查看: 2206|回复: 0
OTTO机器人
    2019-6-29 16:55
  • 签到天数: 29 天
    发表于 2019-5-15 20:08 | 显示全部楼层 |阅读模式
    我按照官网上的教程走了一遍,最后连接上蓝牙却无法让它动起来,这是怎么回事啊???
    还有,arduino编译成功后显示  ‘可用内存偏低,可能出现稳定性问题’,这个该如何优化代码???
    代码如下:
    //-- Zowi basic firmware v2 adapted to Otto
    //-- (c) BQ. Released under a GPL licencse
    //-- 04 December 2015
    //-- Authors:  Anita de Prado: ana.deprado@bq.com
    //--           Jose Alberca:   jose.alberca@bq.com
    //--           Javier Isabel:  javier.isabel@bq.com
    //--           Juan Gonzalez (obijuan): juan.gonzalez@bq.com
    //--           Irene Sanz : irene.sanz@bq.com
    //-- Experiment with all the features that Otto has thanks to Zowi!
    //-- FEBRUARY 2017: modified for OTTO with MAX7219 MATRIX LED module
    //-- allows OTTO to work with ZOWI APP
    //-- Jason Snow
    //-- JANUARY 2018: modified for new OTTO App
    //-- Jason Snow
    #include <BatReader.h>
    #include <US.h>
    #include "MaxMatrix.h"
    MaxMatrix ledmatrix=MaxMatrix(12,10,11, 1); //PIN  12=DIN, PIN 10=CS, PIN 11=CLK
    //-- Library to manage serial commands
    #include <OttoSerialCommand.h>
    OttoSerialCommand SCmd;  //The SerialCommand object
    //-- Otto Library
    #include <Otto.h>
    Otto Otto;  //This is Otto!
    //-- First step: Configure the pins where the servos are attached
            |     O   O     |
    YR 3==> |               | <== YL 2
    RR 5==>   -----   ------  <== RL 4
      #define PIN_YL 2 //servo[0]
      #define PIN_YR 3 //servo[1]
      #define PIN_RL 4 //servo[2]
      #define PIN_RR 5 //servo[3]
    // buzzer connected to pin 13
    //-- Global Variables -------------------------------------------//
    const char programID[]="Otto_APP_1"; //Each program will have a ID
    const char name_fac='$'; //Factory name
    const char name_fir='#'; //First name
    //-- Movement parameters
    int T=1000;              //Initial duration of movement
    int moveId=0;            //Number of movement
    int modeId=0;            //Number of mode
    int moveSize=15;         //Asociated with the height of some movements
    //-- Otto has 5 modes:
    //--    * MODE = 0: Otto is awaiting
    //--    * MODE = 1: Dancing mode!
    //--    * MODE = 2: Obstacle detector mode
    //--    * MODE = 3: Noise detector mode
    //--    * MODE = 4: OttoPAD or any Teleoperation mode (listening SerialPort).
    volatile int MODE=0; //State of Otto in the principal state machine.
    unsigned long previousMillis=0;
    int randomDance=0;
    int randomSteps=0;
    int REDled = 0;
    int GREENled = 0;
    int BLUEled = 0;
    bool obstacleDetected = false;
    //-- Setup ------------------------------------------------------//
    void setup(){
      //Serial communication initialization
      //Set the servo pins
      Otto.init(PIN_YL,PIN_YR,PIN_RL,PIN_RR,true);
      // set up Matrix display
      ledmatrix.init();
      ledmatrix.setIntensity(1);
      //Set a random seed
      randomSeed(analogRead(A6));
      //Setup callbacks for SerialCommand commands
      SCmd.addCommand("S", receiveStop);      //  sendAck & sendFinalAck
      SCmd.addCommand("L", receiveLED);       //  sendAck & sendFinalAck
      SCmd.addCommand("T", recieveBuzzer);    //  sendAck & sendFinalAck
      SCmd.addCommand("M", receiveMovement);  //  sendAck & sendFinalAck
      SCmd.addCommand("H", receiveGesture);   //  sendAck & sendFinalAck
      SCmd.addCommand("K", receiveSing);      //  sendAck & sendFinalAck
      SCmd.addCommand("C", receiveTrims);     //  sendAck & sendFinalAck
      SCmd.addCommand("G", receiveServo);     //  sendAck & sendFinalAck
      SCmd.addCommand("R", receiveName);      //  sendAck & sendFinalAck
      SCmd.addCommand("E", requestName);
      SCmd.addCommand("D", requestDistance);
      SCmd.addCommand("N", requestNoise);
      SCmd.addCommand("B", requestBattery);   //
      SCmd.addCommand("I", requestProgramId);
      SCmd.addCommand("J", requestMode);
      SCmd.addCommand("", requestRGB);
      SCmd.addDefaultHandler(receiveStop);
      //Otto wake up!
