查看: 166|回复: 2
arduino NANO
发表于 2020-2-26 21:07 来自手机 | 显示全部楼层 |阅读模式
我是个萌新看到别人做的一款机械郁金香特别漂亮,现在卡在程序这里过不去我把原帖的程序复制过来编译错误由于我比较菜只能看懂初级的程序这个完全懵逼请大神知道不白嫖
以下是程序;
flower.inoArduino
Tulip source code
#include <Adafruit_TiCoServo.h>
#include "SoftPWM.h"
#define NEOPIXEL_PIN A0
#define TOUCH_SENSOR_PIN 2
#define SERVO_PIN 9
//#define SERVO_OPEN 1750
#define SERVO_OPEN 1650
#define SERVO_SAFE_MIDDLE 1000
#define SERVO_CLOSED 775
#define RED 0
#define GREEN 1
#define BLUE 2
float currentRGB[] = {0, 0, 0};
float changeRGB[] = {0, 0, 0};
byte newRGB[] = {0, 0, 0};
#define MODE_SLEEPING 0
#define MODE_BLOOM 3
#define MODE_BLOOMING 4
#define MODE_BLOOMED 5
#define MODE_FADE 6
#define MODE_FADING 7
#define MODE_FADED 8
#define MODE_FALLINGASLEEP 9
#define MODE_RAINBOW 90
byte mode = MODE_FADED;
byte petalPins[] = {3, 4, 5, 6, 10, 11};
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(7, NEOPIXEL_PIN, NEO_GRB + NEO_KHZ400);
Adafruit_TiCoServo servo;
int servoChange = 1; // open
int servoPosition = SERVO_SAFE_MIDDLE;
  pixels.begin();
  servo.attach(SERVO_PIN, SERVO_CLOSED, SERVO_OPEN);
  pinMode(TOUCH_SENSOR_PIN, INPUT);
  attachInterrupt(digitalPinToInterrupt(TOUCH_SENSOR_PIN), _touchISR, RISING);
  randomSeed(analogRead(A7));
  SoftPWMBegin();
  pixelsUnifiedColor(pixels.Color(0, 0, 0));
  //pixelsUnifiedColor(pixels.Color(255, 70, 0));
  prepareCrossFade(140, 70, 0, 140);
  servo.write(servoPosition);
int counter = 0;
byte speed = 15;
  boolean done = true;
  switch (mode) {
    case MODE_BLOOM:
      prepareCrossFadeBloom(500);
      changeMode(MODE_BLOOMING);
    case MODE_BLOOMING:
      done = crossFade() && done;
      done = openPetals() && done;
      done = petalsBloom(counter) && done;
      if (done) {
        changeMode(MODE_BLOOMED);
    case MODE_FADE:
      //prepareCrossFade(0, 0, 0, 800);
      changeMode(MODE_FADING);
    case MODE_FADING:
      done = closePetals() && done;
      done = petalsFade(counter) && done;
      if (done) {
        changeMode(MODE_FADED);
    case MODE_FADED:
      //prepareCrossFade(140, 70, 0, 140);
      changeMode(MODE_FALLINGASLEEP);
    case MODE_FALLINGASLEEP:
      if (done) {
        changeMode(MODE_SLEEPING);
    case MODE_RAINBOW:
      rainbow(counter);
  counter++;
  delay(speed);
void changeMode(byte newMode) {
  if (mode != newMode) {
    mode = newMode;
    counter = 0;
void _touchISR() {
  if (mode == MODE_SLEEPING) {
    changeMode(MODE_BLOOM);
  else if (mode == MODE_BLOOMED) {
    changeMode(MODE_FADE);
// petals animations
boolean petalsBloom(int j) {
  if (j < 250) {
    return false; // delay
  if (j > 750) {
    return true;
  int val = (j - 250) / 2;
  for (int i = 0; i < 6; i++) {
    SoftPWMSet(petalPins[i], val);
  return false;
boolean petalsFade(int j) {
  if (j > 510) {
    return true;
    SoftPWMSet(petalPins[i], (510 - j) / 2);
  return false;
// animations
void prepareCrossFadeBloom(unsigned int duration) {
  byte color = random(0, 5);
  switch (color) {
    case 0: // white
      prepareCrossFade(140, 140, 140, duration);
    case 1: // red
      prepareCrossFade(140, 5, 0, duration);
