查看: 1041|回复: 2
[已解答] 存储EEPROM的问题
    2019-7-26 21:20
  • 签到天数: 4 天
    发表于 2019-8-3 08:16 | 显示全部楼层 |阅读模式
    [mw_shl_code=arduino,true]/* *****************************************************************
    * Download latest Blinker library here:
    * https://github.com/blinker-iot/blinker-library/archive/master.zip
    * Blinker is a cross-hardware, cross-platform solution for the IoT.
    * It provides APP, device and server support,
    * and uses public cloud services for data transmission and storage.
    * It can be used in smart home, data monitoring and other fields
    * to help users build Internet of Things projects better and faster.
    * Make sure installed 2.5.0 or later ESP8266/Arduino package,
    * if use ESP8266 with Blinker.
    * https://github.com/esp8266/Arduino/releases
    * Make sure installed 1.0.2 or later ESP32/Arduino package,
    * if use ESP32 with Blinker.
    * https://github.com/espressif/arduino-esp32/releases
    * Docs: https://doc.blinker.app/
    *       https://github.com/blinker-iot/blinker-doc/wiki
    * Blinker 库下载地址:
    * Blinker 是一套跨硬件、跨平台的物联网解决方案,提供APP端、设备端、
    * 服务器端支持,使用公有云服务进行数据传输存储。可用于智能家居、
    * 数据监测等领域,可以帮助用户更好更快地搭建物联网项目。
    * 如果使用 ESP8266 接入 Blinker,
    * 请确保安装了 2.5.0 或更新的 ESP8266/Arduino 支持包。
    * 如果使用 ESP32 接入 Blinker,
    * 请确保安装了 1.0.2 或更新的 ESP32/Arduino 支持包。
    * 文档: https://doc.blinker.app/
    #define BLINKER_WIFI
    char auth[] = "aaa";
    char ssid[] = "bbb";
    char pswd[] = "ccc";
    int AK4 = 0;
    #define BUTTON_1 "ButtonKey"
        if (state == BLINKER_CMD_BUTTON_TAP) {
            BLINKER_LOG("Button tap!");
            Button1.icon("icon_1");
            Button1.color("#FFFFFF");
            Button1.text("Your button name or describe");
            Button1.print();
            AK4 = 1;
        else if (state == BLINKER_CMD_BUTTON_PRESSED) {
            BLINKER_LOG("Button pressed!");
            Button1.print();
            AK4 = 1;
        else if (state == BLINKER_CMD_BUTTON_RELEASED) {
            BLINKER_LOG("Button released!");
            // Button1.text("Your button name", "describe");
            Button1.print();
            AK4 = 1;
        else if (state == BLINKER_CMD_ON) {
            BLINKER_LOG("Toggle on!");
            Button1.print("on");
            AK4 = 1;
            BLINKER_LOG("Toggle off!");
            Button1.print("off");
            AK4 = 1;
        else {
            BLINKER_LOG("Get user setting: ", state);
            Button1.print();
            AK4 = 1;
        Blinker.vibrate();
        BLINKER_DEBUG.stream(Serial);
        BLINKER_DEBUG.debugAll();//开启调试,你可以在串口监视器中看到相应信息。
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.attachData(dataRead);
        EEPwrite();
    void EEPwrite(){
    if (AK4 == 1){
    EEPROM.begin(4096);
    for(int a = 0;a<6;a++){
      EEPROM.write( a+3000,a);
    for(int a = 0;a<4;a++){
      EEPROM.write( a+3006,a);
      EEPROM.commit();
      AK4 = 0;
    每次按按键就会储存下参数,
    但是按了就死机重启 。
    原来用不是认证版的不会重启的!
    [mw_shl_code=arduino,true][75201] parse data: {"ButtonKey":"tap"}
    [75201] defined BLINKER_ARDUINOJSON
    [75202] strWidgetsParse isParsed
    [75202] strWidgetsParse: ButtonKey
    [75203] get button state: tap
    [75206] Button tap!
    [75208] autoFormatData key: ButtonKey, json: "ButtonKey":{"ico":"icon_1","clr":"#FFFFFF","tex":"Your button name or describe"}
    [75219] new.
    [75220] isParsed
    Abort called
    >>>stack>>>
    ctx: cont
    sp: 3ffffdb0 end: 3fffffc0 offset: 01b0
    3fffff60:  feefeffe 3fff0378 3fff0e08 402282b4
    3fffff70:  0000df47 00000000 00000000 4021d000
    3fffff80:  00000000 3fff0e08 3fff0f40 402039ae
    3fffff90:  3fffdad0 00000000 3fff0f40 40210503
    3fffffa0:  3fffdad0 00000000 3fff0f40 4021ec8c
    3fffffb0:  feefeffe feefeffe 3ffe8590 40100b05
    <<<stack<<<
    last failed alloc call: 402282E4(4096)
    ets Jan  8 2013,rst cause:2, boot mode1,0)
    ets Jan  8 2013,rst cause:4, boot mode1,0)
    wdt reset
    [/mw_shl_code]
    发表于 2019-8-3 12:45 | 显示全部楼层
    经测试,最新blinker lib+ 2.5.2 8266 package,表现正常,因此该问题应该不是软件方面问题
    2019-10-30 20:54
    发表于 2019-11-21 11:22 | 显示全部楼层
    我也到这样的的问题,怎么解决?
    ESP8266电池供电如何接线?
    ESP8266电池供电如何接线
    【教程】论如何通过经典Arduino UNO主控开发小型电子模块?
    【教程】论如何通过经典Ar
    大家好,这里是我们工作室出的第一个关于Arduino的视频教程,希望大家可以喜欢 非转载
