查看: 795|回复: 2
各位大侠,求帮找一下因为什么崩溃,折磨死我啦。
发表于 2019-8-14 16:28 | 显示全部楼层 |阅读模式
用EPS8266 NODEMCU 搞了一个用MQTT将数据上传阿里云的小玩意,数据只能上传一次就崩溃然后重新开始初始化
代码如下:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <aliyun_mqtt.h>
#define WIFI_SSID "XXX"
#define WIFI_PASSWD "XXX"
#define PRODUCT_KEY "XXX"
#define DEVICE_NAME "GL_SOHO_NO37_3F_1"
#define DEVICE_SECRET "XXXX"
#define ALINK_BODY_FORMAT "{\"id\":\"123\",\"version\":\"1.0\",\"method\":\"%s\",\"params\":%s}"
#define ALINK_TOPIC_PROP_POST "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post"
#define ALINK_TOPIC_PROP_POSTRSP "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post_reply"
#define ALINK_TOPIC_PROP_SET "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/service/property/set"
#define ALINK_METHOD_PROP_POST "thing.event.property.post"
unsigned long lastMs = 0;
WiFiClient espClient;
PubSubClient mqttClient(espClient);
void initWifi(const char *ssid, const char *password)
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.println("WiFi does not connect, try again ...");
    delay(3000);
  Serial.println("Wifi is connected.");
void callback(char *topic, byte *payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  payload[length] = '\0';
  Serial.println((char *)payload);
  if (strstr(topic, ALINK_TOPIC_PROP_SET))
    StaticJsonBuffer<100> jsonBuffer;
    JsonObject &root = jsonBuffer.parseObject(payload);
    if (!root.success())
      Serial.println("parseObject() failed");
      return;
void mqttCheckConnect()
  while (!connectAliyunMQTT(mqttClient, PRODUCT_KEY, DEVICE_NAME, DEVICE_SECRET))
  Serial.println("MQTT connect succeed!");
  mqttClient.subscribe(ALINK_TOPIC_PROP_SET);
  Serial.println("subscribe done");
void mqttIntervalPost()
  char param[32], jsonBuf[128], str_temp[18], str_temp2[20];
  sprintf(param, "{\"mtemp\":%s}", "13.32");
  sprintf(jsonBuf, ALINK_BODY_FORMAT, ALINK_METHOD_PROP_POST, param);
  Serial.print("jsonBuf=");
  Serial.println(jsonBuf);
  mqttClient.publish(ALINK_TOPIC_PROP_POST, jsonBuf);
  Serial.println("");
  Serial.println("");
  Serial.println("Start......");
  initWifi(WIFI_SSID, WIFI_PASSWD);
  mqttClient.setCallback(callback);
  if (millis() - lastMs >= 5000)
    lastMs = millis();
    mqttCheckConnect();
    mqttIntervalPost();
MQTT_MAX_PACKET_SIZE=2048了还崩溃,不知道为什
崩溃图片
崩溃图片
    2020-7-1 09:10
  • 签到天数: 817 天
    [LV.10]以坛为家III
    发表于 2019-8-14 20:16 | 显示全部楼层
    喂狗啦 这个不能少
     楼主| 发表于 2019-8-14 21:54 | 显示全部楼层
        lastMs = millis();
        mqttCheckConnect();
        /* Post */
        ESP.wdtFeed();
        mqttIntervalPost();
        //ESP.restart()
        ESP.wdtFeed();
    无效,苦闷。。。
    求解用arduino 让WS2812全
    Arduino物联网开发实例教程
    Arduino物联网开发实例教
    萌新求助,小爱语音控制8266没有反应
    萌新求助,小爱语音控制82
    看了有大佬做的远程开机,就想自己试试,我用的是esp8266 nodemcu。程序烧进去以后,