      Otto.sing(S_connection);
      Otto.home();
    // Animation Uuuuuh - A little moment of initial surprise
      for(int i=0; i<2; i++){
          for (int i=0;i<8;i++){
            Otto.putAnimationMouth(littleUuh,i);
            delay(150);
      //Smile for a happy Otto
        Otto.putMouth(smile);
        Otto.sing(S_happy);
        delay(200);
      //If Otto's name is '#' means that Otto hasn't been baptized
      //In this case, Otto does a longer greeting
      //5 = EEPROM address that contains first name character
      if (EEPROM.read(5)==name_fir){
            Otto.jump(1,700);
            delay(200);
            Otto.shakeLeg(1,T,1);
            Otto.putMouth(smallSurprise);
            Otto.swing(2,800,20);
            Otto.home();
      Otto.putMouth(happyOpen);
      previousMillis = millis();
    //-- Principal Loop ---------------------------------------------//
      if (Serial.available()>0 && MODE!=4){
      // test
        SCmd.readSerial();
        //MODE=4;
      switch (MODE) {
          //-- MODE 0 - Otto is awaiting
          case 0:
            //Every 80 seconds in this mode, Otto falls asleep
            if (millis()-previousMillis>=80000){
                OttoSleeping_withInterrupts(); //ZZzzzzz...
                previousMillis=millis();
          //-- MODE 1 - Dance Mode!
          case 1:
            randomDance=random(5,21); //5,20
            if((randomDance>14)&&(randomDance<19)){
                randomSteps=1;
                T=1600;
            else{
                randomSteps=random(3,6); //3,5
                T=1000;
            Otto.putMouth(random(10,21));
            for (int i=0;i<randomSteps;i++){
                move(randomDance);
          //-- MODE 2 - Obstacle detector mode
          case 2:
            if(obstacleDetected){
                  Otto.putMouth(bigSurprise);
                  Otto.sing(S_surprise);
                  Otto.jump(5, 500);
                  Otto.putMouth(confused);
                  Otto.sing(S_cuddly);
                //Otto takes two steps back
                for(int i=0;i<3;i++){
                  Otto.walk(1,1300,-1);
                obstacleDetector();
               //If there are no obstacles and no button is pressed, Otto shows a smile
               if(obstacleDetected==true){break;}
               else{
                  delay(50);
                  obstacleDetector();
               //If there are no obstacles and no button is pressed, Otto shows turns left
               for(int i=0; i<3; i++){
                  else{
                      Otto.turn(1,1000,1);
                      obstacleDetector();
                //If there are no obstacles and no button is pressed, Otto is happy
                else{
                    Otto.home();
                    Otto.sing(S_happy_short);
                    delay(200);
            }else{
                Otto.walk(1,1000,1); //Otto walk straight
                obstacleDetector();
          //-- MODE 3 - Noise detector mode
          case 3:
            if (Otto.getNoise()>=650){ //740
              delay(50);  //Wait for the possible 'lag' of the button interruptions.
                          //Sometimes, the noise sensor detect the button before the interruption takes efect
                Otto.sing(S_OhOoh);
                move(randomDance);
                Otto.home();
                delay(500); //Wait for possible noise of the servos while get home
          //-- MODE 4 - OttoPAD or any Teleoperation mode (listening SerialPort)
          case 4:
            SCmd.readSerial();
            //If Otto is moving yet
            if (Otto.getRestState()==false){
              move(moveId);
          default:
              MODE=0;
    //-- Functions --------------------------------------------------//
    //-- Function to read distance sensor & to actualize obstacleDetected variable
    void obstacleDetector(){
       int distance = Otto.getDistance();
            if(distance<15){
              obstacleDetected = true;
            }else{
    //-- Function to receive Stop command.
