查看: 1438|回复: 1
【搬运】M5StickC Audio Spectrum Display
发表于 2019-10-28 10:12 | 显示全部楼层 |阅读模式
     本节介绍一个麦克风应用,制作8段式音频频谱显示器。C的内部集成了一个微型麦克风可以采集声音信号,通过配置I2S就能进行数据通讯,所以如果你想使用麦克风采集音频信号的话可以参考以下程序的I2S配置。本例程需要安装一个快速傅里叶变换的Arduino库,此外作者开启了GCC编译器3级优化。实际测试中还存在问题,大概运行1个小时左右就死机,不过这个案例能帮助我们很好的理解内置麦克风的使用。
[mw_shl_code=arduino,true]#include "arduinoFFT.h"
arduinoFFT FFT = arduinoFFT();
#include <M5StickC.h>
#include <driver/i2s.h>
#pragma GCC optimize ("O3")
#define PIN_CLK  0
#define PIN_DATA 34
#define READ_LEN (2 * 1024)
uint8_t BUFFER[READ_LEN] = {0};
uint16_t oldx[160];
uint16_t oldy[160];
uint16_t *adcBuffer = NULL; // uint16_t *adcBuffer = NULL;
#define SAMPLES 512         // Must be a power of 2
#define SAMPLING_FREQUENCY 40000
struct eqBand {
  const char *freqname;
  uint16_t amplitude;
  int peak;
  int lastpeak;
  uint16_t lastval;
  unsigned long lastmeasured;
eqBand audiospectrum[8] = {
  // Adjust the amplitude values to fit your microphone
  // freqname,amplitude,peak,lastpeak,lastval,lastmeasured
  {  ".1",1000, 0, 0, 0, 0},
  {  ".2", 500, 0, 0, 0, 0},
  {  ".5", 300, 0, 0, 0, 0},
  {  "1" , 250, 0, 0, 0, 0},
  {  "2" , 200, 0, 0, 0, 0},
  {  "4" , 100, 0, 0, 0, 0},
  {  "8" ,  50, 0, 0, 0, 0},
  { "16" ,  50, 0, 0, 0, 0}
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
unsigned long newTime, oldTime;
uint16_t tft_width  = 160;
uint16_t tft_height =  80;
uint8_t bands = 8;
uint8_t bands_width = floor( tft_width / bands );
uint8_t bands_pad = bands_width - 10;
uint16_t colormap[255];//color palette for the band meter(pre-fill in setup)
void i2sInit(){
   i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_PDM),
    .sample_rate =  44100,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, //is fixed at 12bit,stereo,MSB
    .channel_format = I2S_CHANNEL_FMT_ALL_RIGHT,
    .communication_format = I2S_COMM_FORMAT_I2S,
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
    .dma_buf_count = 2,
    .dma_buf_len = 128,
   i2s_pin_config_t pin_config;
   pin_config.bck_io_num   = I2S_PIN_NO_CHANGE;
   pin_config.ws_io_num    = PIN_CLK;
   pin_config.data_out_num = I2S_PIN_NO_CHANGE;
   pin_config.data_in_num  = PIN_DATA;
   i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
   i2s_set_pin(I2S_NUM_0, &pin_config);
   i2s_set_clk(I2S_NUM_0, 44100,I2S_BITS_PER_SAMPLE_16BIT,I2S_CHANNEL_MONO);
void mic_record_task (void* arg){
  while(1){
    i2s_read_bytes(I2S_NUM_0,(char*)BUFFER,READ_LEN,(100/portTICK_RATE_MS));
    adcBuffer = (uint16_t *)BUFFER;
    showSignal();
    vTaskDelay(100 / portTICK_RATE_MS);
  M5.begin();
  M5.Lcd.setRotation(1);
  M5.Lcd.fillScreen(BLACK);
  M5.Lcd.setTextColor(BLUE);
  M5.Lcd.setTextSize(1);
  i2sInit();
  xTaskCreatePinnedToCore(mic_record_task,"mic_record_task",2048,NULL,1,NULL,1);
  sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
  delay(2000);
  for(uint8_t i=0;i<tft_height;i++) {
  //colormap = M5.Lcd.color565(tft_height-i*.5,i*1.1,0); //RGB
    colormap = M5.Lcd.color565(tft_height-i*4.4,i*2.5,0);//RGB:rev macsbug
  for (byte band = 0; band <= 7; band++) {
    M5.Lcd.setCursor(bands_width*band + 2, 0);
    M5.Lcd.print(audiospectrum[band].freqname);
void showSignal(){
  for (int i = 0; i < SAMPLES; i++) {
    newTime  = micros() - oldTime;
    oldTime  = newTime;
    vReal = adcBuffer;
    vImag = 0;
    while (micros() < (newTime + sampling_period_us)){//do nothing to wait
  FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
  for (int i = 2; i < (SAMPLES/2); i++){
    // Don't use sample 0 and only first SAMPLES/2 are usable.
