查看: 260|回复: 0
[经验] arduino驱动p3.75双色led单元64*32
    2019-7-22 10:11
  • 签到天数: 28 天
    发表于 2019-10-15 09:27 | 显示全部楼层 |阅读模式
    使用了MsTimer2库,论坛里有。使用了hx711传感器
    缺点:使用的全局变量偏大,余留289字节。希望高手能优化一下,减少全局变量占用。
    //定时器库的 头文件
    #include <MsTimer2.h>
    #include <Arduino.h>
    #define HX711_SCK 18
    #define HX711_DT 19
    long HX711_Buffer = 0;
    long Weight_Maopi = 0, Weight_Shiwu = 0;
    #define GapValue 430
    float Weight = 0;
    int m, f, flag;
    //extern void Init_Hx711();
    //extern unsigned long HX711_Read(void);
    //extern long Get_Weight();
    //extern void Get_Maopi();
    //初始化HX711
    void Init_Hx711()
      pinMode(HX711_SCK, OUTPUT);
      pinMode(HX711_DT, INPUT);
    //获取毛皮重量
    void Get_Maopi()
      Weight_Maopi = HX711_Read();
    //称重
    long Get_Weight()
      HX711_Buffer = HX711_Read();
      Weight_Shiwu = HX711_Buffer;
      Weight_Shiwu = Weight_Shiwu - Weight_Maopi;       //获取实物的AD采样数值。
      Weight_Shiwu = (long)((float)Weight_Shiwu / GapValue);
      return Weight_Shiwu;
    //读取HX711
    unsigned long HX711_Read(void)  //增益128
      unsigned long count;
      unsigned char i;
      bool Flag = 0;
      digitalWrite(HX711_DT, HIGH);
      delayMicroseconds(1);
      digitalWrite(HX711_SCK, LOW);
      count = 0;
      while (digitalRead(HX711_DT));
      for (i = 0; i < 24; i++)
        digitalWrite(HX711_SCK, HIGH);
        count = count << 1;
        if (digitalRead(HX711_DT))count++;
      count ^= 0x800000;
      return (count);
    int LEPin = 11;//LE锁存控制
    int CLKPin = 12;//时钟 上升沿输入数据
    int R1Pin = 2;//红色上半部分数据
    int R2Pin = 3;//红色下半部分数据
    int G1Pin = 9;//绿色上半部分数据
    int G2Pin = 10;//绿色下半部分数据
    int OEPin = 4;//使能
    int APin = 5;//A
    int BPin = 6;//B
    int CPin = 7;//C
    int DPin = 8;//D
    int keyPin0 = A6;
    int keyPin1 = A7;
    int dian2[64] =
    {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF9, 0xFF, 0xF0, 0xFF, 0xF0, 0xFF, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF}; /*".",0*/
    int shuzi2[12][64] =
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x7F, 0xF3, 0xBF, 0xE7, 0x9F, 0xCF, 0xCF, 0xCF, 0xCF, 0xCF, 0xEF, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0xCF, 0xEF, 0xCF, 0xCF, 0xCF, 0xCF, 0xE7, 0x9F, 0xF3, 0xBF, 0xF8, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"0",0*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFC, 0xFF, 0xC0, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xFC, 0xFF, 0xF8, 0x7F, 0xC0, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"1",1*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x3F, 0xEF, 0x8F, 0xDF, 0xCF, 0xBF, 0xE7, 0xBF, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0xFF, 0xE7, 0xFF, 0xCF, 0xFF, 0xCF, 0xFF, 0x9F, 0xFF, 0x3F, 0xFE, 0x7F, 0xFC, 0xFF, 0xF9, 0xFF, 0xFB, 0xFF, 0xF7, 0xF7, 0xEF, 0xF7, 0xDF, 0xF7, 0xBF, 0xE7, 0x80, 0x0F, 0x80, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"2",2*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x7F, 0xCF, 0x3F, 0x9F, 0x9F, 0x9F, 0xCF, 0x9F, 0xCF, 0x9F, 0xCF, 0xFF, 0xCF, 0xFF, 0xCF, 0xFF, 0x9F, 0xFF, 0x3F, 0xF8, 0x7F, 0xFF, 0x1F, 0xFF, 0xCF, 0xFF, 0xEF, 0xFF, 0xE7, 0xFF, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xEF, 0x9F, 0xCF, 0xCF, 0x9F, 0xF0, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"3",3*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0xFF, 0x3F, 0xFE, 0x3F, 0xFE, 0x3F, 0xFD, 0x3F, 0xFD, 0x3F, 0xFB, 0x3F, 