楼主 |
发表于 2022-12-4 08:59
显示全部楼层
项目之四十一:Arduino 矩阵显示代码
- 【Arduino】168种传感器模块系列实验(资料代码+仿真编程+图形编程)
- 实验二十二:MAX7219点阵显示模块(8X8 LED共阴)
- 项目之四十一:Arduino 矩阵显示代码
- //We always have to include the library
- #include "LedControl.h"
- Now we need a LedControl to work with.
- ***** These pin numbers will probably not work with your hardware *****
- pin 12 is connected to the DataIn
- pin 11 is connected to the CLK
- pin 10 is connected to LOAD
- We have only a single MAX72XX.
- LedControl lc=LedControl(12,11,10,1);
- /* we always wait a bit between updates of the display */
- unsigned long delaytime=100;
- void setup() {
- The MAX72XX is in power-saving mode on startup,
- we have to do a wakeup call
- lc.shutdown(0,false);
- /* Set the brightness to a medium values */
- lc.setIntensity(0,8);
- /* and clear the display */
- lc.clearDisplay(0);
- This method will display the characters for the
- word "Arduino" one after the other on the matrix.
- (you need at least 5x7 leds to see the whole chars)
- void writeArduinoOnMatrix() {
- /* here is the data for the characters */
- byte a[5]={B01111110,B10001000,B10001000,B10001000,B01111110};
- byte r[5]={B00111110,B00010000,B00100000,B00100000,B00010000};
- byte d[5]={B00011100,B00100010,B00100010,B00010010,B11111110};
- byte u[5]={B00111100,B00000010,B00000010,B00000100,B00111110};
- byte i[5]={B00000000,B00100010,B10111110,B00000010,B00000000};
- byte n[5]={B00111110,B00010000,B00100000,B00100000,B00011110};
- byte o[5]={B00011100,B00100010,B00100010,B00100010,B00011100};
- /* now display them one by one with a small delay */
- lc.setRow(0,0,a[0]);
- lc.setRow(0,1,a[1]);
- lc.setRow(0,2,a[2]);
- lc.setRow(0,3,a[3]);
- lc.setRow(0,4,a[4]);
- delay(delaytime);
- lc.setRow(0,0,r[0]);
- lc.setRow(0,1,r[1]);
- lc.setRow(0,2,r[2]);
- lc.setRow(0,3,r[3]);
- lc.setRow(0,4,r[4]);
- delay(delaytime);
- lc.setRow(0,0,d[0]);
- lc.setRow(0,1,d[1]);
- lc.setRow(0,2,d[2]);
- lc.setRow(0,3,d[3]);
- lc.setRow(0,4,d[4]);
- delay(delaytime);
- lc.setRow(0,0,u[0]);
- lc.setRow(0,1,u[1]);
- lc.setRow(0,2,u[2]);
- lc.setRow(0,3,u[3]);
- lc.setRow(0,4,u[4]);
- delay(delaytime);
- lc.setRow(0,0,i[0]);
- lc.setRow(0,1,i[1]);
- lc.setRow(0,2,i[2]);
- lc.setRow(0,3,i[3]);
- lc.setRow(0,4,i[4]);
- delay(delaytime);
- lc.setRow(0,0,n[0]);
- lc.setRow(0,1,n[1]);
- lc.setRow(0,2,n[2]);
- lc.setRow(0,3,n[3]);
- lc.setRow(0,4,n[4]);
- delay(delaytime);
- lc.setRow(0,0,o[0]);
- lc.setRow(0,1,o[1]);
- lc.setRow(0,2,o[2]);
- lc.setRow(0,3,o[3]);
- lc.setRow(0,4,o[4]);
- delay(delaytime);
- lc.setRow(0,0,0);
- lc.setRow(0,1,0);
- lc.setRow(0,2,0);
- lc.setRow(0,3,0);
- lc.setRow(0,4,0);
- delay(delaytime);
- This function lights up a some Leds in a row.
- The pattern will be repeated on every row.
- The pattern will blink along with the row-number.
- row number 4 (index==3) will blink 4 times etc.
- void rows() {
- for(int row=0;row<8;row++) {
- delay(delaytime);
- lc.setRow(0,row,B10100000);
- delay(delaytime);
- lc.setRow(0,row,(byte)0);
- for(int i=0;i<row;i++) {
- delay(delaytime);
- delay(delaytime);
- This function lights up a some Leds in a column.
- The pattern will be repeated on every column.
- The pattern will blink along with the column-number.
- column number 4 (index==3) will blink 4 times etc.
- void columns() {
- for(int col=0;col<8;col++) {
- delay(delaytime);
- lc.setColumn(0,col,B10100000);
- delay(delaytime);
- lc.setColumn(0,col,(byte)0);
- for(int i=0;i<col;i++) {
- delay(delaytime);
- delay(delaytime);
- This function will light up every Led on the matrix.
- The led will blink along with the row-number.
- void single() {
- delay(delaytime);
- lc.setLed(0,row,col,true);
- delay(delaytime);
- lc.setLed(0,row,col,false);
- delay(delaytime);
- delay(delaytime);
- void loop() {
- writeArduinoOnMatrix();
- rows();
- columns();
- single();
