查看: 997|回复: 11
[已解答] arduino due 无法编译程序
    2019-8-15 00:55
    发表于 2019-8-13 22:07 | 显示全部楼层 |阅读模式
    我在做一个灵感来自于3D打印机的起重机,想用blinker控制电机和舵机,蓝牙ble接入,同样程序在uno上可以编译上传,但是在due上无法编译,我看论坛有人说是编程器的问题,换了编程器还是不行,迷……
    代码如下:
    #define BLINKER_BLE
    #define ENA_one 3
    #define in1_one 2
    #define in2_one 4
    #define ENA_two 5
    #define in3_two 7
    #define in4_two 8
    #define ENA_three 6
    #define in1_three 10
    #define in2_three 11
    #define ENA_four 9
    #define in3_four 12
    #define in4_four 13
    BlinkerButton Button2("btn-fic");
    BlinkerButton Button3("btn-01g");
    BlinkerButton Button4("btn-8xa");
    BlinkerButton Button5("btn-d91");
    BlinkerButton Button6("btn-oy9");
    BlinkerButton Button7("btn-574");
    BlinkerButton Button8("btn-o2j");
    BlinkerButton Button9("btn-bf1");
    BlinkerButton Button10("btn-or9");
    int counter = 0;
    int sudu=100;
    int suduxie=120;
    int suduweitiao=111;
    int suduxieweitiao=131;
    void forward();
    void backward();
    void _stop();
    //void fanzhuan();
    void dianjichushihua();
    void nishizheng();
    void shunshizheng();
    void left();
    void right();
    void zuoshang();
    void youxia();
    void zuoxia();
    void youshang();
    void button1_callback(const String & state);
    void button2_callback(const String & state);
    void button3_callback(const String & state);
    void button4_callback(const String & state);
    void button5_callback(const String & state);
    void button6_callback(const String & state);
    void button7_callback(const String & state);
    void button8_callback(const String & state);
    void button9_callback(const String & state);
    void button10_callback(const String & state);
        counter++;
        Number1.print(counter);
        BLINKER_DEBUG.stream(Serial);
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.begin(A1,A0);
        Blinker.attachData(dataRead);
        Button4.attach(button4_callback);
        Button5.attach(button5_callback);
        Button6.attach(button6_callback);
        Button7.attach(button7_callback);
        Button8.attach(button8_callback);
        Button9.attach(button9_callback);
        Button10.attach(button10_callback);
        dianjichushihua();
    //………………………………………………函数定义……………………………………
      pinMode(ENA_one,OUTPUT);
      pinMode(in1_one,OUTPUT);
      pinMode(in2_one,OUTPUT);
      pinMode(ENA_two,OUTPUT);
      pinMode(in3_two,OUTPUT);
      pinMode(in4_two,OUTPUT);
      //pinMode(xinhao_two,INPUT);
      pinMode(ENA_three,OUTPUT);
      pinMode(in1_three,OUTPUT);
      pinMode(in2_three,OUTPUT);
      //pinMode(xinhao_three,INPUT);
      pinMode(ENA_four,OUTPUT);
      pinMode(in3_four,OUTPUT);
      pinMode(in4_four,OUTPUT);
      //pinMode(xinhao_four,INPUT);
    void _stop()
      analogWrite(ENA_one,0);
      digitalWrite(in1_one,HIGH);
      digitalWrite(in2_one,LOW);
      analogWrite(ENA_two,0);
      digitalWrite(in3_two,HIGH);
      digitalWrite(in4_two,LOW);
      analogWrite(ENA_three,0);
      digitalWrite(in1_three,HIGH);
      digitalWrite(in2_three,LOW);
      analogWrite(ENA_four,0);
      digitalWrite(in3_four,HIGH);
      digitalWrite(in4_four,LOW);
    void fanzhuan()
      analogWrite(ENA,sudu);
    void forward()
      analogWrite(ENA_one,suduweitiao);
      digitalWrite(in1_one,LOW);
      digitalWrite(in2_one,HIGH);
      analogWrite(ENA_two,suduweitiao);
      digitalWrite(in3_two,LOW);
      digitalWrite(in4_two,HIGH);
      analogWrite(ENA_three,sudu);
      analogWrite(ENA_four,sudu);
    void nishizheng()
      digitalWrite(in1_three,LOW);
      digitalWrite(in2_three,HIGH);
      digitalWrite(in3_four,LOW);
      digitalWrite(in4_four,HIGH);
      void shunshizheng()
      void backward()
        void left()
    void right()
      void zuoshang()
        analogWrite(ENA_one,suduxieweitiao);
      analogWrite(ENA_four,suduxie);
      void youxia()
      void youshang()
      analogWrite(ENA_two,suduxieweitiao);
      analogWrite(ENA_three,suduxie);
        void zuoxia()
        //digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
        if (state == BLINKER_CMD_BUTTON_PRESSED) {
            BLINKER_LOG("Button pressed!");
            //Button1.icon("icon_1");
            Button1.color("#FFFFFF");
            Button1.text("前进");
            // Button1.text("Your button name", "describe");
            Button1.print();
            //电机程序
            forward();
        else if (state == BLINKER_CMD_BUTTON_RELEASED) {
            BLINKER_LOG("Button released!");
            Button1.color("#00FF00");
            Button1.text("前进");
            Button1.print();
            _stop();
          Button1.print();
            Button2.text("后退");
            //电机程序
            backward();
            Button2.print();
            _stop();
          Button2.print();
            Button3.text("向左");
            //电机程序
            left();
            Button3.print();
            _stop();
          Button3.print();
            Button4.text("向右");
            //电机程序
            right();
            Button4.print();
            _stop();
          Button4.print();
            Button5.text("左上");
            //电机程序
            zuoshang();
            Button5.print();
            _stop();
          Button5.print();
            Button6.text("右上");
            //电机程序
            youshang();
            Button6.print();
            _stop();
          Button6.print();
            Button7.text("左下");
            //电机程序
            zuoxia();
            Button7.print();
            _stop();
          Button7.print();
            Button8.text("右下");
            //电机程序
            youxia();
            Button8.print();
            _stop();
          Button8.print();
            Button9.text("顺时针");
            //电机程序
            shunshizheng();
            Button9.print();
            _stop();
          Button9.print();
            Button10.text("逆时针");
            //电机程序
            nishizheng();
            Button10.print();
            _stop();
          Button10.print();
    2019-8-15 00:55
     楼主| 发表于 2019-8-14 20:26 | 显示全部楼层
    Arduino:1.8.9 (Windows 10), 开发板:"Arduino Due (Programming Port)"
    In file included from C:\Users\Handsome BF\Desktop\����͹���\arduinoIDE-1.8.9\libraries\blinker-library-master\src/BlinkerSerialBLE.h:4:0,
                     from C:\Users\Handsome BF\Desktop\����͹���\arduinoIDE-1.8.9\libraries\blinker-library-master\src/Blinker.h:21,
                     from C:\Users\Handsome BF\Documents\Arduino\blinker_dipan_uno\blinker_dipan_uno.ino:22:
    C:\Users\Handsome BF\Desktop\����͹���\arduinoIDE-1.8.9\libraries\blinker-library-master\src/Adapters/BlinkerSerial.h:21:32: fatal error: SoftwareSerial.h: No such file or directory
         #include <SoftwareSerial.h>
    compilation terminated.
