查看: 201|回复: 4
[已解决] wifiduino程序上传出错
发表于 2019-7-28 12:29 | 显示全部楼层 |阅读模式
希望大佬帮忙看下~
完整代码(就是根据Blinker技术文档里的实例略加修改)如下
#define BLINKER_PRINT Serial
#define BLINKER_WIFI
char auth[] = "625cfae33206";
char ssid[] = "CuMoon";
char pswd[] = "147532515117";
//设置电机控制引脚
int DIR1 = 4;        //棕
int PWM1 = 5;        //红
int PWM2 = 6;        //橙
int DIR2 = 7;        //黄
// 新建组件对象
int counter = 0;
// 按下按键即会执行该函数
    digitalWrite(DIR1,LOW);
    digitalWrite(DIR2,LOW);
    analogWrite(PWM1,255);
    analogWrite(PWM2,255);
    // 初始化串口
    #if defined(BLINKER_PRINT)
    #endif
    // 初始化有LED的IO
    pinMode(LED_BUILTIN, OUTPUT);
    // 初始化blinker
    Blinker.attachData(dataRead);
    pinMode(DIR1,OUTPUT);
    pinMode(PWM1,OUTPUT);
    pinMode(PWM2,OUTPUT);
    pinMode(DIR2,OUTPUT);
错误信息如下
Arduino:1.8.7 (Windows 10), 开发板:"WiFiduino, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
In file included from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTT.h:10:0,
                 from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker.h:36,
                 from C:\Users\璇歌憶淇綈\Desktop\Hello_WiFi\Hello_WiFi.ino:6:
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h: In member function 'virtual char* BlinkerMQTT::lastRead()':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:684:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     else return "";
In file included from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:82:0,
                 from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTT.h:11,
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApiBase.h: In member function 'char* BlinkerBridge_key::getName()':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApiBase.h:194:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 else return "false";
In file included from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:83:0,
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::deviceName()':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h:96:86: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
             char * deviceName() { if (isInit) return conn->deviceName(); else return ""; }
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::authKey()':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h:97:83: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
             char * authKey()    { if (isInit) return conn->authKey(); else return "";  }
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::dataParse()':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h:226:86: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         char* dataParse()       { if (canParse) return conn->lastRead(); else return ""; }
In file included from C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTT.h:11:0,
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: At global scope:
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:762:97: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         BlinkerWidgets_string _BUILTIN_SWITCH = BlinkerWidgets_string(BLINKER_CMD_BUILTIN_SWITCH);
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::bridgeKey(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6258:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::bridgeName(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6265:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_str(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6887:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     else return "";
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_rgb(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6901:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     else return "";
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_int(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6907:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     else return "";
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_tab(uint8_t)':
C:\Users\齐\Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:6913:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     else return "";
C:\Users\璇歌憶淇綈\Desktop\Hello_WiFi\Hello_WiFi.ino: At global scope:
C:\Users\璇歌憶淇綈\Desktop\Hello_WiFi\Hello_WiFi.ino:20:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\璇歌憶淇綈\Desktop\Hello_WiFi\Hello_WiFi.ino:21:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\璇歌憶淇綈\Desktop\Hello_WiFi\Hello_WiFi.ino: In function 'void setup()':
Hello_WiFi:48:24: error: 'dataRead' was not declared in this scope
exit status 1
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
    2019-8-23 00:00
  • 签到天数: 26 天
    发表于 2019-7-28 12:51 | 显示全部楼层
    dataRead没有声明是什么,你可以去掉或写个dataRead函数 看文档吧
    发表于 2019-7-28 12:52 | 显示全部楼层
    翻译过来的意思:
    你程序中没有定义dataRead
    建议按照blinker文档教程学习,理解后,再自由发挥
     楼主| 发表于 2019-7-28 13:34 | 显示全部楼层
    是4567引脚不能用吗?
    6、7不行  详情 回复 发表于 2019-7-28 18:34
    发表于 2019-7-28 18:34 | 显示全部楼层
    abcd2019 发表于 2019-7-28 13:34
    是4567引脚不能用吗?
    6、7不行
    可见:
    https://wifiduino.com/
    一直显示'Serial' was not declared in this scope,求前辈解答谢谢
    一直显示'Serial'
    做了一个温控装置的蓝牙模块时遇到的问题,
    【Arduino】108种传感器模块系列实验(97)---0.96寸OLED液晶屏
    【Arduino】108种传感器模
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    教你让OLED动起来!多重字符串版!
    教你让OLED动起来!多重字