    void receiveStop(){
        sendAck();
        Otto.home();
        sendFinalAck();
    //-- Function to receive LED commands
    void receiveLED(){
        //sendAck & stop if necessary
        sendAck();
        Otto.home();
        //Examples of receiveLED Bluetooth commands
        //L 000000001000010100100011000000000
        //L 001111111111111111111111111111111 (todos los LED encendidos)
        unsigned long int matrix;
        char *arg;
        char *endstr;
        arg=SCmd.next();
        //Serial.println (arg);
        if (arg != NULL) {
          matrix=strtoul(arg,&endstr,2);    // Converts a char string to unsigned long integer
          Otto.putMouth(matrix,false);
        }else{
          Otto.putMouth(xMouth);
          delay(2000);
          Otto.clearMouth();
        sendFinalAck();
    //-- Function to receive buzzer commands
    void recieveBuzzer(){
        sendAck();
        Otto.home();
        bool error = false;
        int frec;
        int duration;
        char *arg;
        arg = SCmd.next();
        if (arg != NULL) { frec=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { duration=atoi(arg); } // Converts a char string to an integer
        else {error=true;}
        if(error==true){
          delay(2000);
          Otto.clearMouth();
        }else{
          Otto._tone(frec, duration, 1);
        sendFinalAck();
    //-- Function to receive TRims commands
    void receiveTrims(){
        sendAck();
        Otto.home();
        int trim_YL,trim_YR,trim_RL,trim_RR;
        //Definition of Servo Bluetooth command
        //C trim_YL trim_YR trim_RL trim_RR
        //Examples of receiveTrims Bluetooth commands
        //C 20 0 -8 3
        bool error = false;
        char *arg;
        arg=SCmd.next();
        if (arg != NULL) { trim_YL=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { trim_YR=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { trim_RL=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { trim_RR=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        if(error==true){
          delay(2000);
          Otto.clearMouth();
        }else{ //Save it on EEPROM
          Otto.setTrims(trim_YL, trim_YR, trim_RL, trim_RR);
          Otto.saveTrimsOnEEPROM(); //Uncomment this only for one upload when you finaly set the trims.
        sendFinalAck();
    //-- Function to receive Servo commands
    void receiveServo(){
        sendAck();
        moveId = 30;
        //G  servo_YL servo_YR servo_RL servo_RR
        //Example of receiveServo Bluetooth commands
        //G 90 85 96 78
        bool error = false;
        char *arg;
        int servo_YL,servo_YR,servo_RL,servo_RR;
        arg=SCmd.next();
        if (arg != NULL) { servo_YL=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { servo_YR=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { servo_RL=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        arg = SCmd.next();
        if (arg != NULL) { servo_RR=atoi(arg); }    // Converts a char string to an integer
        else {error=true;}
        if(error==true){
          delay(2000);
          Otto.clearMouth();
        }else{ //Update Servo:
          int servoPos[4]={servo_YL, servo_YR, servo_RL, servo_RR};
          Otto._moveServos(200, servoPos);   //Move 200ms
        sendFinalAck();
    //-- Function to receive movement commands
    void receiveMovement(){
        sendAck();
        if (Otto.getRestState()==true){
            Otto.setRestState(false);
        //Definition of Movement Bluetooth commands
        //M  MoveID  T   MoveSize
        char *arg;
        arg = SCmd.next();
        if (arg != NULL) {moveId=atoi(arg);}
        else{
          delay(2000);
          Otto.clearMouth();
          moveId=0; //stop
        arg = SCmd.next();
        if (arg != NULL) {T=atoi(arg);}
        else{
          T=1000;
        arg = SCmd.next();
        if (arg != NULL) {moveSize=atoi(arg);}
        else{
          moveSize =15;
    //-- Function to execute the right movement according the movement command received.