0xF7, 0x3F, 0xF7, 0x3F, 0xEF, 0x3F, 0xEF, 0x3F, 0xDF, 0x3F, 0x9F, 0x3F, 0xBF, 0x3F, 0x7F, 0x3F, 0x00, 0x07, 0xFF, 0x3F, 0xFF, 0x3F, 0xFF, 0x3F, 0xFF, 0x3F, 0xFF, 0x3F, 0xF8, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"4",4*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0x07, 0xE0, 0x07, 0xDF, 0xFF, 0xDF, 0xFF, 0xDF, 0xFF, 0xDF, 0xFF, 0xDF, 0xFF, 0xDF, 0xFF, 0xD8, 0x3F, 0xD7, 0x9F, 0xCF, 0xCF, 0xDF, 0xEF, 0xFF, 0xE7, 0xFF, 0xE7, 0xFF, 0xE7, 0xFF, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0xBF, 0xCF, 0xBF, 0xCF, 0xCF, 0x9F, 0xF0, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"5",5*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x3F, 0xF3, 0xCF, 0xE7, 0xCF, 0xEF, 0xCF, 0xCF, 0xFF, 0xDF, 0xFF, 0xDF, 0xFF, 0x9F, 0xFF, 0x98, 0x3F, 0x93, 0x9F, 0x8F, 0xCF, 0x8F, 0xEF, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0xCF, 0xE7, 0xCF, 0xEF, 0xE7, 0xCF, 0xE3, 0x9F, 0xF8, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"6",6*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x07, 0xC0, 0x07, 0xDF, 0xEF, 0x9F, 0xDF, 0xBF, 0xDF, 0xBF, 0xBF, 0xFF, 0xBF, 0xFF, 0x7F, 0xFF, 0x7F, 0xFF, 0x7F, 0xFE, 0xFF, 0xFE, 0xFF, 0xFD, 0xFF, 0xFD, 0xFF, 0xFD, 0xFF, 0xFD, 0xFF, 0xF9, 0xFF, 0xF9, 0xFF, 0xF9, 0xFF, 0xF9, 0xFF, 0xF9, 0xFF, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"7",7*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x3F, 0xE7, 0x9F, 0xCF, 0xCF, 0x9F, 0xE7, 0x9F, 0xE7, 0x9F, 0xE7, 0x8F, 0xE7, 0x8F, 0xEF, 0xC3, 0xCF, 0xE1, 0xBF, 0xF0, 0x7F, 0xCE, 0x1F, 0x9F, 0x0F, 0x9F, 0x8F, 0x3F, 0xC7, 0x3F, 0xE7, 0x3F, 0xE7, 0x3F, 0xE7, 0x3F, 0xE7, 0x9F, 0xCF, 0xCF, 0x9F, 0xF0, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"8",8*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x7F, 0xCF, 0xBF, 0x9F, 0xDF, 0x9F, 0xCF, 0x3F, 0xEF, 0x3F, 0xE7, 0x3F, 0xE7, 0x3F, 0xE7, 0x3F, 0xE7, 0x3F, 0xE7, 0x1F, 0xC7, 0x9F, 0xA7, 0xCF, 0x27, 0xE0, 0xE7, 0xFF, 0xE7, 0xFF, 0xCF, 0xFF, 0xCF, 0xFF, 0xDF, 0x9F, 0x9F, 0x9F, 0x3F, 0x9E, 0x7F, 0xE0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"9",9*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F, 0xE0, 0xC7, 0xFB, 0xC7, 0xFB, 0xD3, 0xFB, 0xD3, 0xFB, 0xD9, 0xFB, 0xD9, 0xFB, 0xDC, 0xFB, 0xDC, 0xFB, 0xDE, 0x7B, 0xDE, 0x7B, 0xDF, 0x3B, 0xDF, 0x3B, 0xDF, 0x9B, 0xDF, 0x9B, 0xDF, 0xCB, 0xDF, 0xCB, 0xDF, 0xE3, 0xDF, 0xE3, 0xDF, 0xF3, 0xDF, 0xF3, 0x07, 0xFB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, /*"N",10*/
      {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x11, 0xF3, 0xC9, 0xF7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xF7, 0xE7, 0xF3, 0xCF, 0xF0, 0x1F, 0xE7, 0xFF, 0xE7, 0xFF, 0xE0, 0x3F, 0xF0, 0x07, 0xE7, 0xE3, 0xCF, 0xF3, 0xCF, 0xF3, 0xCF, 0xF3, 0xE7, 0xE7, 0xF8, 0x1F}, /*"g",11*/
    void SendDate(unsigned char DataR1, unsigned char DataG1,  unsigned char DataR2, unsigned char DataG2 )
      unsigned char i;
      for (i = 0; i < 8; i++)
        digitalWrite(CLKPin, LOW);
        digitalWrite(R1Pin, DataR1 & 0x80);
        digitalWrite(R2Pin, DataR2 & 0x80);
        //    digitalWrite(G1Pin, DataR1 & 0x80);
        //    digitalWrite(G2Pin, DataR2 & 0x80);
        digitalWrite(CLKPin, HIGH);
        DataR1 <<= 1;
        //    DataG1 <<= 1;
        DataR2 <<= 1;
        //    DataG2 <<= 1;
    void flash()
        显示质量,单位克
      if (!flag)
        for (int i = 0; i < 16; i++)
          //      digitalWrite(CLKPin, LOW);
          digitalWrite(LEPin, LOW);//锁存,传递数据
