[经验] 【Arduino】108种传感器模块系列实验(110)---US-026超声波测距
签到天数: 506 天
 楼主| 发表于 2019-9-8 09:50 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 11:12 | 显示全部楼层
[mw_shl_code=arduino,true]/*
实验一百: AT-09蓝牙4.0BLE模块 串口引出 CC2541兼容HM-10 (BT05)
1、实验项目:US-025/US-026高精度测距例程
2、实验接脚:
EchoPin = D2
TrigPin = D3
GND = GND
VCC  = 5V
unsigned int EchoPin = 2;
unsigned int TrigPin = 3;
unsigned long Time_Echo_us = 0;
unsigned long Len_mm_X100 = 0;
unsigned long Len_Integer = 0;
unsigned int Len_Fraction = 0;
pinMode(EchoPin, INPUT);
pinMode(TrigPin, OUTPUT);
digitalWrite(TrigPin, HIGH);
delayMicroseconds(50);
digitalWrite(TrigPin, LOW);
Time_Echo_us = pulseIn(EchoPin, HIGH);
if((Time_Echo_us < 60000) && (Time_Echo_us > 1))
Len_mm_X100 = (Time_Echo_us*34)/2;
Len_Integer = Len_mm_X100/100;
Len_Fraction = Len_mm_X100%100;
Serial.print("Present Length is: ");
Serial.print(Len_Integer, DEC);
Serial.print(".");
if(Len_Fraction < 10)
Serial.print("0");
Serial.print(Len_Fraction, DEC);
Serial.println("mm");
签到天数: 506 天
 楼主| 发表于 2019-9-8 11:13 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 12:35 | 显示全部楼层
2、实验接脚:
EchoPin = D2
TrigPin  = D3
GND = GND
VCC  = 5V
unsigned int EchoPin = 2;           // connect Pin 2(Arduino digital io) to Echo at US-025/US-026
unsigned int TrigPin = 3;           // connect Pin 3(Arduino digital io) to Trig at US-025/US-026
unsigned long Len_mm  = 0;
{  //Initialize
    Serial.begin(9600);                        //Serial: output result to Serial monitor
    pinMode(EchoPin, INPUT);                    //Set EchoPin as input, to receive measure result from US-025,US-026
    pinMode(TrigPin, OUTPUT);                   //Set TrigPin as output, used to send high pusle to trig measurement (>10us)
    digitalWrite(TrigPin, HIGH);              //begin to send a high pulse, then US-025/US-026 begin to measure the distance
    delayMicroseconds(20);                    //set this high pulse width as 20us (>10us)
    digitalWrite(TrigPin, LOW);               //end this high pulse
    Time_Echo_us = pulseIn(EchoPin, HIGH);               //calculate the pulse width at EchoPin,
    if((Time_Echo_us < 60000) && (Time_Echo_us > 1))     //a valid pulse width should be between (1, 60000).
      Len_mm = (Time_Echo_us*34/100)/2;      //calculate the distance by pulse width, Len_mm = (Time_Echo_us * 0.34mm/us) / 2 (mm)
      Serial.print("Present Distance is: ");  //output result to Serial monitor
      Serial.print(Len_mm, DEC);            //output result to Serial monitor
      Serial.println("mm");                 //output result to Serial monitor
    delay(1000);                            //take a measurement every second (1000ms)
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:11 | 显示全部楼层
1、实验项目:用串口显示测出的距离值
2、实验接脚:
EchoPin = D2
TrigPin  = D3
GND = GND
VCC  = 5V
// 设定SR04连接的Arduino引脚
const int TrigPin = 3;
const int EchoPin = 2;
float distance;
{   // 初始化串口通信及连接SR04的引脚
    // 要检测引脚上输入的脉冲宽度,需要先设置为输入状态
    Serial.println("Ultrasonic sensor:");
    // 产生一个10us的高脉冲去触发TrigPin
        delayMicroseconds(2);
        delayMicroseconds(10);
    // 检测脉冲宽度,并计算出距离
        distance = pulseIn(EchoPin, HIGH) / 58.00;
        Serial.print(distance);
        Serial.print("cm");
        Serial.println();
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:22 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:24 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:44 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:46 | 显示全部楼层
签到天数: 506 天
 楼主| 发表于 2019-9-8 13:47 | 显示全部楼层
原价299元【语音开发板套件】限时免费领!
原价299元【语音开发板套
教你让OLED动起来!多重字符串版!
教你让OLED动起来!多重字
TTGO TFT屏幕Arduino使用的小结
TTGO TFT屏幕Arduino使用
分享我的第一个点灯程序——家庭控制中心
分享我的第一个点灯程序—
