[经验] 【Arduino】108种传感器模块系列实验(48)---三轴ADXL345模块
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 14:32 | 显示全部楼层
    模块的电原理图
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 15:38 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 15:40 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 15:42 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 16:09 | 显示全部楼层
    [mw_shl_code=arduino,true]/*
    【Arduino】66种传感器模块系列实验(48)
    实验四十八:GY-291 数字三轴重力加速度倾斜度模块 (IIC/SPI传输)
    简单实验,之一
    pinMode(A4, INPUT);
    pinMode(A5, INPUT);
    Serial.println(analogRead(A4));
    Serial.println(analogRead(A5));
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 16:13 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 16:59 | 显示全部楼层
    实验代码之二
    #include <Wire.h>
    #define DEVICE (0x53)
    #define TO_READ (6)
    byte buff[TO_READ] ;
    char str[512];
    int regAddress = 0x32;
    int x, y, z;
    double roll = 0.00, pitch = 0.00;
      Wire.begin();
      writeTo(DEVICE, 0x2D, 0);
      writeTo(DEVICE, 0x2D, 16);
      writeTo(DEVICE, 0x2D, 8);
      readFrom(DEVICE, regAddress, TO_READ, buff);
      x = (((int)buff[1]) << 8) | buff[0];
      y = (((int)buff[3])<< 8) | buff[2];
      z = (((int)buff[5]) << 8) | buff[4];
      //we send the x y z values as a string to the serial port
      Serial.print("The acceleration info of x, y, z are:");
      sprintf(str, "%d %d %d", x, y, z);
      Serial.print(str);
      Serial.write(10);
      RP_calculate();
      Serial.print("Roll:"); Serial.println( roll );
      Serial.print("Pitch:"); Serial.println( pitch );
      Serial.println("");
      delay(300);
    void writeTo(int device, byte address, byte val) {
      Wire.beginTransmission(device);
      Wire.write(address);
      Wire.write(val);
      Wire.endTransmission();
    void readFrom(int device, byte address, int num, byte buff[]) {
      Wire.requestFrom(device, num);
      int i = 0;
      while(Wire.available())
        buff = Wire.read();
        i++;
    void RP_calculate(){
      double x_Buff = float(x);
      double y_Buff = float(y);
      double z_Buff = float(z);
      roll = atan2(y_Buff , z_Buff) * 57.3;
      pitch = atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3;
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 17:01 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 17:04 | 显示全部楼层
    2020-8-15 12:53
  • 签到天数: 419 天
     楼主| 发表于 2019-7-5 17:07 | 显示全部楼层
    Arduino UNO中文数据手册
    Arduino UNO中文数据手册
    LabVIEW监控温度传感器
    LabVIEW监控温度传感器
    黑乌鸦的Arduino兵器库-----DS1302时钟模块
    黑乌鸦的Arduino兵器库---
    中文 字库 的8针 OLED 128
