查看: 596|回复: 0
[未解决] 为开发板 Digispark (Default - 16.5mhz) 编译时出错
    2019-11-23 01:25
    发表于 2019-11-23 01:25 | 显示全部楼层 |阅读模式
    Arduino:1.8.10 (Windows 10), 开发板:"Digispark (Default - 16.5mhz)"
    K:\工作类\badusb\arduino-1.8.10\arduino-builder -dump-prefs -logger=machine -hardware K:\工作类\badusb\arduino-1.8.10\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools K:\工作类\badusb\arduino-1.8.10\tools-builder -tools K:\工作类\badusb\arduino-1.8.10\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries K:\工作类\badusb\arduino-1.8.10\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=digistump:avr:digispark-tiny -ide-version=10810 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_798989 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_930150 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.micronucleus.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -prefs=runtime.tools.micronucleus-2.0a4.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -prefs=runtime.tools.avr-gcc-4.8.1-arduino5.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -verbose C:\Users\Administrator\Documents\Arduino\sketch_nov21a\sketch_nov21a.ino
    K:\工作类\badusb\arduino-1.8.10\arduino-builder -compile -logger=machine -hardware K:\工作类\badusb\arduino-1.8.10\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools K:\工作类\badusb\arduino-1.8.10\tools-builder -tools K:\工作类\badusb\arduino-1.8.10\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries K:\工作类\badusb\arduino-1.8.10\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=digistump:avr:digispark-tiny -ide-version=10810 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_798989 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_930150 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.micronucleus.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -prefs=runtime.tools.micronucleus-2.0a4.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\tools\micronucleus\2.0a4 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -prefs=runtime.tools.avr-gcc-4.8.1-arduino5.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5 -verbose C:\Users\Administrator\Documents\Arduino\sketch_nov21a\sketch_nov21a.ino
    Using board 'digispark-tiny' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7
    Using core 'tiny' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7
    Detecting libraries used...
    "C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16500000L -DARDUINO=10810 -DARDUINO_AVR_DIGISPARK -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\tiny" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\digispark" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_798989\\sketch\\sketch_nov21a.ino.cpp" -o nul
    Alternatives for Keyboard.h: [Keyboard@1.0.2]
    ResolveLibrary(Keyboard.h)
      -> candidates: [Keyboard@1.0.2]
    "C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16500000L -DARDUINO=10810 -DARDUINO_AVR_DIGISPARK -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\cores\\tiny" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\variants\\digispark" "-IK:\\工作类\\badusb\\arduino-1.8.10\\libraries\\Keyboard\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_798989\\sketch\\sketch_nov21a.ino.cpp" -o nul
    Alternatives for HID.h: []
    ResolveLibrary(HID.h)
      -> candidates: []In file included from C:\Users\Administrator\Documents\Arduino\sketch_nov21a\sketch_nov21a.ino:1:0:
    "Keyboard.h" 对应多个库
    K:\������\badusb\arduino-1.8.10\libraries\Keyboard\src/Keyboard.h:25:17: fatal error: HID.h: No such file or directory
    已使用: K:\工作类\badusb\arduino-1.8.10\libraries\Keyboard
    #include "HID.h"
    compilation terminated.
    使用 1.0.2  版本的库 Keyboard 在文件夹: K:\工作类\badusb\arduino-1.8.10\libraries\Keyboard
    exit status 1
    为开发板 Digispark (Default - 16.5mhz) 编译时出错。
    这是怎么回事,怎么解决啊?拜托拜托
    基于机器视觉的智能分拣机械臂
    基于机器视觉的智能分拣机
    服务器平台又挂了么,显示服务器未响应了
    服务器平台又挂了么,显示
    数据读不回来了
    esp8266-AP-控制LED灯
    esp8266-AP-控制LED灯
    网上很少这个ap控制led的灯,求人还不如求自己,自己开搞 我用了esp8266-01s,只有一
