查看: 1881|回复: 4
[分享] blinker控制RGB LED示例
    2019-7-12 18:42
    发表于 2019-9-9 23:46 | 显示全部楼层 |阅读模式
    这是一个RGB控制示例,帮助大家更好的编写灯控程序。
    注意:只有changeLight()函数在改变灯的状态,如果你是用的其他灯,只用在setup中进行初始化,在changeLight中改变灯的状态即可。
    #define BLINKER_WIFI
    char auth[] = "xxxxxxxxxxx";
    char ssid[] = "xxxxx";
    char pswd[] = "xxxxxxxxxx";
    #define RGB_1 "RGBKey"
    BlinkerRGB RGB1(RGB_1);
    bool switch_state = false;
    int red=0;
    int green=0;
    int blue=0;
    int bright=0;
    void rgb1_callback(uint8_t r_value, uint8_t g_value, uint8_t b_value, uint8_t bright_value)
        red=r_value;
        green=g_value;
        blue=b_value;
        bright=bright_value;
        changeLight();
        BLINKER_LOG("R value: ", r_value);
        BLINKER_LOG("G value: ", g_value);
        BLINKER_LOG("B value: ", b_value);
        BLINKER_LOG("Rrightness value: ", bright_value);
        RGB1.brightness(bright);
        RGB1.print(red, green, blue);
    void switch_callback(const String & state)
        BLINKER_LOG("get switch state: ", state);
            switch_state = true;
            bright=255;
            changeLight();
            BUILTIN_SWITCH.print("on");
            bright=0;
            changeLight();
            BUILTIN_SWITCH.print("off");
    void heartbeat()
        if (switch_state) BUILTIN_SWITCH.print("on");
        else BUILTIN_SWITCH.print("off");
    void changeLight(){
        int red_temp=map(red*bright/255,0,255,1023,0);
        int green_temp= map(green*bright/255,0,255,1023,0);
        int blue_temp= map(blue*bright/255,0,255,1023,0);
        BLINKER_LOG("red_temp: ", red_temp);
        BLINKER_LOG("green_temp: ", green_temp);
        BLINKER_LOG("blue_temp: ", blue_temp);
        analogWrite(D8,red_temp);
        analogWrite(D9,green_temp);
        analogWrite(D10,blue_temp);
        BLINKER_DEBUG.stream(Serial);
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.attachData(dataRead);
        BUILTIN_SWITCH.attach(switch_callback);
        RGB1.attach(rgb1_callback);
    2019-9-29 18:54
  • 签到天数: 10 天
    发表于 2019-9-12 09:58 | 显示全部楼层
    可以分享一下blinker软件中界面的设置吗?谢谢啦
    2019-7-12 18:42
     楼主| 发表于 2019-9-12 10:21 | 显示全部楼层
    就是一个颜色拾取组件,没了,不过这个程序是2.2.7使用的,不知道2.2.6正常不
    2020-3-8 11:08
  • 签到天数: 17 天
    发表于 2019-9-18 19:55 | 显示全部楼层
    coloz老师,能否写一个教程?开关按键:RGB循环变颜色的;颜色拾取:使用拾色按键选取颜色,调节亮度并且保持该颜色、亮度。折腾了许久不懂如何中断RGB循环颜色和解决blinker app端接受数据延迟的问题。谢谢~
    2019-7-12 18:42
     楼主| 发表于 2019-9-18 21:31 | 显示全部楼层
    carlbeven 发表于 2019-9-18 19:55
    coloz老师,能否写一个教程?开关按键:RGB循环变颜色的;颜色拾取:使用拾色按键选取颜色,调节亮度并且保 ...
    https://github.com/blinker-iot/Blinker_PRO_SMART_LAMP
    <ESP8266NodeMCU>网络连接问题
    基于机器视觉的智能分拣机械臂
    基于机器视觉的智能分拣机
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    blinker做的卧室灯开关发现一个问题
    blinker做的卧室灯开关发
