查看: 693|回复: 5
[分享] 用blinker做一个可调速的RGB笔记本散热风扇
    2019-10-21 16:33
  • 签到天数: 9 天
    发表于 2019-8-1 23:30 | 显示全部楼层 |阅读模式
           首先我们用到的材料有 arduino nano、蓝牙模块、da大功率mos管模块、散热风扇、ws2812b灯带\DC-DC电源等材料。
    说一下思路,风扇通过大功率mos管控制进风量,手机通过蓝牙控制风扇的转速以及灯带的颜色。
    引脚接法:
    arduino -----  蓝牙
    11-----  TX
    12-----  RX
    GND-----  GND
    VCC----- VCC
    arduino -----ws2812b灯带
    4-----DIN
    GND-----GND
    外接电源+-----VCC
    arduino -----大功率mos管模块
    GND-----GND
    3-----pwm+
    DC+和DC-接电源输入
    OUT+和OUT-接风扇
    (注:风扇和灯带的电源推荐用外接电源,不然电流不稳定会影响arduino正常工作)
    手机端设置:
    Screenshot_2019-08-01-23-20-51-156_iot.clz.me.jpg Screenshot_2019-08-01-23-25-59-674_iot.clz.me.jpg Screenshot_2019-08-01-23-26-02-644_iot.clz.me.jpg
    代码如下:
    #define BLINKER_PRINT    Serial
    #define BLINKER_BLE
    #include <PWM.h>
    #ifdef __AVR__
    #include <avr/power.h>
    #endif
    #define PIN            4   //ws2812b灯带引脚
    #define NUMPIXELS      16  //灯珠数量
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
    #define RGB_1 "RGBKey"
    BlinkerSlider Slider1("fan");
    BlinkerRGB RGB1(RGB_1);
    void slider1_callback(int32_t value1)
        BLINKER_LOG("get slider value: ", value1);
        OCR2B = value1; //Toggle value B, Output at pin 3
    void rgb1_callback(uint8_t r_value, uint8_t g_value, uint8_t b_value, uint8_t bright_value)
        BLINKER_LOG("R value: ", r_value);
        BLINKER_LOG("G value: ", g_value);
        BLINKER_LOG("B value: ", b_value);
        BLINKER_LOG("Rrightness value: ", bright_value);
        uint8_t colorR = map(r_value, 0, 255, 0, bright_value);
        uint8_t colorG = map(g_value, 0, 255, 0, bright_value);
        uint8_t colorB = map(b_value, 0, 255, 0, bright_value);
        for(int i = 0; i < NUMPIXELS; i++)
          pixels.setPixelColor(i, pixels.Color(colorR,colorG,colorB));
          pixels.show();
        #if defined(BLINKER_PRINT)
        #endif
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.begin(11, 12);//设置数字IO口11(RX)12(TX)这两个脚接蓝牙TX RX
        pixels.begin();
        Slider1.attach(slider1_callback);
        RGB1.attach(rgb1_callback);
        InitTimersSafe();
        pinMode(3, OUTPUT);  //风扇引脚
        TCCR2A = _BV(COM2A0) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); //Set Timer2 to varying top limit fast PWM mode
        // TCCR2B = _BV(WGM22) | _BV(CS22) | _BV(CS21) | _BV(CS20);//another way to set prescaler CS2=fff
        TCCR2B = TCCR2B & 0b11111000 | 0x01;
        OCR2A = 255;
        OCR2B = 10;
    //  Serial.println(i);
    2019-10-21 16:33
  • 签到天数: 9 天
     楼主| 发表于 2019-8-1 23:44 | 显示全部楼层
    给大家看一下制作过程中的图片吧
    制作过程中换了很多方案主要是换了风扇,换了控制风扇的元器件。
    成品图没怎么拍照,只找到一张。
    63D7DF8B8F6475328DA7F7A158AB8612.jpg ED4DB3AC0EEC4B9413386E138A149739.jpg 599128DA5A3997B7B4C9F3BF9F8E45F7.jpg 3260CAC983EB7E775A7523D93BBEB84F.jpg 9A7F6D9041C31EAF1A8776BDEB6A08D3.jpg
    2020-1-26 21:32
  • 签到天数: 125 天
    发表于 2019-8-1 23:45 | 显示全部楼层
    有成品图片不?
    放上来欣赏欣赏~
    2019-10-21 16:33
  • 签到天数: 9 天
     楼主| 发表于 2019-8-1 23:47 | 显示全部楼层
    Creeper666 发表于 2019-8-1 23:45
    有成品图片不?
    放上来欣赏欣赏~
    刚刚上传,
    2019-10-21 16:33
  • 签到天数: 9 天
     楼主| 发表于 2019-8-2 00:05 | 显示全部楼层
    刚刚把它拆开拍了几张照片 0F4E0BEC07A0EEA6435C7D8DBDCBEC16.jpg 33F8EE8B91B52C4DAC63611C2BCDF5E5.jpg 9A721663113B9173502653150BBEAECD.jpg 69B194FB0B106DB71B9EF0BA049171DE.jpg F0B469B34AD65D3737D514BE7B518546.jpg
    2019-10-21 16:33
  • 签到天数: 9 天
     楼主| 发表于 2019-8-2 00:06 | 显示全部楼层
    欢迎大家来交流
    哪位高手帮帮忙呀用UNO主板控制垃圾分类
    哪位高手帮帮忙呀用UNO主
    打砖块游戏
    打砖块游戏
    **** 本内容被作者隐藏 ****
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    arduino Micro
    arduino Micro
    1、micro概述 Micro是一款基于ATmega32U4的微控制器板,与Adafruit共同开发 。
