查看: 502|回复: 0
[未解决] 萌新求助 关于Windows remote arduino UWP app的问题
    2020-1-7 11:13
  • 签到天数: 9 天
    发表于 2019-11-22 11:31 | 显示全部楼层 |阅读模式
    前几天本人在网上看到了一篇关于用xbox one手柄控制arduino小车的文章https://www.hackster.io/svelde/control-arduino-rover-using-firmata-and-xbox-one-controller-70c51a?ref=user&ref_id=27558&offset=0,就也想把闲置的手柄利用起来,于是按部就班的给uno上载了standard firmata,也用网上的代码做了一个app,运行后点击连接总是提示无法找到蓝牙设备,希望得到大佬们的帮助。
    UWP app代码:
    using Microsoft.Maker.Firmata;
    using Microsoft.Maker.RemoteWiring;
    using Microsoft.Maker.Serial;
    using System;
    using System.Collections.Generic;
    using System.Threading.Tasks;
    using Windows.Gaming.Input;
    using Windows.UI.Core;
    using Windows.UI.Xaml;
    using Windows.UI.Xaml.Controls;
    namespace car_controller
        /// <summary>
        /// 可用于自身或导航至 Frame 内部的空白页。
        /// </summary>
        public sealed partial class MainPage : Page
            private BluetoothSerial _bluetooth;
            private RemoteDevice _arduino;
            private UwpFirmata _firmata = null;
            private Gamepad _Gamepad = null;
            // We never supply a PWM of more then 255 * 0,75
            private double _SpeedLimit = 0.75;
            // values below this absolte value stop the rover
            private double _ActionPoint = 0.15;
            private byte _LeftForward = 6;
            private byte _LeftBackward = 7;
            private byte _LeftValue = 5;
            private byte _RightForward = 9;
            private byte _RightBackward = 8;
            private byte _RightValue = 10;
            double sldrLeftSpeed;
            ushort LeftSpeed;
            double sldrRightSpeed;
            ushort RightSpeed;
            private Dictionary<byte, PinState> _CurrentPinStates
                                     = new Dictionary<byte, PinState>();
            private Dictionary<byte, ushort> _CurrentSpeedValues
                                       = new Dictionary<byte, ushort>();
            public MainPage()
                this.InitializeComponent();
            private void btnStart_Click(object sender,
                                        RoutedEventArgs e)
                btnStart.IsEnabled = false;
                Gamepad.GamepadAdded += Gamepad_GamepadAdded;
                Gamepad.GamepadRemoved += Gamepad_GamepadRemoved;
                _bluetooth = new BluetoothSerial("JDY-30");
                _bluetooth.ConnectionLost += BluetoothConnectionLost;
                _bluetooth.ConnectionFailed += BluetoothConnectionFailed;
                _bluetooth.ConnectionEstablished +=
                                               OnConnectionEstablished;
                _firmata = new UwpFirmata();
                _arduino = new RemoteDevice(_firmata);
                _firmata.begin(_bluetooth);
                _bluetooth.begin(9600, SerialConfig.SERIAL_8N1);
                _arduino.DeviceReady += ArduinoDeviceReady;
            private async void BluetoothConnectionLost(string message)
                await Dispatcher.RunAsync(
                  CoreDispatcherPriority.Normal, () =>
                      tbRead.Text = "ConnectionLost" + message;
                      btnStart.IsEnabled = true;
            private async void BluetoothConnectionFailed(string message)
                      tbRead.Text = "ConnectionFailed" + message;
            private async void ArduinoDeviceReady()
                      tbRead.Text = "Device Ready";
            private void OnConnectionEstablished()
                var action = Dispatcher.RunAsync(
                  new DispatchedHandler(() =>
                      DisableEnableButtons(true);
                      ArduinoDigitalWrite(_LeftForward, PinState.LOW);
                      ArduinoDigitalWrite(_LeftBackward, PinState.LOW);
                      ArduinoDigitalWrite(_RightBackward, PinState.LOW);
                      ArduinoDigitalWrite(_RightForward, PinState.LOW);
            private void DisableEnableButtons(bool enabled)
                // Disable all buttons. Otherwise
                //  the 'A' will press the one focussed.
                btnController.IsEnabled = enabled;
                btnStart.IsEnabled = enabled;
            private async void Gamepad_GamepadRemoved(
                                             object sender, Gamepad e)
                _Gamepad = null;
                      tbRead.Text = "Controller removed";
            private async void Gamepad_GamepadAdded(
                _Gamepad = e;
                      tbRead.Text = "Controller added";
            private async void btnController_Click(object sender,
                                                   RoutedEventArgs e)
                DisableEnableButtons(false);
                while (true)
                    await Task.Delay(TimeSpan.FromMilliseconds(3));
                    if (_Gamepad == null)
                        continue;
                    // Get the current state
                    var reading = _Gamepad.GetCurrentReading();
                    if (Math.Abs(reading.LeftThumbstickY) < _ActionPoint)
                        ArduinoAnalogWrite(_LeftValue, 0);
                    else if (reading.LeftThumbstickY >= _ActionPoint)
                        ArduinoDigitalWrite(_LeftForward, PinState.HIGH);
                        sldrLeftSpeed = 255 * Math.Abs(reading.LeftThumbstickY) * _SpeedLimit;
                        sldrLeftSpeed = Math.Truncate(sldrLeftSpeed);
                        LeftSpeed = (ushort)sldrLeftSpeed;
                        ArduinoAnalogWrite(_LeftValue,LeftSpeed);
                    else if (reading.LeftThumbstickY <= -_ActionPoint)
                        ArduinoDigitalWrite(_LeftBackward, PinState.HIGH);
                        ArduinoAnalogWrite(_LeftValue, LeftSpeed);
                    if (Math.Abs(reading.RightThumbstickY) < _ActionPoint)
                        ArduinoAnalogWrite(_RightValue,0);
                    else if (reading.RightThumbstickY >= _ActionPoint)
                        ArduinoDigitalWrite(_RightForward, PinState.HIGH);
                        sldrRightSpeed = 255 * Math.Abs(reading.RightThumbstickY) * _SpeedLimit;
                        sldrRightSpeed = Math.Truncate(sldrRightSpeed);
                        RightSpeed = (ushort)sldrRightSpeed;
                        ArduinoAnalogWrite(_RightValue,RightSpeed);
                    else if (reading.RightThumbstickY <= -_ActionPoint)
                        ArduinoDigitalWrite(_RightBackward, PinState.HIGH);
                        ArduinoAnalogWrite(_RightValue, RightSpeed);
            private void ArduinoDigitalWrite(byte port, PinState state)
                // ignore duplicate commands
                var exists = _CurrentPinStates.ContainsKey(port);
                if (!exists
                       || _CurrentPinStates[port] != state)
                    _CurrentPinStates[port] = state;
                    _arduino.digitalWrite(port, state);
            private void ArduinoAnalogWrite(byte port, ushort value)
                var exists = _CurrentSpeedValues.ContainsKey(port);
                if (!exists
                      || _CurrentSpeedValues[port] != value)
                    _CurrentSpeedValues[port] = value;
                    _arduino.analogWrite(port, value);
    [Arduino物联网开发实战2]数据反馈
    [Arduino物联网开发实战2]
    小爱同学开电脑 esp8266 12f
    小爱同学开电脑 esp8266 1
    1.mini D1 wifi ESP-12F N ESP8266开发板 2.1路 5V继电器模块 高电平触发 3.AMS1117-3
    服务器平台又挂了么,显示服务器未响应了
    服务器平台又挂了么,显示
    数据读不回来了