    // Each array eleement represents a frequency and its value the amplitude.
    if (vReal > 1500) { // Add a crude noise filter, 10 x amplitude or more
      byte bandNum = getBand(i);
      if(bandNum!=8) {
        displayBand(bandNum, (int)vReal/audiospectrum[bandNum].amplitude);
  long vnow = millis();
    // auto decay every 50ms on low activity bands
    if(vnow - audiospectrum[band].lastmeasured > 50) {
      displayBand(band, audiospectrum[band].lastval>4 ? audiospectrum[band].lastval-4 : 0);
    if (audiospectrum[band].peak > 0) {
      audiospectrum[band].peak -= 2;
      if(audiospectrum[band].peak<=0) {
        audiospectrum[band].peak = 0;
    // only draw if peak changed
    if(audiospectrum[band].lastpeak != audiospectrum[band].peak) {
      // delete last peak
     M5.Lcd.drawFastHLine(bands_width*band,tft_height-audiospectrum[band].lastpeak,bands_pad,BLACK);
     audiospectrum[band].lastpeak = audiospectrum[band].peak;
     M5.Lcd.drawFastHLine(bands_width*band, tft_height-audiospectrum[band].peak,
                          bands_pad, colormap[tft_height-audiospectrum[band].peak]);
void displayBand(int band, int dsize){
  uint16_t hpos = bands_width*band;
  int dmax = 200;
  if(dsize>tft_height-10) {
    dsize = tft_height-10; // leave some hspace for text
  if(dsize < audiospectrum[band].lastval) {
    // lower value, delete some lines
    M5.Lcd.fillRect(hpos, tft_height-audiospectrum[band].lastval,
                    bands_pad, audiospectrum[band].lastval - dsize,BLACK);
  if (dsize > dmax) dsize = dmax;
  for (int s = 0; s <= dsize; s=s+4){
    M5.Lcd.drawFastHLine(hpos, tft_height-s, bands_pad, colormap[tft_height-s]);
  if (dsize > audiospectrum[band].peak){audiospectrum[band].peak = dsize;}
  audiospectrum[band].lastval = dsize;
  audiospectrum[band].lastmeasured = millis();
byte getBand(int i) {
  if (i<=2 )             return 0;  // 125Hz
  if (i >3   && i<=5 )   return 1;  // 250Hz
  if (i >5   && i<=7 )   return 2;  // 500Hz
  if (i >7   && i<=15 )  return 3;  // 1000Hz
  if (i >15  && i<=30 )  return 4;  // 2000Hz
  if (i >30  && i<=53 )  return 5;  // 4000Hz
  if (i >53  && i<=200 ) return 6;  // 8000Hz
  if (i >200           ) return 7;  // 16000Hz
  return 8;
void loop() {}[/mw_shl_code]
发表于 2019-10-28 10:44 | 显示全部楼层
看起来挺有意思的啊
现在的 arm 核心的都支持 i2s 直接获得音频了
小度app不能连接<已解决>
小度app不能连接<已解决>
用的是点灯2.7.1,已经没有阿里broker了。所以就加了Arduino设备。 点灯app没有问题可
MAX6675模块+K型热电偶因为导线长短出现的测温不准问题
MAX6675模块+K型热电偶因
MAX6675模块+K型热电偶因为导线长短出现的测温不准问题.搞了好多天了,找不到原因。MA
智能家居之震动闹钟
智能家居之震动闹钟
[md]## 简介 blinker设备端SDK已经集成了定时控制功能,用户只需要添加定时组件到设备
家居之氛围灯
家居之氛围灯
[md]## 简介 Wifiduino接入云服务器后,我们可以通过已经联网的智能音箱发送指令来控