          if (m < 100)
            SendDate( 0xFF, 0xFF, 0xFF, 0xFF );
            SendDate( 0xFF, 0xFF, 0xFF, 0xFF);
            SendDate(shuzi2[m / 100][2 * i], 0xFF, shuzi2[m / 100][2 * i + 32], 0xFF);
            SendDate(shuzi2[m / 100][2 * i + 1], 0xFF, shuzi2[m / 100][2 * i + 33], 0xFF);
          if (m < 10)
            SendDate(shuzi2[(m / 10) % 10][2 * i], 0xFF, shuzi2[(m / 10) % 10][2 * i + 32], 0xFF);
            SendDate(shuzi2[(m / 10) % 10][2 * i + 1], 0xFF, shuzi2[(m / 10) % 10][2 * i + 33],  0xFF);
          SendDate(shuzi2[m  % 10][2 * i], 0xFF, shuzi2[m  % 10][2 * i + 32],  0xFF);
          SendDate(shuzi2[m % 10][2 * i + 1], 0xFF,  shuzi2[m  % 10][2 * i + 33], 0xFF);
          SendDate(shuzi2[11][2 * i], 0xFF,  shuzi2[11][2 * i + 32],  0xFF);
          SendDate(shuzi2[11][2 * i + 1], 0xFF,  shuzi2[11][2 * i + 33], 0xFF);
          digitalWrite(APin, i & 0x01); digitalWrite(BPin, i & 0x02); digitalWrite(CPin, i & 0x04); digitalWrite(DPin,  i & 0x08);
          digitalWrite(LEPin, HIGH);//锁存,显示
          digitalWrite(OEPin, LOW  );
          delayMicroseconds(200);
          digitalWrite(OEPin, HIGH);
          显示力,单位牛顿
          if (f < 100)
            SendDate(shuzi2[0][2 * i], 0xFF,  shuzi2[0][2 * i + 32] & dian2[2 * i + 32], 0xFF);
            SendDate(shuzi2[0][2 * i + 1], 0xFF, shuzi2[0][2 * i + 33] & dian2[2 * i + 33],  0xFF);
          } else
            SendDate(shuzi2[f / 100][2 * i], 0xFF,  shuzi2[f / 100][2 * i + 32] & dian2[2 * i + 32], 0xFF);
            SendDate(shuzi2[f / 100][2 * i + 1], 0xFF, shuzi2[f / 100][2 * i + 33] & dian2[2 * i + 33],  0xFF);
          if (f < 10)
            SendDate(shuzi2[0][2 * i], 0xFF,  shuzi2[0][2 * i + 32] , 0xFF);
            SendDate(shuzi2[0][2 * i + 1], 0xFF, shuzi2[0][2 * i + 33] ,  0xFF);
            SendDate(shuzi2[(f / 10) % 10][2 * i], 0xFF, shuzi2[(f / 10) % 10][2 * i + 32], 0xFF);
            SendDate(shuzi2[(f / 10) % 10][2 * i + 1], 0xFF, shuzi2[(f / 10) % 10][2 * i + 33], 0xFF);
          SendDate(shuzi2[f  % 10][2 * i], 0xFF,  shuzi2[f  % 10][2 * i + 32],  0xFF);
          SendDate(shuzi2[f % 10][2 * i + 1], 0xFF,  shuzi2[f  % 10][2 * i + 33], 0xFF);
          SendDate( shuzi2[10][2 * i], 0xFF,  shuzi2[10][2 * i + 32],  0xFF);
          SendDate(shuzi2[10][2 * i + 1], 0xFF, shuzi2[10][2 * i + 33],  0xFF);
      pinMode(LEPin, OUTPUT);
      pinMode(CLKPin, OUTPUT);
      pinMode(R1Pin, OUTPUT);
      pinMode(R2Pin, OUTPUT);
      pinMode(G1Pin, OUTPUT);
      pinMode(G2Pin, OUTPUT);
      pinMode(APin, OUTPUT);
      pinMode(BPin, OUTPUT);
      pinMode(CPin, OUTPUT);
      pinMode(DPin, OUTPUT);
      pinMode(OEPin, OUTPUT);
      pinMode(keyPin0, INPUT_PULLUP);
      pinMode(keyPin1, INPUT_PULLUP);
       Init_Hx711();       //初始化HX711模块连接的IO设置
      digitalWrite(G1Pin, HIGH);
      digitalWrite(G2Pin, HIGH);
      digitalWrite(R1Pin, HIGH);
      digitalWrite(R2Pin, HIGH);
      Serial.print("Welcome to use!\n");
      delay(3000);
      Get_Maopi();    //获取毛皮
      // 中断设置函数,每 2ms 进入一次中断
      MsTimer2::set(2, flash);
      //开始计时
      MsTimer2::start();
       Weight = Get_Weight();  //计算放在传感器上的重物重量
      m = Weight;
      if (m < 0)m = 0;
      f = m * 9.8 / 10;
      if (f < 0)f = 0;
    《第四章》自制Arduino最小系统板,经过再次改进后终于完成
    《第四章》自制Arduino最
    经过了上次的失败后,我又重新设计了电路,选取了一些合适的器件来改进我的这块板子,
    中文 字库 的8针 OLED 128
    萌新跪求arduinoUNO板对接无线模块(如何接和程序)
    萌新跪求arduinoUNO板对接
