查看: 1252|回复: 3
[已解答] 用arduino ide烧写esp8266 模块blinker固件出现问题
发表于 2019-7-14 22:53 | 显示全部楼层 |阅读模式
Arduino:1.8.9 (Windows 10), 开发板:"Generic ESP8266 Module, 80 MHz, Flash, Disabled, ck, 26 MHz, 40MHz, DOUT (compatible), 1M (144K SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,ResetMethod=ck,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M144,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_689121 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_788418 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Program Files (x86)\Arduino\libraries\blinker-library-master\examples\Blinker_AT_Firmware\AT_Firmware_WiFi\AT_Firmware_WiFi.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,ResetMethod=ck,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M144,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_689121 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_788418 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Program Files (x86)\Arduino\libraries\blinker-library-master\examples\Blinker_AT_Firmware\AT_Firmware_WiFi\AT_Firmware_WiFi.ino
Using board 'generic' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
Using core 'esp8266' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
构建选项已变更,全部重新构建
Detecting libraries used...
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266WiFi\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266HTTPClient\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\EEPROM" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\EEPROM" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\SoftwareSerial" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o nul
"-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\Hash\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\preproc\\ctags_target_for_gcc_minus_e.cpp"
正在编译项目...
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\generic" "-IC:\\Program Files (x86)\\Arduino\\libraries\\blinker-library-master\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\EEPROM" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\SoftwareSerial" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\Ticker" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\libraries\\Hash\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_689121\\sketch\\AT_Firmware_WiFi.ino.cpp.o"
In file included from C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTTAT.h:10:0,
                 from C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/Blinker.h:116,
                 from C:\Program Files (x86)\Arduino\libraries\blinker-library-master\examples\Blinker_AT_Firmware\AT_Firmware_WiFi\AT_Firmware_WiFi.ino:40:
C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTTAT.h: In member function 'void BlinkerMQTTAT::subscribe()':
C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTTAT.h:681:103: error: expected ',' or ';' before ')' token
             DeserializationError error = deserializeJson(jsonBuffer, (char *)iotSub_MQTT_AT->lastread));
C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTTAT.h: In member function 'virtual void BlinkerMQTTAT::sharers(const String&)':
C:\Program Files (x86)\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTTAT.h:1615:62: error: 'arrayData' was not declared in this scope
     DeserializationError error = deserializeJson(jsonBuffer, arrayData);
使用 0.3.2  版本的库 blinker-library-master 在文件夹: C:\Program Files (x86)\Arduino\libraries\blinker-library-master
使用 1.2  版本的库 ESP8266mDNS 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266mDNS
使用 1.0  版本的库 ESP8266WiFi 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266WiFi
使用 1.2  版本的库 ESP8266HTTPClient 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266HTTPClient
使用 1.0  版本的库 EEPROM 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\EEPROM
使用 1.0  版本的库 SoftwareSerial 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SoftwareSerial
使用 1.0  版本的库 Ticker 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Ticker
使用 1.3  版本的库 ESP8266httpUpdate 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266httpUpdate
使用 1.0  版本的库 Hash 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Hash
exit status 1
给位大佬,帮帮忙,小弟万谢
    发表于 2019-7-16 01:34 | 显示全部楼层
    在github更新最新的库,我这边测试是没问题的
     楼主| 发表于 2019-7-21 11:02 | 显示全部楼层
    好的,谢谢大佬
    发表于 2019-11-8 19:20 | 显示全部楼层
    楼主解决了吗,遇到模块也是烧录不了
    <ESP8266NodeMCU>网络连接问题
    基于机器视觉的智能分拣机械臂
    基于机器视觉的智能分拣机
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    blinker做的卧室灯开关发现一个问题
    blinker做的卧室灯开关发