    void move(int moveId){
      bool manualMode = false;
      switch (moveId) {
        case 0:
          Otto.home();
        case 1: //M 1 1000
          Otto.walk(1,T,1);
        case 2: //M 2 1000
          Otto.walk(1,T,-1);
        case 3: //M 3 1000
          Otto.turn(1,T,1);
        case 4: //M 4 1000
          Otto.turn(1,T,-1);
        case 5: //M 5 1000 30
          Otto.updown(1,T,moveSize);
        case 6: //M 6 1000 30
          Otto.moonwalker(1,T,moveSize,1);
        case 7: //M 7 1000 30
          Otto.moonwalker(1,T,moveSize,-1);
        case 8: //M 8 1000 30
          Otto.swing(1,T,moveSize);
        case 9: //M 9 1000 30
          Otto.crusaito(1,T,moveSize,1);
        case 10: //M 10 1000 30
          Otto.crusaito(1,T,moveSize,-1);
        case 11: //M 11 1000
          Otto.jump(1,T);
        case 12: //M 12 1000 30
          Otto.flapping(1,T,moveSize,1);
        case 13: //M 13 1000 30
          Otto.flapping(1,T,moveSize,-1);
        case 14: //M 14 1000 20
          Otto.tiptoeSwing(1,T,moveSize);
        case 15: //M 15 500
          Otto.bend(1,T,1);
        case 16: //M 16 500
          Otto.bend(1,T,-1);
        case 17: //M 17 500
        case 18: //M 18 500
          Otto.shakeLeg(1,T,-1);
        case 19: //M 19 500 20
          Otto.jitter(1,T,moveSize);
        case 20: //M 20 500 15
          Otto.ascendingTurn(1,T,moveSize);
        default:
            manualMode = true;
      if(!manualMode){
        sendFinalAck();
    //-- Function to receive gesture commands
    void receiveGesture(){
        sendAck();
        Otto.home();
        //Definition of Gesture Bluetooth commands
        //H  GestureID
        int gesture = 0;
        char *arg;
        arg = SCmd.next();
        if (arg != NULL) {gesture=atoi(arg);}
          //Otto.putMouth(xMouth);
          delay(2000);
          //Otto.clearMouth();
        switch (gesture) {
          case 1: //H 1
            Otto.playGesture(OttoHappy);
          case 2: //H 2
            Otto.playGesture(OttoSuperHappy);
          case 3: //H 3
            Otto.playGesture(OttoSad);
          case 4: //H 4
            Otto.playGesture(OttoSleeping);
          case 5: //H 5
            Otto.playGesture(OttoFart);
          case 6: //H 6
            Otto.playGesture(OttoConfused);
          case 7: //H 7
            Otto.playGesture(OttoLove);
          case 8: //H 8
            Otto.playGesture(OttoAngry);
          case 9: //H 9
            Otto.playGesture(OttoFretful);
          case 10: //H 10
            Otto.playGesture(OttoMagic);
          case 11: //H 11
            Otto.playGesture(OttoWave);
          case 12: //H 12
            Otto.playGesture(OttoVictory);
          case 13: //H 13
            Otto.playGesture(OttoFail);
          default:
        sendFinalAck();
    //-- Function to receive sing commands
    void receiveSing(){
        sendAck();
        Otto.home();
        //Definition of Sing Bluetooth commands
        //K  SingID
        int sing = 0;
        char *arg;
        arg = SCmd.next();
        if (arg != NULL) {sing=atoi(arg);}
         // Otto.putMouth(xMouth);
          delay(2000);
        switch (sing) {
          case 1: //K 1
          case 2: //K 2
            Otto.sing(S_disconnection);
          case 3: //K 3
          case 4: //K 4
            Otto.sing(S_OhOoh);
          case 5: //K 5
            Otto.sing(S_OhOoh2);
          case 6: //K 6
          case 7: //K 7
            Otto.sing(S_sleeping);
          case 8: //K 8
            Otto.sing(S_happy);
          case 9: //K 9
            Otto.sing(S_superHappy);
          case 10: //K 10
          case 11: //K 11
            Otto.sing(S_sad);
          case 12: //K 12
            Otto.sing(S_confused);
          case 13: //K 13
            Otto.sing(S_fart1);
          case 14: //K 14
            Otto.sing(S_fart2);
          case 15: //K 15
            Otto.sing(S_fart3);
          case 16: //K 16
            Otto.sing(S_mode1);
          case 17: //K 17
            Otto.sing(S_mode2);
          case 18: //K 18
            Otto.sing(S_mode3);
          case 19: //K 19
            Otto.sing(S_buttonPushed);
          default:
        sendFinalAck();
    //-- Function to receive Name command
    void receiveName(){
        sendAck();
        Otto.home();
        char newOttoName[11] = "";  //Variable to store data read from Serial.
        int eeAddress = 5;          //Location we want the data to be in EEPROM.
        char *arg;
        arg = SCmd.next();
        if (arg != NULL) {
          //Complete newOttoName char string
          int k = 0;
          while((*arg) && (k<11)){
              newOttoName[k]=*arg++;
              k++;
          EEPROM.put(eeAddress, newOttoName);
          delay(2000);
        sendFinalAck();
    //-- Function to send Otto's name
    void requestName(){
        Otto.home(); //stop if necessary
        char actualOttoName[11]= "";  //Variable to store data read from EEPROM.
