查看: 806|回复: 5
[已解决] WiFiduino 示例检验不通过 端口无显示
    2019-12-9 18:19
    发表于 2019-12-6 00:47 | 显示全部楼层 |阅读模式
    新购进WiFiduino
    按照说明 安装好esp8266扩展 选择了WIFIduino 主板
    连接无误,指示灯亮
    进行示例程序的加载时,一开始提示 “串口没有选择”,而且开发板端口是灰色,无法选择端口
    后尝试连接了 Arduino UNO 可以出现端口,可以选择COM3
    而后换为wifiduino,端口依然无法选择
    求各位帮忙解答,十分感谢
    以下附有错误信息
    Arduino:1.8.10 (Windows 10), 开发板:"WiFiduino, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from C:\Users\���\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:10:0,
                     from C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker.h:36,
                     from C:\Users\张旖\AppData\Local\Temp\arduino_modified_sketch_775379\Button_WiFi.ino:48:
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Adapters/BlinkerMQTT.h: In member function 'virtual char* BlinkerMQTT::lastRead()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Adapters/BlinkerMQTT.h:684:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
    In file included from C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:82:0,
                     from C:\Users\���\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:11,
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApiBase.h: In member function 'char* BlinkerBridge_key::getName()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApiBase.h:194:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     else return "false";
    In file included from C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:83:0,
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::deviceName()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h:97:86: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 char * deviceName() { if (isInit) return conn->deviceName(); else return ""; }
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::authKey()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h:98:83: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 char * authKey()    { if (isInit) return conn->authKey(); else return "";  }
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h: In member function 'char* BlinkerProtocol::dataParse()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerProtocol.h:228:86: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
             char* dataParse()       { if (canParse) return conn->lastRead(); else return ""; }
    In file included from C:\Users\���\Documents\Arduino\libraries\Blinker\src/BlinkerESPMQTT.h:11:0,
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: At global scope:
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:764:97: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
             BlinkerWidgets_string _BUILTIN_SWITCH = BlinkerWidgets_string(BLINKER_CMD_BUILTIN_SWITCH);
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::bridgeKey(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6328:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
             else return "";
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::bridgeName(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6335:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_str(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6960:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_rgb(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6974:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_int(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6980:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h: In member function 'char* BlinkerApi::widgetName_tab(uint8_t)':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src/Blinker/BlinkerApi.h:6986:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         else return "";
    C:\Users\张旖\AppData\Local\Temp\arduino_modified_sketch_775379\Button_WiFi.ino: At global scope:
    C:\Users\张旖\AppData\Local\Temp\arduino_modified_sketch_775379\Button_WiFi.ino:56:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    C:\Users\���\Documents\Arduino\libraries\Blinker\src\modules\WebSockets\WebSocketsClient.cpp: In member function 'void WebSocketsClient::connectedCb()':
    C:\Users\���\Documents\Arduino\libraries\Blinker\src\modules\WebSockets\WebSocketsClient.cpp:706:68: warning: 'bool BearSSL::WiFiClientSecure::verify(const char*, const char*)' is deprecated (declared at C:\Users\���\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:180): This is deprecated AxTLS API, check https://github.com/esp8266/Arduino/blob/master/libraries/ESP8266WiFi/src/WiFiClientSecure.h#L25-L99 [-Wdeprecated-declarations]
             if(!_client.ssl->verify(_fingerprint.c_str(), _host.c_str())) {
    项目使用了 542496 字节,占用了 (51%) 程序存储空间。最大为 1044464 字节。
    全局变量使用了37768字节,(46%)的动态内存,余留44152字节局部变量。最大为81920字节。
    Serial port not selected.
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    2019-7-12 18:42
    发表于 2019-12-6 14:05 | 显示全部楼层
    2019-12-9 18:19
     楼主| 发表于 2019-12-6 15:04 | 显示全部楼层
    coloz 发表于 2019-12-6 14:05
    没装驱动吧http://wch.cn/downloads/CH341SER_EXE.html
    谢谢您,驱动安装了,发现设备管理器 端口被隐藏了,这回找到了。
    目前情况可以正常上传示例程序,但是blink里始终是离线状态
    程序里面报错有
    打开串行端口COM4出错 (Port busy)
    Wrote 550448 bytes (385605 compressed) at 0x00000000 in 34.1 seconds (effective 129.2 kbit/s)...
    Hash of data verified.
    Leaving...
    Hard resetting via RTS pin...
    请问这如何解决?
    2019-12-9 18:19
     楼主| 发表于 2019-12-6 15:09 | 显示全部楼层
    目前情况可以正常上传示例程序,但是bl ...
    拔了再插了一遍,没有端口出错,但依旧blink里是离线状态
    2019-7-12 18:42
    发表于 2019-12-6 16:15 | 显示全部楼层
    先确定程序是否上传成功,如果上传成功,看串口调试信息。
    2019-12-9 18:19
     楼主| 发表于 2019-12-9 18:19 | 显示全部楼层
    程序上传成功,原先用手机开的热点,后来更换成了移动wifi,好用了。
    谢谢您(●'◡'●)
    读取传感器的16进制问题
    读取传感器的16进制问题
    这是我的代码,求助怎样写才能分别获得通道1、2的TDS值和温度值,求助!!! [mw_shl_
    RPG游戏 无人世界
    RPG游戏 无人世界
    操作:方向键移动,a键确认 b键打开符文菜单 游戏流程大约半小时 视频攻略:ht
    开贴讲讲NRF24L01P,让你
    一开始测试时手头上只有论坛给的一块mega以及自己的一块仿制UNO,结果是nRF24L无法
    【原创】 drawbot平面关节
