查看: 1177|回复: 2
[经验] STM32+ST7789+XPT2046测试程序
    2020-1-14 13:13
  • 签到天数: 4 天
    发表于 2020-1-13 00:36 | 显示全部楼层 |阅读模式
    这个是STM32+ST7789+XPT2046测试程序,可以随意画图形、写字等,点击Clear按钮就可以清除,用于测试用,这是在实例中修改一些代码。
    #include <Arduino.h>
    #include <SPI.h>
    #include <Adafruit_ST7789.h>
    #include <Adafruit_GFX.h>
    #include <XPT2046.h>
    // Modify the following two lines to match your hardware
    // Also, update calibration parameters below, as necessary
    // For the esp shield, these are the default.
      #define TFT_CS        PB11
      #define TFT_RST       -1 // Or set to -1 and connect to Arduino RESET pin
      #define TFT_DC        PB10
      #define TFT_MOSI PB0  // Data out
      #define TFT_SCLK PB1  // Clock
    Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
    XPT2046 touch(/*cs=*/ PA4, /*irq=*/ PA1);// MOSI=11, MISO=12, SCK=13
    Adafruit_GFX_Button button;
        tft.init(240,320);
      tft.setRotation(0);//旋转屏幕
      touch.ROT0;
      touch.begin(tft.width(), tft.height());  // Must be done before setting rotation
      Serial.print("tftx ="); Serial.print(tft.width()); Serial.print(" tfty ="); Serial.println(tft.height());
      tft.fillScreen(ST77XX_BLACK);
      // Replace these for your screen module
      touch.setCalibration(209, 1759, 1775, 273);
      button.initButton(&tft, 35, 300, 70, 40, ST77XX_GREEN, ST77XX_BLUE, ST77XX_YELLOW, "Clear", 2);
      button.drawButton();
    static uint16_t prev_x = 0xffff, prev_y = 0xffff;
        uint16_t x, y;
      if (touch.isTouching()) {
        touch.getPosition(x, y);
        if (prev_x == 0xffff) {
          tft.drawPixel(x,y,ST77XX_BLUE);
        } else {
          tft.drawLine(prev_x, prev_y, x, y,ST77XX_BLUE);
        prev_x = x;
        prev_y = y;
      } else {
        prev_x = prev_y = 0xffff;
      button.press(button.contains(x, y)); // tell the button it is pressed
    // now we can ask the buttons if their state has changed
        if (button.justReleased()) {
            button.drawButton(); // draw normal
        if (button.justPressed()) {
            button.drawButton(true); // draw invert!
      delay(20);
    发表于 2020-2-23 19:18 | 显示全部楼层
    谢谢你,真的很棒
    2020-7-28 23:19
    发表于 2020-7-28 00:24 | 显示全部楼层
    这什么代码,,混乱。。
    求一份 新版 nano V3.0 ATMEGA328P 改进版原理图
    求一份 新版 nano V3.0 AT
    如标题,求一份 新版 nano V3.0 ATMEGA328P 改进版的原理图。 串口方案为 CH340C。
    中国电子学会提供fritzing的免费版本
    中国电子学会提供fritzing
    看到网上经常有朋友说找不到fritzing的免费版本,这里推荐一个绝对安全的下载方式http
    更智能的电脑远程开关机-基于继电器
    更智能的电脑远程开关机-
