楼主 |
发表于 2022-11-23 15:14
显示全部楼层
- #define LIN_OUT 1
- #define FHT_N 128 // set to 256 point fht 128
- #include <FHT.h> // include the library
- #include <SPI.h>
- #include <DMD.h> //
- #include <TimerOne.h> //
- #include "SystemFont5x7.h"
- #include "Arial_black_16.h"
- #define DISPLAYS_ACROSS 1
- #define DISPLAYS_DOWN 1
- DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
- // Change this to MONO to for a one-channel full-display or STEREO for two-channel
- String displayType = "MONO";
- byte sampleR[64]; //64
- byte sampleL[64];
- unsigned long startTime, endTime, oldTime;
- String displayText = "DY";
- String sampleSet;
- int displaySize;
- void ScanDMD()
- dmd.scanDisplayBySPI();
- void setup() {
- if (displayType == "MONO") {displaySize = 32;} else {displaySize = 16;}
- //TIMSK0 = 0; // turn off timer0 for lower jitter
- ADCSRA = 0xe7; // set the adc to free running mode
- ADMUX = 0x45; // use adc5
- DIDR0 = 0x20; // turn off the digital input for adc5
- Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
- Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
- dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
- dmd.selectFont(Arial_Black_16); // show off who wrote the app... :p
- dmd.drawString(6,1,"DY",2,GRAPHICS_NORMAL);
- delay(3000);
- dmd.drawString(6,1,"CJ",2,GRAPHICS_NORMAL);
- delay(3000);
- dmd.selectFont(SystemFont5x7);
- dmd.drawString(2,0,"Audio",5,GRAPHICS_NORMAL);
- dmd.drawString(2,9,"Analy",5,GRAPHICS_NORMAL);
- delay(3000);
- void loop() {
- startTime = millis();
- sampleSet = "L";
- sampleInput();
- sampleFix();
- if (displaySize == 16) {
- sampleSet = "R";
- sampleInput();
- sampleFix();
- drawSpectrum();
- endTime = millis();
- void drawSpectrum () {
- dmd.clearScreen(true);
- for (int disX; disX < 16; disX++) {
- dmd.drawLine (disX, 16, disX, 16-sampleL[disX+1], GRAPHICS_NORMAL );
- dmd.drawLine (17+disX, 16, 17+disX, 16-sampleR[disX+1], GRAPHICS_NORMAL );
- else {
- for (int disX; disX < 33; disX++) {
- void sampleInput() {
- cli(); // UDRE interrupt slows this way down on arduino1.0
- for (int x=0; x<FHT_N; x++) {
- while(!(ADCSRA & 0x10)); // wait for adc to be ready
- ADCSRA = 0xf5; // restart adc
- if (sampleSet == "L") {
- } else {
- ADMUX = 0x44; // use adc4
- byte m = ADCL; // fetch adc data
- byte j = ADCH;
- int k = (j << 8) | m; // form into an int 8
- k -= 0x0200; // form into a signed int
- k <<= 6; // form into a 16b signed int 6
- fht_input[x] = k; // put real data into bins
- sei();
- fht_window(); // window the data for better frequency response
- fht_reorder(); // reorder the data before doing the fht
- fht_run(); // process the data in the fht
- fht_mag_lin();
- void sampleFix() {
- int newPos;
- float fhtCount, tempY;
- for (int x=0; x < displaySize; x++) {
- fhtCount = FHT_N/2; // 2
- newPos = x * (fhtCount / displaySize); // single channel half-display 15-LED wide
- tempY = fht_lin_out[newPos];
- sampleL[x] = ((tempY/256)*16); // single channel full 16 LED high
- } else {
- sampleR[x] = ((tempY/256)*16); // single channel full 16 LED high
