查看: 549|回复: 4
[未解决] DS1302读不出来时间
    2019-9-12 08:08
    发表于 2019-9-11 22:05 | 显示全部楼层 |阅读模式
    用的是unoR3板,代码用的是网上的ds1302库的示例,代码如下
    #include <stdio.h>
    #include <DS1302.h>
    namespace {
    // Set the appropriate digital I/O pin connections. These are the pin
    // assignments for the Arduino as well for as the DS1302 chip. See the DS1302
    // datasheet:
    //   http://datasheets.maximintegrated.com/en/ds/DS1302.pdf
    const int kCePin   = 5;  // Chip Enable
    const int kIoPin   = 6;  // Input/Output
    const int kSclkPin = 7;  // Serial Clock
    // Create a DS1302 object.
    DS1302 rtc(kCePin, kIoPin, kSclkPin);
    String dayAsString(const Time:ay day) {
      switch (day) {
        case Time::kSunday: return "Sunday";
        case Time::kMonday: return "Monday";
        case Time::kTuesday: return "Tuesday";
        case Time::kWednesday: return "Wednesday";
        case Time::kThursday: return "Thursday";
        case Time::kFriday: return "Friday";
        case Time::kSaturday: return "Saturday";
      return "(unknown day)";
    void printTime() {
      // Get the current time and date from the chip.
      Time t = rtc.time();
      // Name the day of the week.
      const String day = dayAsString(t.day);
      // Format the time and date and insert into the temporary buffer.
      char buf[50];
      snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
               day.c_str(),
               t.yr, t.mon, t.date,
               t.hr, t.min, t.sec);
      // Print the formatted string to serial so we can see the time.
      Serial.println(buf);
    }  // namespace
      // Initialize a new chip by turning off write protection and clearing the
      // clock halt flag. These methods needn't always be called. See the DS1302
      // datasheet for details.
      rtc.writeProtect(false);
      rtc.halt(false);
      // Make a new time object to set the date and time.
      // Sunday, September 22, 2013 at 01:38:50.
      Time t(2013, 9, 22, 1, 38, 50, Time::kSunday);
      // Set the time and date on the chip.
      rtc.time(t);
    // Loop and print the time every second.
      printTime();
    换了几个ds1302了,程序上传没有问题,但是用串口监视器看输出的都是(unknown day) 2000-00-00 00:00:00
    求解这个是怎么一个情况?
    ds1302库.zip
    155.4 KB, 下载次数: 5
    2019-9-12 08:08
     楼主| 发表于 2019-9-11 22:08 | 显示全部楼层
    接线也没有错,有个情况不知道是正确的还是错误的,程序上传以后,R3板的TX灯会一直亮,然后打开串口监视器TX灯就会随着时间跳动的节奏闪烁
    发表于 2019-9-12 07:20 | 显示全部楼层
    我前两天调试时钟程序时,也遇到这个问题,我手中有三个不同类型的DSc302模块,一开始也是读不出数,我以为我换了两块,总是不起振,后来把一个正在用的拿过来,直接就读出来数了,我的建议是,一定要保证你试用的模块是好用的,然后你再测试程序。
    2020-2-24 08:58
    发表于 2019-9-12 09:23 | 显示全部楼层
    根据以上检查接线
    2019-9-14 07:38
    发表于 2019-9-12 23:59 来自手机 | 显示全部楼层
    注意供电问题,查一下晶振有没有正常起振~希望对你有用,之前有用过,因为供电问题导致非常不稳定,查了晶振不起振,才发现电源错了
    ESP32能烧录程序但是不能启动
    ESP32能烧录程序但是不能
    电路图3如下1,能烧录程序但是不能启动,3.3V供电正常
    SpiderRobot 蜘蛛
    SpiderRobot 蜘蛛
    点灯·blinker-app智动化