    case 2: // blue
      prepareCrossFade(30, 70, 170, duration);
    case 3: // pink
      prepareCrossFade(140, 0, 70, duration);
    case 4: // orange
      prepareCrossFade(255, 70, 0, duration);
void rainbow(int j) {
  uint16_t i;
  byte num = pixels.numPixels() - 1;
  pixels.setPixelColor(pixels.numPixels() - 1, 100, 100, 100);
  for (i = 0; i < num; i++) {
    pixels.setPixelColor(i, colorWheel(((i * 256 / num) + j) & 255));
  pixels.show();
// servo function
boolean openPetals() {
  if (servoPosition >= SERVO_OPEN) {
    return true;
  servoPosition ++;
  return false;
boolean closePetals() {
  if (servoPosition <= SERVO_CLOSED) {
    return true;
  servoPosition --;
  return false;
// utility function
void pixelsUnifiedColor(uint32_t color) {
  for (unsigned int i = 0; i < pixels.numPixels(); i++) {
    pixels.setPixelColor(i, color);
  pixels.show();
void prepareCrossFade(byte red, byte green, byte blue, unsigned int duration) {
  float rchange = red - currentRGB[RED];
  float gchange = green - currentRGB[GREEN];
  float bchange = blue - currentRGB[BLUE];
  changeRGB[RED] = rchange / (float) duration;
  changeRGB[GREEN] = gchange / (float) duration;
  changeRGB[BLUE] = bchange / (float) duration;
  newRGB[RED] = red;
  newRGB[GREEN] = green;
  newRGB[BLUE] = blue;
  Serial.print(newRGB[RED]);
  Serial.print(" ");
  Serial.print(newRGB[GREEN]);
  Serial.print(" ");
  Serial.print(newRGB[BLUE]);
  Serial.print(" (");
  Serial.print(changeRGB[RED]);
  Serial.print(" ");
  Serial.print(changeRGB[GREEN]);
  Serial.print(" ");
  Serial.print(changeRGB[BLUE]);
  Serial.println(")");
boolean crossFade() {
  if (currentRGB[RED] == newRGB[RED] && currentRGB[GREEN] == newRGB[GREEN] && currentRGB[BLUE] == newRGB[BLUE]) {
    return true;
  for (byte i = 0; i < 3; i++) {
    if (changeRGB[i] > 0 && currentRGB[i] < newRGB[i]) {
      currentRGB[i] = currentRGB[i] + changeRGB[i];
    else if (changeRGB[i] < 0 && currentRGB[i] > newRGB[i]) {
    else {
      currentRGB[i] = newRGB[i];
  pixelsUnifiedColor(pixels.Color(currentRGB[RED], currentRGB[GREEN], currentRGB[BLUE]));
    Serial.print(currentRGB[RED]);
    Serial.print(" ");
    Serial.print(currentRGB[GREEN]);
    Serial.print(" ");
    Serial.print(currentRGB[BLUE]);
    Serial.println();
  return false;
uint32_t colorWheel(byte wheelPos) {
  // Input a value 0 to 255 to get a color value.
  // The colours are a transition r - g - b - back to r.
  wheelPos = 255 - wheelPos;
  if (wheelPos < 85) {
    return pixels.Color(255 - wheelPos * 3, 0, wheelPos * 3);
  if (wheelPos < 170) {
    wheelPos -= 85;
    return pixels.Color(0, wheelPos * 3, 255 - wheelPos * 3);
  wheelPos -= 170;
  return pixels.Color(wheelPos * 3, 255 - wheelPos * 3, 0);
有大佬愿意帮我写个吗不白嫖
想看原帖的加我QQ我能翻译,原帖全是英文
3325162502
    2019-7-29 00:08
  • 签到天数: 47 天
    发表于 2020-2-26 22:08 | 显示全部楼层
    已在wx上加你了
     楼主| 发表于 2020-2-27 13:00 来自手机 | 显示全部楼层
    解决了(๑>؂<๑)
    《Color Unit免费申请试用》
    《Color Unit免费申请试用
    编译时空白行出现stray &#
    【原创】 drawbot平面关节
    siri+小爱+小度+天猫控制灯
    siri+小爱+小度+天猫控制
    siri控制8266
    siri控制8266
