:
     * https://github.com/blinker-iot/blinker-library/archive/master.zip
     * Blinker is a cross-hardware, cross-platform solution for the IoT.
     * It provides APP, device and server support,
     * and uses public cloud services for data transmission and storage.
     * It can be used in smart home, data monitoring and other fields
     * to help users build Internet of Things projects better and faster.
     * Make sure installed 2.5.0 or later ESP8266/Arduino package,
     * if use ESP8266 with Blinker.
     * https://github.com/esp8266/Arduino/releases
     * Docs: https://doc.blinker.app/
     *       https://github.com/blinker-iot/blinker-doc/wiki
     * Blinker 库下载地址:
     * Blinker 是一套跨硬件、跨平台的物联网解决方案,提供APP端、设备端、
     * 服务器端支持,使用公有云服务进行数据传输存储。可用于智能家居、
     * 数据监测等领域,可以帮助用户更好更快地搭建物联网项目。
     * 如果使用 ESP8266 接入 Blinker,
     * 请确保安装了 2.5.0 或更新的 ESP8266/Arduino 支持包。
     * 文档: https://doc.blinker.app/
    #define BLINKER_WIFI
    char auth[] = "97971d25a1b0";
    char ssid[] = "ketingkz";
    char pswd[] = "jurenpass1207";
    #define BUTTON_1 "btn-abc"
    #define BUTTON_2 "btn-s"
    #define BUTTON_3 "btn-x"
    #define BUTTON_4 "btn-z"
    #define BUTTON_5 "btn-y"
    #define BUTTON_6 "btn-t"
    int motorL1 = D0; //左边轮子
    int motorL2 = D1;
    int motorR1 = D7; //右边轮子
    int motorR2 = D8;
    BlinkerButton Button2(BUTTON_2);
    BlinkerButton Button3(BUTTON_3);
    BlinkerButton Button4(BUTTON_4);
    BlinkerButton Button5(BUTTON_5);
    BlinkerButton Button6(BUTTON_6);
        if (state == BLINKER_CMD_BUTTON_TAP) {
            BLINKER_LOG("Button tap!");
            Button1.icon("icon_1");
            Button1.color("#FFFFFF");
            Button1.text("Your button name or describe");
            Button1.print();
        else if (state == BLINKER_CMD_BUTTON_PRESSED) {
            BLINKER_LOG("Button pressed!");
            Button1.print();
        else if (state == BLINKER_CMD_BUTTON_RELEASED) {
            BLINKER_LOG("Button released!");
            // Button1.text("Your button name", "describe");
            Button1.print();
        else {
            BLINKER_LOG("Get user setting: ", state);
            Button1.print();
    void button2_callback(const String & state)
       // digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
            Button2.icon("icon_1");
            Button2.color("#FFFFFF");
            Button2.text("前进");
           Button2.print();
            line();
            delay(200);
            lull();
            Button2.text("连续前进");
            Button2.print();
            line();
            delay(200);
            Button2.text("停止前进");
            // Button2.text("Your button name", "describe");
            Button2.print();
            lull();
        else {
            Button2.text("s");
            Button2.print();
    void button3_callback(const String & state)
            Button3.icon("icon_1");
            Button3.color("#FFFFFF");
            Button3.text("后退");
            Button3.print();
            back();
            delay(200);
            lull();
            Button3.text("连续后退");
            Button3.print();
            back();
            Button3.text("停止后退");
            // Button3.text("Your button name", "describe");
            Button3.print();
            lull();
        else {
            Button3.text("x");
            Button3.print();
    void button4_callback(const String & state)
            Button4.icon("icon_1");
            Button4.color("#FFFFFF");
            Button4.text("左转");
            Button4.print();
            L();
            delay(200);
            lull();
            Button4.text("连续左转");
            Button4.print();
            L();
            Button4.text("左转停止");
            // Button4.text("Your button name", "describe");
            Button4.print();
            lull();
        else {
            Button4.text("Your button name or describe");
            Button4.print();
    void button5_callback(const String & state)
            Button5.icon("icon_1");
            Button5.color("#FFFFFF");
            Button5.text("右转");
            Button5.print();
            R();
            delay(200);
            lull();
            Button5.text("连续右转");
            Button5.print();
            R();
            Button5.text("停止右转");
            // Button5.text("Your button name", "describe");
            Button5.print();
            lull();
        else {
            Button5.text("Your button name or describe");
            Button5.print();
    void button6_callback(const String & state)
            Button6.icon("icon_1");
            Button6.color("#FFFFFF");
            Button6.text("Your button name or describe");
            Button6.print();
            lull();
            Button6.print();
             lull();
            // Button6.text("Your button name", "describe");
            Button6.print();
             lull();
        else {
            Button6.print();
        Blinker.vibrate();
        Blinker.print(BlinkerTime);
        BLINKER_DEBUG.stream(Serial);
        pinMode(LED_BUILTIN, OUTPUT);
         pinMode(motorL1, OUTPUT);
      pinMode(motorL2, OUTPUT);
      pinMode(motorR1, OUTPUT);
      pinMode(motorR2, OUTPUT);
        Blinker.attachData(dataRead);
        Button4.attach(button4_callback);
        Button5.attach(button5_callback);
        Button6.attach(button6_callback);
    void line() {
     /* digitalWrite(motorL1, HIGH);
      digitalWrite(motorL2, LOW);
      digitalWrite(motorR1, LOW);
      digitalWrite(motorR2, HIGH);*/
     analogWrite(motorL1, 700);
      analogWrite(motorR2, 700);
    void L() {
      digitalWrite(motorL1, LOW);
      analogWrite(motorL2, 700);
    void R() {
      analogWrite(motorR1, 700);
      digitalWrite(motorR2, LOW);
    void back() { //后退函数
    void lull() {
      digitalWrite(motorL2, HIGH);
      digitalWrite(motorR1, HIGH);
    发表于 2019-5-13 00:49 | 显示全部楼层
    我这边测试是正常的,请在android 8.0或者9.0的手机上测试最新版本,如果还是有问题,请按提问要求发帖:
    https://www.arduino.cn/thread-83658-1-1.html
    请问一下微动开关 4X4矩阵
    Nano 一直显示上传,不显示上传成功。
    Nano 一直显示上传,不显
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    Arduino板接74HC拓展接驱动器接多个四项电机
    Arduino板接74HC拓展接驱
