[经验] 【Arduino】108种传感器模块系列实验(105)---12位智能RGB彩环
 楼主| 发表于 2019-9-4 08:58 | 显示全部楼层
 楼主| 发表于 2019-9-4 09:33 | 显示全部楼层
[mw_shl_code=arduino,true]/*
1、安装库:IDE-工具-管理库-搜索Adafruit_NeoPixel-安装
2、项目:点亮环形LED模块,循环快闪绿色光
3、接脚:
VCC  → 5V
GND → GND
DI  接  D7
#define PIN 7
#define MAX_LED 12
#define ADD true
#define SUB false
int val = 0;
boolean stat = ADD;
Adafruit_NeoPixel strip = Adafruit_NeoPixel( MAX_LED, PIN, NEO_RGB + NEO_KHZ800 );
  strip.begin();
  strip.show();
  uint8_t i,a=0;
  uint32_t color = strip.Color(255, 100, 0);
  while(a<17)
      for(i=0;i<16;i++)
        if(i==a) strip.setPixelColor(i, color);
        else strip.setPixelColor(i, 0);
       strip.show();
       delay(20);
       a++;
 楼主| 发表于 2019-9-4 09:35 | 显示全部楼层
 楼主| 发表于 2019-9-4 11:33 | 显示全部楼层
2、项目:灯环显示彩色
3、接脚:
VCC  → 5V
GND → GND
DI  接  D7
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 7
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(64, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  //colorWipe(strip.Color(255, 0, 0), 50); // Red
// colorWipe(strip.Color(0, 255, 0), 50); // Green
  //colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
// theaterChase(strip.Color(127, 127, 127), 50); // White
  //theaterChase(strip.Color(127, 0, 0), 50); // Red
  //theaterChase(strip.Color(0, 0, 127), 50); // Blue
  rainbow(20);
  //rainbowCycle(20);
  //theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
}  [/mw_shl_code]
发表于 2019-9-4 11:44 | 显示全部楼层
好东西,可以做个时钟,用不同颜色显示时分秒
 楼主| 发表于 2019-9-4 11:57 | 显示全部楼层
2、项目:逐个点亮环形彩色LED
3、接脚:
VCC  → 5V
GND → GND
DI  接  D7
#include <FastLED.h>
#define LED_PIN     7
#define NUM_LEDS    12
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
  leds[0] = CRGB(255, 0, 0);
  FastLED.show();
  leds[1] = CRGB(0, 255, 0);
  FastLED.show();
  leds[2] = CRGB(0, 0, 255);
  FastLED.show();
  leds[3] = CRGB(150, 0, 255);
  FastLED.show();
  leds[4] = CRGB(255, 200, 20);
  FastLED.show();
  leds[5] = CRGB(85, 60, 180);
  FastLED.show();
  leds[6] = CRGB(150, 255, 20);
  FastLED.show();
  leds[7] = CRGB(0, 50, 255);
  FastLED.show();
  leds[8] = CRGB(255, 255, 0);
  FastLED.show();
  leds[9] = CRGB(20, 25, 255);
  FastLED.show();
  leds[10] = CRGB(255, 0, 20);
  FastLED.show();
  leds[11] = CRGB(50, 0, 55);
  FastLED.show();
 楼主| 发表于 2019-9-4 12:04 | 显示全部楼层
适合做时钟的有12灯,24灯还有60灯的
 楼主| 发表于 2019-9-4 12:56 | 显示全部楼层
2、项目:红蓝色快扫——这里第一个“for”循环点亮所有12个蓝色LED,
从第一个LED到最后一个LED,延迟40毫秒。 下一个“for”循环再
次点亮所有12个LED,但这次是红色,反之,从最后一个LED到第一个LED。
3、接脚:
VCC  → 5V
GND → GND
DI  接  D7
#define LED_PIN     7
#define NUM_LEDS    12
  for (int i = 0; i <= 11; i++) {
    leds = CRGB ( 0, 0, 255);
    FastLED.show();
    delay(60);
  for (int i = 11; i >= 0; i--) {
    leds = CRGB ( 255, 0, 0);
    FastLED.show();
    delay(40);
 楼主| 发表于 2019-9-4 13:06 | 显示全部楼层
2、项目:逐个点亮不同序列的LED(可设置为任何颜色)
3、接脚:
VCC  → 5V
GND → GND
DI  接  D7
#define LED_PIN     7
#define NUM_LEDS    12
  FastLED.show();
  FastLED.show();
  FastLED.show();
  leds[5] = CRGB(150, 0, 255);
  FastLED.show();
  leds[9] = CRGB(255, 200, 20);
  FastLED.show();
  leds[3] = CRGB(85, 60, 180);
  FastLED.show();
  leds[7] = CRGB(50, 255, 20);
  FastLED.show();
 楼主| 发表于 2019-9-4 14:09 | 显示全部楼层
GMT+8, 2022-12-2 04:35 , Processed in 0.076112 second(s), 15 queries .