        int eeAddress = 5;            //EEPROM address to start reading from
        //Get the float data from the EEPROM at position 'eeAddress'
        EEPROM.get(eeAddress, actualOttoName);
        Serial.print(F("&&"));
        Serial.print(F("E "));
        Serial.print(actualOttoName);
        Serial.println(F("%%"));
        Serial.flush();
    //-- Function to send ultrasonic sensor measure (distance in "cm")
    void requestDistance(){
        Serial.print(F("D "));
        Serial.print(distance);
        Serial.flush();
    //-- Function to send noise sensor measure
    void requestNoise(){
        int microphone= Otto.getNoise(); //analogRead(PIN_NoiseSensor);
        Serial.print(F("N "));
        Serial.print(microphone);
        Serial.flush();
    //-- Function to send battery voltage percent
    void requestBattery(){
        //The first read of the batery is often a wrong reading, so we will discard this value.
        double batteryLevel = Otto.getBatteryLevel();
        Serial.print(F("B "));
        Serial.print(batteryLevel);
        Serial.flush();
    //-- Function to send program ID
    void requestProgramId(){
        Serial.print(F("I "));
        Serial.print(programID);
        Serial.flush();
    //-- Function to send Ack comand (A)
    void sendAck(){
      delay(30);
      Serial.print(F("A"));
      Serial.flush();
    //-- Function to send final Ack comand (F)
    void sendFinalAck(){
      delay(30);
      Serial.print(F("F"));
      Serial.flush();
    //-- Function to receive mode selection.
    void requestMode(){
        sendAck();
        Otto.home();
        //Definition of Mode Bluetooth commands
        //J ModeID
        char *arg;
        arg = SCmd.next();
        if (arg != NULL)
          modeId=atoi(arg);
          Otto.putMouth(heart);
        else{
          delay(2000);
          Otto.clearMouth();
          modeId=0; //stop
    switch (modeId) {
          case 0: //
            MODE = 0;
          case 1: //
            MODE = 1;
            Otto.sing(S_mode1);
            Otto.putMouth(one);
        delay(200);
            case 2: //
            MODE = 2;
            Otto.sing(S_mode2);
            Otto.putMouth(two);
            case 3: //
            MODE = 3;
            Otto.sing(S_mode3);
            Otto.putMouth(three);
            case 4: //
            Otto.sing(S_mode1);
            Otto.putMouth(four);
            MODE = 4;
         default:
            MODE = 0;
    sendFinalAck();
    //-- Function to receive RGB colours.
    void requestRGB(){
        sendAck();
        Otto.home();
        //J ModeID
        char *arg;
        arg = SCmd.next();
        if (arg != NULL)
          REDled=atoi(arg);
          else{
          delay(2000);
          Otto.clearMouth();
          REDled=0; //stop
        arg = SCmd.next();
        if (arg != NULL) {GREENled=atoi(arg);}
        else{
          GREENled=0;
        arg = SCmd.next();
        if (arg != NULL) {BLUEled=atoi(arg);}
        else{
          BLUEled =0;
        Otto.putMouth(okMouth);
          delay(2000);
          Otto.clearMouth();
    //-- Functions with animatics
    void OttoLowBatteryAlarm(){
        if(batteryLevel<45){
              Otto.putMouth(thunder);
              Otto.bendTones (880, 2000, 1.04, 8, 3);  //A5 = 880
              delay(30);
              Otto.bendTones (2000, 880, 1.02, 8, 3);  //A5 = 880
              Otto.clearMouth();
    void OttoSleeping_withInterrupts(){
      int bedPos_0[4]={100, 80, 60, 120};
        Otto._moveServos(700, bedPos_0);
      for(int i=0; i<4;i++){
          Otto.putAnimationMouth(dreamMouth,0);
          Otto.bendTones (100, 200, 1.04, 10, 10);
          Otto.putAnimationMouth(dreamMouth,1);
          Otto.bendTones (200, 300, 1.04, 10, 10);
          Otto.putAnimationMouth(dreamMouth,2);
          Otto.bendTones (300, 500, 1.04, 10, 10);
          Otto.bendTones (400, 250, 1.04, 10, 1);
          Otto.bendTones (250, 100, 1.04, 10, 1);
        Otto.putMouth(lineMouth);
      Otto.home();
    【Arduino】108种传感器模块系列实验(129)---BH1750光照传感器
    【Arduino】108种传感器模
    智能插座-blinker-天猫精灵-开源分享
    智能插座-blinker-天猫精
    1。之前学blinker做的一个项目,开源分享一下。视频上传B站,PCB在立创开源。
    在Arduino Nano 33 BLE Sense上用机器学习通过声音分辨不同的昆虫
    用机器学习识别植物的应用有很多,拿出手机,打开APP,拍张照片就可以一键识别眼前盛
