查看: 488|回复: 1
[求助] esp8266连接错误
    2019-9-5 16:28
    发表于 2019-12-2 11:30 | 显示全部楼层 |阅读模式
    Arduino:1.8.7 (Windows 10), 开发板:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (1M SPIFFS)"
    In file included from C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/BlinkerESPMQTT.h:10:0,
                     from C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker.h:36,
                     from C:\Users\85988\Desktop\arduino鏁欑▼\arduino绋嬪簭\WiFi鐏痋Hello_WiFi\Hello_WiFi.ino:3:
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:220:5: error: 'BearSSL' does not name a type
         BearSSL::WiFiClientSecure   client_mqtt;
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h: In member function 'virtual int BlinkerMQTT::connect()':
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:334:9: error: 'client_mqtt' was not declared in this scope
             client_mqtt.setInsecure();
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h: In member function 'int BlinkerMQTT::connectServer()':
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1623:5: error: 'client_mqtt' was not declared in this scope
         client_mqtt.stop();
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1625:21: error: 'BearSSL' was not declared in this scope
         std::unique_ptr<BearSSL::WiFiClientSecure>client_s(new BearSSL::WiFiClientSecure);
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1625:46: error: template argument 1 is invalid
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1625:46: error: template argument 2 is invalid
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1625:55: error: invalid type in declaration before '(' token
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1625:60: error: expected type-specifier before 'BearSSL'
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1628:13: error: base operand of '->' is not a pointer
         client_s->setInsecure();
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Adapters/BlinkerMQTT.h:1644:21: error: invalid type argument of unary '*' (have 'int')
         if (http.begin(*client_s, url_iot)) {  // HTTPS
    In file included from C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:45:0,
                     from C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/BlinkerESPMQTT.h:11,
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h: At global scope:
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h:13:12: error: 'BearSSL' does not name a type
         extern BearSSL::WiFiClientSecure client_mqtt;
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h: In member function 'bool BlinkerOTA::update()':
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h:122:5: error: 'BearSSL' has not been declared
         BearSSL::WiFiClientSecure client_s;
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h:122:31: error: expected ';' before 'client_s'
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h:126:5: error: 'client_mqtt' was not declared in this scope
         client_mqtt.stop();
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/../Functions/BlinkerOTA.h:129:17: error: 'client_s' was not declared in this scope
         bool mfln = client_s.probeMaxFragmentLength(ota_host, ota_port, 1024);
    In file included from C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/BlinkerESPMQTT.h:11:0,
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'String BlinkerApi::blinkerServer(uint8_t, const String&, bool)':
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10444:20: error: 'BearSSL' does not name a type
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10445:13: error: 'client_mqtt' was not declared in this scope
                 client_mqtt.stop();
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10447:29: error: 'BearSSL' was not declared in this scope
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10447:54: error: template argument 1 is invalid
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10447:54: error: template argument 2 is invalid
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10447:63: error: invalid type in declaration before '(' token
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10447:68: error: expected type-specifier before 'BearSSL'
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10450:21: error: base operand of '->' is not a pointer
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10474:37: error: invalid type argument of unary '*' (have 'int')
                             http.begin(*client_s, url_iot);
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10487:37: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10501:37: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10516:37: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10529:37: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10542:37: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10557:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10571:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10584:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10596:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10610:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10623:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10636:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10649:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10661:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10675:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10688:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10701:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10714:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10726:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10739:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10752:41: error: invalid type argument of unary '*' (have 'int')
    C:\Users\85988\AppData\Local\Arduino15\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:10766:41: error: invalid type argument of unary '*' (have 'int')
    exit status 1
    为开发板 NodeMCU 1.0 (ESP-12E Module) 编译时出错。
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    程序
    //13=D7 16=D0 15=D8 14=D5 12=D6 4=D2 3=D9 2=D4 1=D10 0-D3//
    #define BLINKER_WIFI
    char auth[] = "006bef2727ec";
    char ssid[] = "住进深海里";
    char pswd[] = "741852963";
    // 新建组件对象
    int counter = 0;
    // 按下按键即会执行该函数
        digitalWrite(13, !digitalRead(13));
    // 如果未绑定的组件被触发,则会执行其中内容
        counter++;
        Number1.print(counter);
        // 初始化串口
        BLINKER_DEBUG.stream(Serial);
        // 初始化有LED的IO
        pinMode(13, OUTPUT);
        digitalWrite(13, HIGH);
        // 初始化blinker
        Blinker.attachData(dataRead);
    发表于 2019-12-2 12:17 | 显示全部楼层
    更新package
    esp8266-01s改造空调开关
    esp8266-01s改造空调开关
    最近在学习esp8266开发,esp8266是一款带wifi功能的物联网MCU,可以低成本实现
    [Arduino物联网开发实战2]数据反馈
    [Arduino物联网开发实战2]
    这个拓展板上的LCD接口是什么类型的?怎么搜?
    这个拓展板上的LCD接口是
    如图。