    exit status 1
    为开发板 Arduino Due (Programming Port) 编译时出错。
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    发表于 2019-8-14 22:04 | 显示全部楼层
    用硬件串口
    2019-8-15 00:55
     楼主| 发表于 2019-8-15 00:39 | 显示全部楼层
    已改为RX1,TX1(19,18),依然报错,而且我uno用的也是软串口
    C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\hardware -hardware C:\Users\Handsome BF\AppData\Local\Arduino15\packages -tools C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\tools-builder -tools C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\hardware\tools\avr -tools C:\Users\Handsome BF\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\libraries -libraries C:\Users\Handsome BF\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -vid-pid=0X2341_0X003D -ide-version=10809 -build-path C:\Users\HANDSO~1\AppData\Local\Temp\arduino_build_286104 -warnings=none -build-cache C:\Users\HANDSO~1\AppData\Local\Temp\arduino_cache_843601 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\Handsome BF\Documents\Arduino\blinker_dipan_uno\blinker_dipan_uno.ino
    C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\arduino-builder -compile -logger=machine -hardware C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\hardware -hardware C:\Users\Handsome BF\AppData\Local\Arduino15\packages -tools C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\tools-builder -tools C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\hardware\tools\avr -tools C:\Users\Handsome BF\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\libraries -libraries C:\Users\Handsome BF\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -vid-pid=0X2341_0X003D -ide-version=10809 -build-path C:\Users\HANDSO~1\AppData\Local\Temp\arduino_build_286104 -warnings=none -build-cache C:\Users\HANDSO~1\AppData\Local\Temp\arduino_cache_843601 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\Handsome BF\Documents\Arduino\blinker_dipan_uno\blinker_dipan_uno.ino
    Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
    Using core 'arduino' from platform in folder: C:\Users\Handsome BF\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
    Detecting libraries used...
    "C:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10809 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\HANDSO~1\\AppData\\Local\\Temp\\arduino_build_286104\\sketch\\blinker_dipan_uno.ino.cpp" -o nul
    "C:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10809 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\Handsome BF\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\Handsome BF\\Desktop\\程序和工具\\arduinoIDE-1.8.9\\libraries\\blinker-library-master\\src" "C:\\Users\\HANDSO~1\\AppData\\Local\\Temp\\arduino_build_286104\\sketch\\blinker_dipan_uno.ino.cpp" -o nul
                     from C:\Users\Handsome BF\Documents\Arduino\blinker_dipan_uno\blinker_dipan_uno.ino:21:
    使用 0.3.2  版本的库 blinker-library-master 在文件夹: C:\Users\Handsome BF\Desktop\程序和工具\arduinoIDE-1.8.9\libraries\blinker-library-master
    exit status 1
    1544106114
    发表于 2019-8-15 11:45 | 显示全部楼层
    更新最新的库 已添加DUE可用的代码
    2019-8-15 00:55
     楼主| 发表于 2019-8-15 13:15 | 显示全部楼层
    三水 发表于 2019-8-15 11:45
    更新最新的库 已添加DUE可用的代码
    上传成功了,太感谢了,感谢两位大佬
    2019-8-15 00:55
     楼主| 发表于 2019-8-15 15:33 | 显示全部楼层
    更新最新的库 已添加DUE可用的代码
    又有新问题了,设备跟app无法连接
    2019-8-15 00:55
     楼主| 发表于 2019-8-15 15:49 | 显示全部楼层
    包包大人666123 发表于 2019-8-15 15:33
    又有新问题了,设备跟app无法连接
    连接不正常
    1544106114
    发表于 2019-8-15 17:19 | 显示全部楼层
    1. app是否能发现蓝牙
    2. 如果app能发现蓝牙,debug all 看调试信息
    【原创】 drawbot平面关节
    error:'UTFT' does not mame a type这个错在那里?
    error:'UTFT' doe
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    哪种按钮传感器可以适用我的arduino装置
    哪种按钮传感器可以适用我
    我想做大概12个按钮并联的这么一个装置,具体交互行为如下:按一次按钮通过mp3模块发
