查看: 87|回复: 2
[已解决] 在使用blinker实例库中button-wifi出现了错误 求助
    2019-5-19 20:25
    发表于 2019-5-16 19:10 | 显示全部楼层 |阅读模式
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10808 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_353261 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_196683 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Administrator\Documents\Arduino\libraries\blinker-library-master\examples\Blinker_Button\Button_WiFi\Button_WiFi.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10808 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_353261 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_196683 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Administrator\Documents\Arduino\libraries\blinker-library-master\examples\Blinker_Button\Button_WiFi\Button_WiFi.ino
    Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_353261\\sketch\\Button_WiFi.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_353261\\sketch\\Button_WiFi.ino.cpp" -o nul
    Error while detecting libraries included by C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_353261\sketch\Button_WiFi.ino.cpp
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\OneButton\\OneButton.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\Ultrasonic.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\WebSockets.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\WebSocketsClient.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\WebSocketsServer.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\libb64\\cdecode.c" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\libb64\\cencode.c" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\WebSockets\\libsha1\\libsha1.c" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\dht\\DHT.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\mqtt\\Adafruit_MQTT.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src\\modules\\mqtt\\Adafruit_MQTT_Client.cpp" -o nul
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Administrator\\Documents\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_353261\\sketch\\Button_WiFi.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_353261\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    In file included from C:\Users\Administrator\Documents\Arduino\libraries\blinker-library-master\examples\Blinker_Button\Button_WiFi\Button_WiFi.ino:4:0:
    C:\Users\Administrator\Documents\Arduino\libraries\blinker-library-master\src/Blinker.h:19:10: error: #error This code is intended to run on the ESP8266/ESP32 platform! Please check your Tools->Board setting.
    使用 0.1.5  版本的库 blinker-library-master 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\blinker-library-master
    exit status 1
    发表于 2019-5-16 19:26 | 显示全部楼层
    请下载最新版lib,文档中有链接
    2019-5-19 20:25
     楼主| 发表于 2019-5-16 20:31 | 显示全部楼层
    谅解在哪里呀 我是新手找不到
    请问一下微动开关 4X4矩阵
    Nano 一直显示上传,不显示上传成功。
    Nano 一直显示上传,不显
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    Arduino板接74HC拓展接驱动器接多个四项电机
    Arduino板接74HC拓展接驱
