查看: 427|回复: 1
[分享] 动手用blinker做台灯
    2018-8-29 00:35
  • 签到天数: 21 天
    发表于 2019-5-27 01:50 | 显示全部楼层 |阅读模式
    分享一个使用blinker做的台灯,使用的是esp8266,可以使用天猫精灵进行控制(亮度、开关)。
    附上代码
    #define BLINKER_PRINT Serial //串口调试组件
    #define BLINKER_MQTT         //通讯方式
    #define BLINKER_ALIGENIE_LIGHT
    //#define BLINKER_ESP_SMARTCONFIG
    #define BLINKER_DEBUG_ALL
    #define LED D1
    #define Button_io D2
    #define LED_light_MAX 100
    #define LED_light_MIX 10
    bool LED_power = false; //灯状态
    int  set_light = 60;    //设置态
    int  Now_light = 0;     //现在态
    char auth[] = "";     //APP key
    char ssid[] = "";        //WiFi 名字
    char pswd[] = "";       //密码
    //创建对象
    BlinkerButton power("btn_pwr");
    BlinkerSlider Slider1("Slider");
     * APP组件
    void slider1_callback(int32_t value) //滑动条处理
      set_light = value;
      LED_light_set(set_light , LED_power);
      Slider1.print(value);
    void power_callback(const String &state) { //台灯开关处理
        LED_power = true ;
        power.icon("fal fa-power-off");
        power.color("#FF0000");
        power.text("", "开");
        power.print("on");
      if (state == BLINKER_CMD_OFF) {
        LED_power = false ;
        power.color("#FFFFFF");
        power.text("", "关");
        power.print("off");
     * 语音音箱处理
    void aligeniePowerSate(const String & state) //台灯开关处理
        LED_power = true ;
        BlinkerAliGenie.print();
        LED_power = false ;
    void aligenieBright(const String & bright) //灯亮度处理
      if (bright == BLINKER_CMD_MAX) {
        set_light = LED_light_MAX;
      else if (bright == BLINKER_CMD_MIN) {
        set_light = LED_light_MIX;
      else {
        set_light = bright.toInt();
      BlinkerAliGenie.brightness(set_light);
    void aligenieRelativeBright(int32_t bright)
      set_light += bright;
    void LED_light_set(int light, bool power) {
      light = light * 10.24;
      if (power) {
        analogWrite(LED ,light);
      else {
        analogWrite(LED , LOW);
    #if defined(BLINKER_PRINT)
      BLINKER_DEBUG.debugAll();
    #endif
      power.attach(power_callback);
      Slider1.attach(slider1_callback);
      BlinkerAliGenie.attachPowerState(aligeniePowerSate);
      BlinkerAliGenie.attachBrightness(aligenieBright);
      BlinkerAliGenie.attachRelativeBrightness(aligenieRelativeBright);
      pinMode(LED , OUTPUT);
      pinMode(Button_io , INPUT_PULLUP);
      digitalWrite(LED, LOW);
      attachInterrupt(Button_io,button,FALLING);
    void heartbeat() //心跳包
      if (LED_power) {
        power.print("on");
      else {
        power.print("off");
      Slider1.print(set_light);
    void button() {
        if (digitalRead(Button_io) == LOW){
          detachInterrupt(Button_io);
          LED_power = !LED_power;
    原理是ESP8266控制NMOS调节灯的电压从而改变灯的亮度。
    代码只需填WiFi信息和KEY即可使用,做人做到底,我也把PCB也贴上来。
    注意:PCB文件我画的是双色(支持暖和白灯)如需单色接一个即可。
    PCB 3D
    PCB 3D
    PCB 3D
    PCB 3D
    PCB解析
    实物图
    台灯调试成功。
    PCB文件和原理图已上传到github,只能用于学习。不可商业。
    github地址:https://github.com/hqs1/blinker-lamp
    如有问题可在评论区留言。
    发表于 2019-6-8 17:14 | 显示全部楼层
    期待小爱与小度
    MAC arduino ESP8266mDNS.h不能加载。。。
    SpiderRobot 蜘蛛
    SpiderRobot 蜘蛛
    【原创】 drawbot平面关节
    项目分享——arduino梦幻交互雪花2019
    项目分享——arduino梦幻
    雪花由30颗LED打造,分为17个独立的部分,由Arduino Nano控制。每组LED都可以用PWM调
    体验OneNET4.0,一起来拼开发板
    体验OneNET4.0,一起来拼
    一、 活动时间2019年04月09日-2019年6月30日 二、活动链接1.登录Arduino中文社区账
