查看: 490|回复: 2
[未解决] DS3231库出了问题,不知怎么解决
    2020-1-26 00:05
  • 签到天数: 56 天
    发表于 2019-8-14 22:00 | 显示全部楼层 |阅读模式
    Arduino:1.8.9 (Windows Store 1.8.21.0) (Windows 10), 开发板:"WeMos D1 R1, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:22:0:
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:66:2: error: 'uint8_t' does not name a type
      uint8_t  hour;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:67:2: error: 'uint8_t' does not name a type
      uint8_t  min;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:68:2: error: 'uint8_t' does not name a type
      uint8_t  sec;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:69:2: error: 'uint8_t' does not name a type
      uint8_t  date;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:70:2: error: 'uint8_t' does not name a type
      uint8_t  mon;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:71:2: error: 'uint16_t' does not name a type
      uint16_t year;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:72:2: error: 'uint8_t' does not name a type
      uint8_t  dow;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:80:18: error: expected ')' before 'data_pin'
       DS3231(uint8_t data_pin, uint8_t sclk_pin);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:83:16: error: 'uint8_t' has not been declared
       void setTime(uint8_t hour, uint8_t min, uint8_t sec);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:83:30: error: 'uint8_t' has not been declared
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:83:43: error: 'uint8_t' has not been declared
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:84:16: error: 'uint8_t' has not been declared
       void setDate(uint8_t date, uint8_t mon, uint16_t year);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:84:30: error: 'uint8_t' has not been declared
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:84:43: error: 'uint16_t' has not been declared
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:86:15: error: 'uint8_t' has not been declared
       void setDOW(uint8_t dow);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:88:9: error: expected ';' at end of member declaration
       char *getTimeStr(uint8_t format=FORMAT_LONG);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:88:28: error: expected ')' before 'format'
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:89:9: error: expected ';' at end of member declaration
       char *getDateStr(uint8_t slformat=FORMAT_LONG, uint8_t eformat=FORMAT_LITTLEENDIAN, char divider='.');
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:89:28: error: expected ')' before 'slformat'
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:90:9: error: expected ';' at end of member declaration
       char *getDOWStr(uint8_t format=FORMAT_LONG);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:90:27: error: expected ')' before 'format'
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:91:9: error: expected ';' at end of member declaration
       char *getMonthStr(uint8_t format=FORMAT_LONG);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:91:29: error: expected ')' before 'format'
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:95:18: error: 'byte' has not been declared
       void setOutput(byte enable);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:100:3: error: 'uint8_t' does not name a type
       uint8_t _scl_pin;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:101:3: error: 'uint8_t' does not name a type
       uint8_t _sda_pin;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:102:3: error: 'uint8_t' does not name a type
       uint8_t _burstArray[7];
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:103:3: error: 'boolean' does not name a type
       boolean _use_hw;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:105:19: error: 'byte' has not been declared
       void _sendStart(byte addr);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:110:3: error: 'uint8_t' does not name a type
       uint8_t _readByte();
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:111:19: error: 'uint8_t' has not been declared
       void _writeByte(uint8_t value);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:113:3: error: 'uint8_t' does not name a type
       uint8_t _readRegister(uint8_t reg);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:114:24: error: 'uint8_t' has not been declared
       void  _writeRegister(uint8_t reg, uint8_t value);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:114:37: error: 'uint8_t' has not been declared
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:115:3: error: 'uint8_t' does not name a type
       uint8_t _decode(uint8_t value);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:116:3: error: 'uint8_t' does not name a type
       uint8_t _decodeH(uint8_t value);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:117:3: error: 'uint8_t' does not name a type
       uint8_t _decodeY(uint8_t value);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.h:118:3: error: 'uint8_t' does not name a type
       uint8_t _encode(uint8_t vaule);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:48:14: error: 'uint8_t' does not name a type
    static const uint8_t dim[] = { 31,28,31,30,31,30,31,31,30,31,30,31 };
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp: In constructor 'Time::Time()':
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:54:8: error: 'class Time' has no member named 'year'
      this->year = 2014;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:55:8: error: 'class Time' has no member named 'mon'
