查看: 374|回复: 1
[已解决] blinker hello wifi 烧录失败 程序编译没问题
    2019-5-19 20:25
    发表于 2019-5-16 21:52 | 显示全部楼层 |阅读模式
    avrdude: Version 6.3-20171130
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM3
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x73
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x73
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x73
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x73
    发表于 2019-5-16 22:41 | 显示全部楼层
    这是硬件问题了,和blinker无关了
    确定下驱动是否安装好,串口是否选对,板子是否选对
    Arduino lcd屏幕亮了但是不显示字符
    Arduino lcd屏幕亮了但是
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    【Arduino】108种传感器模
    两个ESP8266通过云端实现远程数据交互
    两个ESP8266通过云端实现
