查看: 602|回复: 1
[求助] blinkerAliGenie天猫精灵的代码写好后连不上WiFi
    2019-5-26 23:31
    发表于 2019-6-9 00:25 | 显示全部楼层 |阅读模式
    • 硬件: [esparduino v3]
    • 接入方式: [WIFI]
    • 开发环境: [Arduino|]
    • 操作系统: [Windows]
    • IDE设置
    • Module: [Nodemcu 0.9(esp-12Module)]
    • Flash Size: [4MB]
    • lwip Variant: [v2 Lower Memory]
    • Reset Method: [ck|nodemcu]
    • Flash Frequency: [40Mhz]
    • CPU Frequency: [80Mhz]
    • Upload Speed: [115200]
    问题主要是esparduino连不上WiFi,用例程可以连接上,怀疑我的代码有误,编译显示是成功的,让我抓不着头脑,代码没问题,wifi的ssid,pswd都是对的原来我只设置了开和关都可以进行连接,
    #define BLINKER_WIFI
    #define BLINKER_ALIGENIE_LIGHT
    #define ledR 6//ledR端口
    #define ledG 7//ledG 端口
    #define ledB 8//ledB 端口
    #define ledbright 5//控制亮度的端口
    char auth[]="2a3864d31a93";
    char ssid[]="114";
    char pswd[]="114meiyoumima";
    uint8_t colorR,colorG,colorB,colorW;
    bool oState=false;
    void LightShow(){//颜色输出,出去的方法
      analogWrite(ledR,colorR);
      analogWrite(ledG,colorG);
      analogWrite(ledB,colorB);
      analogWrite(ledbright,colorW);
    void aligeniePowerState(const String & state){
      BLINKER_LOG("need set power state:",state);
      if(state==BLINKER_CMD_ON){
        colorW=255;
        BlinkerAliGenie.print();
        oState=true;
        }else if(state==BLINKER_CMD_OFF){
          colorW=0;
          LightShow();
    void aligenieQuery(int32_t queryCode){
      BLINKER_LOG("aligenie query codes:",queryCode);
      switch (queryCode)
      case BLINKER_CMD_QUERY_ALL_NUMBER:
      BlinkerAliGenie.powerState(oState?"on":"off");
      case BLINKER_CMD_QUERY_POWERSTATE_NUMBER:
      BLINKER_LOG("AliGenie Query PowerState");
      case BLINKER_CMD_QUERY_COLOR_NUMBER:
      BLINKER_LOG("set color");
      BlinkerAliGenie.color(getcolor());
      case BLINKER_CMD_QUERY_BRIGHTNESS_NUMBER:
      BLINKER_LOG("set bright");
      BlinkerAliGenie.brightness(colorW);
      default :
      void aligenieColor(const String & color)
        BLINKER_LOG("need set color: ", color);
        if (color == "Red") {
            colorR = 255; colorG = 0; colorB = 0;
        else if (color == "Yellow") {
            colorR = 255; colorG = 255; colorB = 0;
        else if (color == "Blue") {
            colorR = 0; colorG = 0; colorB = 255;
        else if (color == "Green") {
            colorR = 0; colorG = 255; colorB = 0;
        else if (color == "White") {
            colorR = 255; colorG = 255; colorB = 255;
        else if (color == "Black") {
            colorR = 0; colorG = 0; colorB = 0;
        else if (color == "Cyan") {
            colorR = 0; colorG = 255; colorB = 255;
        else if (color == "Purple") {
            colorR = 128; colorG = 0; colorB = 128;
        else if (color == "Orange") {
            colorR = 255; colorG = 165; colorB = 0;
        LightShow();
        BlinkerAliGenie.color(color);
    void aligenieBright(const String & bright)
        BLINKER_LOG("need set brightness: ", bright);
        if (bright == BLINKER_CMD_MAX) {
            colorW = 255;
        else if (bright == BLINKER_CMD_MIN) {
            colorW = 0;
        else {
            colorW = bright.toInt();
        BLINKER_LOG("now set brightness: ", colorW);
        LightShow();
        Blinker.print(BlinkerTime);
    String getcolor(){
      uint32_t color = colorR << 16 | colorG << 8 | colorB;
        switch (color)
            case 0xFF0000 :
                return "Red";
            case 0xFFFF00 :
                return "Yellow";
            case 0x0000FF :
                return "Blue";
            case 0x00FF00 :
                return "Green";
            case 0xFFFFFF :
                return "White";
            case 0x000000 :
                return "Black";
            case 0x00FFFF :
                return "Cyan";
            case 0x800080 :
                return "Purple";
            case 0xFFA500 :
                return "Orange";
            default :
                return "White";
      pinMode(ledR,OUTPUT);
      pinMode(ledG,OUTPUT);
      pinMode(ledB,OUTPUT);
      pinMode(ledbright,OUTPUT);
      colorR=255;
      colorG=255;
      colorB=255;
      colorW=100;
      LightShow();
      Blinker.begin(auth,ssid,pswd);
      BlinkerAliGenie.attachBrightness(aligenieBright);
      BlinkerAliGenie.attachColor(aligenieColor);
      BlinkerAliGenie.attachPowerState(aligeniePowerState);
      BlinkerAliGenie.attachQuery(aligenieQuery);
      Blinker.attachData(dataRead);
    void loop(){
      LightShow();
    发表于 2019-6-9 01:41 | 显示全部楼层
    同时读取两个传感器的数据,并上传至云端存储
    同时读取两个传感器的数据
    一个示例,仅供参考,可以自己更换传感器,或者连接更多传感器。 开发板: Wifiduin
    求助帖 新手
    求助帖 新手
    如图,第一个LED灯驱动失败,求原因… 板子是UNO R3,LED灯接在13与GND上面。
    【Arduino】108种传感器系列实验(93)---CSR8350蓝牙音乐模块
    【Arduino】108种传感器系
    光线跟踪钛合金猫眼
    光线跟踪钛合金猫眼
    +视频 https://www.bilibili.com/video/av67732712/ +原理 ---光线跟踪 建立极
    "高精度"米家电子温湿度计Pro拆解
    "高精度"米家电子温湿度计
    为了了解哪种温湿度传感器更好,我搞了一个米家电子温湿度计Pro(阿蒙同志赠送) 价格
