查看: 160|回复: 2
[已解决] arduino上传一直这样,编译可以通过,在别人的电脑可以上传
发表于 2019-5-15 21:28 | 显示全部楼层 |阅读模式
java.lang.NullPointerException
at processing.app.BaseNoGui.removeDescendants(BaseNoGui.java:832)
at processing.app.BaseNoGui.removeDir(BaseNoGui.java:854)
at processing.app.Base.removeDir(Base.java:2322)
at processing.app.Sketch.saveAs(Sketch.java:711)
at processing.app.Editor.handleSaveAs(Editor.java:2377)
at processing.app.Editor.handleSave(Editor.java:2318)
at processing.app.Editor.handleExport(Editor.java:2444)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:349)
at java.awt.Component.processMouseEvent(Component.java:6522)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3322)
at java.awt.Component.processEvent(Component.java:6290)
at java.awt.Container.processEvent(Container.java:2234)
at java.awt.Component.dispatchEventImpl(Component.java:4881)
at java.awt.Container.dispatchEventImpl(Container.java:2292)
at java.awt.Component.dispatchEvent(Component.java:4703)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4898)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4530)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4462)
at java.awt.Container.dispatchEventImpl(Container.java:2278)
at java.awt.Window.dispatchEventImpl(Window.java:2739)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:751)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:702)
at java.awt.EventQueue$3.run(EventQueue.java:696)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:724)
at java.awt.EventQueue$4.run(EventQueue.java:722)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:721)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Sketch uses 4,774 bytes (14%) of program storage space. Maximum is 32,256 bytes.
全局变量使用了222字节,(10%)的动态内存,余留1,826字节局部变量。最大为2,048字节。
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
    发表于 2019-5-15 21:46 | 显示全部楼层
    建议用最新的IDE试试,首页有下载
     楼主| 发表于 2019-5-15 22:06 | 显示全部楼层
    奈何col 发表于 2019-5-15 21:46
    建议用最新的IDE试试,首页有下载
    问题已解决,谢谢!就是IDE版本低了,下载了1.8.9的IDE问题解决了。
    请问一下微动开关 4X4矩阵
    Nano 一直显示上传,不显示上传成功。
    Nano 一直显示上传,不显
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    Arduino板接74HC拓展接驱动器接多个四项电机
    Arduino板接74HC拓展接驱