      this->mon  = 1;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:56:8: error: 'class Time' has no member named 'date'
      this->date = 1;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:57:8: error: 'class Time' has no member named 'hour'
      this->hour = 0;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:58:8: error: 'class Time' has no member named 'min'
      this->min  = 0;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:59:8: error: 'class Time' has no member named 'sec'
      this->sec  = 0;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:60:8: error: 'class Time' has no member named 'dow'
      this->dow  = 3;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp: At global scope:
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:63:15: error: expected constructor, destructor, or type conversion before '(' token
    DS3231:S3231(uint8_t data_pin, uint8_t sclk_pin)
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp: In member function 'Time DS3231::getTime()':
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:73:4: error: 'class Time' has no member named 'sec'
      t.sec = _decode(_burstArray[0]);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:73:18: error: '_burstArray' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:73:32: error: '_decode' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:74:4: error: 'class Time' has no member named 'min'
      t.min = _decode(_burstArray[1]);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:75:4: error: 'class Time' has no member named 'hour'
      t.hour = _decodeH(_burstArray[2]);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:75:34: error: '_decodeH' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:76:4: error: 'class Time' has no member named 'dow'
      t.dow = _burstArray[3];
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:77:4: error: 'class Time' has no member named 'date'
      t.date = _decode(_burstArray[4]);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:78:4: error: 'class Time' has no member named 'mon'
      t.mon = _decode(_burstArray[5]);
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:79:4: error: 'class Time' has no member named 'year'
      t.year = _decodeY(_burstArray[6])+2000;
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:79:34: error: '_decodeY' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:83:22: error: variable or field 'setTime' declared void
    void DS3231::setTime(uint8_t hour, uint8_t min, uint8_t sec)
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:83:22: error: 'uint8_t' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:83:36: error: 'uint8_t' was not declared in this scope
    C:\Users\16285\Documents\Arduino\libraries\DS3231\DS3231.cpp:83:49: error: 'uint8_t' was not declared in this scope
    exit status 1
    为开发板 WeMos D1 R1 编译时出错。
    // DS3231_Serial_Easy
    // Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
    // web: http://www.RinkyDinkElectronics.com/
    // A quick demo of how to use my DS3231-library to
    // quickly send time and date information over a serial link
    // To use the hardware I2C (TWI) interface of the Arduino you must connect
    // the pins as follows:
    // Arduino Uno/2009:
    // DS3231:  SDA pin   -> Arduino Analog 4 or the dedicated SDA pin
    //          SCL pin   -> Arduino Analog 5 or the dedicated SCL pin
    // Arduino Leonardo:
    // DS3231:  SDA pin   -> Arduino Digital 2 or the dedicated SDA pin
    //          SCL pin   -> Arduino Digital 3 or the dedicated SCL pin
    // Arduino Mega:
    // DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA pin
    //          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL pin
    // Arduino Due:
    // DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA1 (Digital 70) pin
    //          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL1 (Digital 71) pin
    // The internal pull-up resistors will be activated when using the
    // hardware I2C interfaces.
    // You can connect the DS3231 to any available pin but if you use any
    // other than what is described above the library will fall back to
    // a software-based, TWI-like protocol which will require exclusive access
    // to the pins used, and you will also have to use appropriate, external
    // pull-up resistors on the data and clock signals.
    #include <DS3231.h>
    // Init the DS3231 using the hardware interface
    DS3231  rtc(SDA, SCL);
      // Setup Serial connection
      // Uncomment the next line if you are using an Arduino Leonardo
      //while (!Serial) {}
      // Initialize the rtc object
      rtc.begin();
      // The following lines can be uncommented to set the date and time
      rtc.setDOW(WEDNESDAY);     // Set Day-of-Week to SUNDAY
      rtc.setTime(12, 0, 0);     // Set the time to 12:00:00 (24hr format)
      rtc.setDate(1, 1, 2014);   // Set the date to January 1st, 2014
      // Send Day-of-Week
      Serial.print(rtc.getDOWStr());
      Serial.print(" ");
      // Send date
      Serial.print(rtc.getDateStr());
      Serial.print(" -- ");
      // Send time
      Serial.println(rtc.getTimeStr());
      // Wait one second before repeating
      delay (1000);
    2020-1-26 00:05
  • 签到天数: 56 天
     楼主| 发表于 2019-8-14 22:28 | 显示全部楼层
    还没有解决
    2020-1-26 00:05
  • 签到天数: 56 天
     楼主| 发表于 2019-8-15 12:09 | 显示全部楼层
    哪位高手帮帮忙呀用UNO主板控制垃圾分类
    哪位高手帮帮忙呀用UNO主
    打砖块游戏
    打砖块游戏
    **** 本内容被作者隐藏 ****
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    arduino Micro
    arduino Micro
    1、micro概述 Micro是一款基于ATmega32U4的微控制器板,与Adafruit共同开发 。
