查看: 6425|回复: 15
arduino ide给esp8266-01上传程序失败
发表于 2019-10-29 22:37 | 显示全部楼层 |阅读模式
arduino ide给esp8266-01上传示例程序失败
  1. /*
  2.   ESP8266 Blink by Simon Peter
  3.   Blink the blue LED on the ESP-01 module
  4.   This example code is in the public domain
  5.   The blue LED on the ESP-01 module is connected to GPIO1
  6.   (which is also the TXD pin; so we cannot use Serial.print() at the same time)
  7.   Note that this sketch uses LED_BUILTIN to find the pin with the internal LED
  8. */
  9. void setup() {
  10.   pinMode(LED_BUILTIN, OUTPUT);     // Initialize the LED_BUILTIN pin as an output
  11. }
  12. // the loop function runs over and over again forever
  13. void loop() {
  14.   digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (Note that LOW is the voltage level
  15.   // but actually the LED is on; this is because
  16.   // it is active low on the ESP-01)
  17.   delay(1000);                      // Wait for a second
  18.   digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
  19.   delay(2000);                      // Wait for two seconds (to demonstrate the active low LED)
  20. }
我忘了是esp8266-01还是esp8266-01s,用这个底座来连接电脑上传程序
用com串口调试工具可以连接,但是用arduino ide给esp8266-01上传示例程序却失败,如下图
图片有点小,我还是把 报错信息粘上来吧(下面红色字)
Arduino:1.8.10 (Windows 7), 开发板:"Generic ESP8266 Module, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), ck, 40 MHz, 40MHz, DOUT (compatible), 512K (no SPIFFS), 2, nonos-sdk 2.2.1 (legacy), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
项目使用了 257712 字节,占用了 (51%) 程序存储空间。最大为 499696 字节。
全局变量使用了26572字节,(32%)的动态内存,余留55348字节局部变量。最大为81920字节。
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM12
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
  File "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2/tools/upload.py", line 25, in <module>
    esptool.main(fakeargs)
  File "C:/Users/Administrator/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py", line 2653, in main
    esp.connect(args.before)
  File "C:/Users/Administrator/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py", line 468, in connect
    raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
选择的串口 _
不存在或开发板没有连接
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
看网上别人的教程好像没做什么别的操作就可以直接写入,而我操作就不行,换了电脑试了,也换了esp8266试了
弄了半天还是不知道问题出在 哪里,希望有大神能给我指点一下啊
    2021-1-4 08:50
  • 签到天数: 827 天
    [LV.10]以坛为家III
    发表于 2019-10-29 23:43 | 显示全部楼层
    选择的串口 _
    不存在或开发板没有连接
    2017-6-8 09:20
    发表于 2019-10-30 08:02 | 显示全部楼层
    这个底座之后串口功能,如果想用来下载程序,你需要在gpio0接地,下载前RST短接到地端,使esp-01进入下载模式
     楼主| 发表于 2019-10-30 09:29 | 显示全部楼层
    单片机菜鸟 发表于 2019-10-29 23:43
    选择的串口 _
    不存在或开发板没有连接
    就是不知道找不到串口的原因在哪
     楼主| 发表于 2019-10-30 09:32 | 显示全部楼层
    天狼落星 发表于 2019-10-30 08:02
    这个底座之后串口功能,如果想用来下载程序,你需要在gpio0接地,下载前RST短接到地端,使esp-01进入下载模 ...
    gpio0和rst同时接地吗?
    是接一下就行还是得一直接着?
    发表于 2019-11-2 10:32 | 显示全部楼层
    没有选择端口
    2019-9-1 02:18
    发表于 2019-11-22 18:58 | 显示全部楼层
    myarduino666 发表于 2019-10-30 09:32
    gpio0和rst同时接地吗?
    是接一下就行还是得一直接着?
    用铜丝一小段 连接gpio0和gnd 插入电脑即可
    难过
    2020-2-16 01:37
    发表于 2020-2-16 11:31 来自手机 | 显示全部楼层
    请问一下解决了吗  我也是这个问题
    2020-1-18 12:13
    发表于 2020-2-16 20:19 | 显示全部楼层
    受教了
    看了楼主发的图片,我才知道,原来8266模块还有这种用法,
    我是一直用Arduino Nano为主控,串口接8266,其它引脚接电磁阀或传感器,做一些测试工装
    再把测试到数据显示到12864屏上,及传到间服务器上
    2020-2-28 10:33
  • 签到天数: 4 天
    发表于 2020-2-25 17:18 | 显示全部楼层
    串口选对了吗,我也用的这种差不多的烧写工具,只要选对板子和串口,就可以了啊,
    arduino,工具>端口,看选择的对吗。
    ESP8266-01烧录blinker定制固件成功后,调试无反应
    如图所示配置 烧录后,将IO0拉高调试,在串口监视器中发送AT指令一片空白。 不知道
    树莓派资源分享
    树莓派资源分享
    下面是我学习过程中收集到的一些资源,分享给大家; 主要有一些书籍、DIY项目、系统镜
    串口丢失接收的字符
    串口丢失接收的字符
    arduino micro pro 损坏,板子无法用iic烧录程序
    已经使用USBtiny重新烧录过引导程序,提示烧录完成,烧录后表示串口的灯开始疯狂的闪
    雄霸Arduino中文开发平台
    雄霸Arduino中文开发平台
    雄霸Arduino中文开发平台适合于小白学习,中英文无缝切换。由于文件较大无法上传,请
