查看: 959|回复: 5
[未解决] nun+nrf24l01只接收3条信息就不接了
    2019-4-15 15:12
    发表于 2019-7-25 17:20 | 显示全部楼层 |阅读模式
    大概是这样用的uno 板子和nrf24l01无线模块,可以接收信息但是接收几条就没了,但是如果重启发射端设备就又可以接收几条
    2019-4-15 15:12
     楼主| 发表于 2019-7-25 17:25 | 显示全部楼层
    发送端代码
    Radio    Arduino
    CE    -> 9
    CSN   -> 10 (Hardware SPI SS)
    MOSI  -> 11 (Hardware SPI MOSI)
    MISO  -> 12 (Hardware SPI MISO)
    SCK   -> 13 (Hardware SPI SCK)
    IRQ   -> 3  (Hardware INT1)
    VCC   -> No more than 3.6 volts
    GND   -> GND
    #include <SPI.h>
    #include <NRFLite.h>
    const static uint8_t RADIO_ID = 1;
    const static uint8_t DESTINATION_RADIO_ID = 0;
    const static uint8_t PIN_RADIO_CE = 9;
    const static uint8_t PIN_RADIO_CSN = 10;
    const static uint8_t PIN_RADIO_IRQ = 3;
    NRFLite _radio;
    uint8_t _data;
    uint32_t _lastSendTime;
    volatile uint8_t _sendSucceeded, _sendFailed;
        if (!_radio.init(RADIO_ID, PIN_RADIO_CE, PIN_RADIO_CSN))
            Serial.println("Cannot communicate with radio");
            while (1);
        attachInterrupt(digitalPinToInterrupt(PIN_RADIO_IRQ), radioInterrupt, FALLING);
        if (millis() - _lastSendTime > 999)
            _lastSendTime = millis();
            _data++;
            Serial.print("Sending ");
            Serial.print(_data);
            _radio.startSend(DESTINATION_RADIO_ID, &_data, sizeof(_data));
        if (_sendSucceeded)
            _sendSucceeded = false;
            Serial.println("...Success");
        if (_sendFailed)
            _sendFailed = false;
            Serial.println("...Failed");
    void radioInterrupt()
        uint8_t txOk, txFail, rxReady;
        _radio.whatHappened(txOk, txFail, rxReady);
        if (txOk)
            _sendSucceeded = true;
        if (txFail)
            _sendFailed = true;
    2019-4-15 15:12
     楼主| 发表于 2019-7-25 17:26 | 显示全部楼层
    接收端代码
    Radio    Arduino
    CE    -> 9
    GND   -> GND
    #include <SPI.h>
    const static uint8_t RADIO_ID = 0;
    NRFLite _radio;
    volatile uint8_t _dataWasReceived;
            while (1);
        if (_dataWasReceived)
            _dataWasReceived = false;
            while (_radio.hasDataISR())
                uint8_t data;
                _radio.readData(&data);
                Serial.print("Received ");
                Serial.println(data);
        if (rxReady)
            _dataWasReceived = true;
    2019-4-15 15:12
     楼主| 发表于 2019-7-25 17:45 | 显示全部楼层
    接线也没接错
    2019-4-15 15:12
     楼主| 发表于 2019-7-25 23:00 | 显示全部楼层
    没人吗,我好像看到好多人都是这个问题,或者是接收不到
    2020-7-29 09:31
  • 签到天数: 204 天
    发表于 2019-7-26 23:57 | 显示全部楼层
    注释里面有一句:
    NO MORE THAN 3.6 VOLT!!!
    中文意思是不超过3.6伏!
    请注意模块电源输入是否接成了5V!!!
    如果是,改接3.3v!!!
    Arduino官方开发板购买
    Arduino官方开发板购买
    中文 字库 的8针 OLED 128
    ESP8266-01s网页配网+红外NEC学习固件
    ESP8266-01s网页配网+红外
    红外学习+html网页配网通用固件 硬件:esp8266-01s,红外发射二极管,红外接收头,50
