查看: 296|回复: 22
[已解答] 爆改车间 开机升级版 代码一直报错 求指点!!
    2020-3-29 09:09
  • 签到天数: 4 天
    发表于 2020-3-26 18:29 | 显示全部楼层 |阅读模式
    第一次报错 这个单词 我改了 就好了 也不知道该不该改的
    Screenshot_2020-03-25-14-07-37-750_com.oray.sunlo.jpg 第二次报错 就是这个了
    C:\Users\Administrator\Desktop\diannao\blinker_kaiji_xiaoai13\blinker_kaiji_xiaoai13.ino: In function 'void miotPowerState(const String&)':
    blinker_kaiji_xiaoai13:35:9: error: 'BlinkerAliGenie' was not declared in this scope
    blinker_kaiji_xiaoai13:46:9: error: 'BlinkerAliGenie' was not declared in this scope
    C:\Users\Administrator\Desktop\diannao\blinker_kaiji_xiaoai13\blinker_kaiji_xiaoai13.ino: In function 'void miotQuery(int32_t)':
    blinker_kaiji_xiaoai13:59:13: error: 'BlinkerAliGenie' was not declared in this scope
    blinker_kaiji_xiaoai13:62:13: error: 'BlinkerAliGenie' was not declared in this scope
    blinker_kaiji_xiaoai13:65:13: error: 'BlinkerAliGenie' was not declared in this scope
                 BlinkerAliGenie.print();
    exit status 1
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 18:33 | 显示全部楼层
    Arduino:1.8.12 (Windows 7), 开发板:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    exit status 1
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 19:05 | 显示全部楼层
    #define BLINKER_PRINT Serial
    #define BLINKER_WIFI
    #define BLINKER_MIOT_OUTLET   //小爱同学
    char auth[] = "*********";
    char ssid[] = "*********";
    char pswd[] = "*********";
    BlinkerButton Button1("btn-abc");     //定义按钮数据键值
    BlinkerText Text1("TextKey");        //文件显示键值
    bool oState = false;
    bool power;
    bool lastpower;
    int counter = 0;
    String pState;  //存储检测到的电源状态
    #define PW D2    //继电器控制管脚
    #define PM D5    //电源检测管脚
            digitalWrite(PW, HIGH);
            delay(200);
            digitalWrite(PW, LOW);
            Serial.println("开了");
            oState = true;
            digitalWrite(PW,HIGH);
            delay(200);
            Serial.println("关了");
            oState = false;
                if(digitalRead(PM) == true){
              }else {
    void dataRead(const String & data)      // 如果未绑定的组件被触发,则会执行其中内容
        Blinker.vibrate();
        delay(200);
    void heartbeat(){
            pState="开机";
          }else {
            pState="关机";
         Text1.print(pState,"电源状态反馈");
         Serial.println("心跳反馈");
        pinMode(PM,INPUT);
        #if defined(BLINKER_PRINT)
        #endif
        pinMode(PW, OUTPUT);              //定义io口为输出
        digitalWrite(PW, LOW);           //定义io默认为高电平
        Blinker.attachData(dataRead);
        power = digitalRead(PM);
        if (power != lastpower){
                  pState="开机";
                }else {
                  pState="关机";
               Serial.println("反馈");
        lastpower = power;
    发表于 2020-3-26 19:12 | 显示全部楼层
    这个错误提示意思是:你程序中有非ASCII的字符。通常是你网页上复制粘贴造成的。
    解决办法:手动输入,或者使用专业的代码编辑器删除不可见的字符
    2019-12-25 10:13
  • 签到天数: 10 天
    发表于 2020-3-26 19:25 | 显示全部楼层
    分号用成中文符号了!!
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 19:33 | 显示全部楼层
    解决办法:手动输入,或者 ...
    这个是他 上传到网盘的 直接 就可以打开的 代码
    能帮忙 改下吗 ?
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 19:41 | 显示全部楼层
    jh800215 发表于 2020-3-26 19:25
    分号用成中文符号了!!
    不会弄啊  求指点
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 19:51 | 显示全部楼层
    解决办法:手动输入,或者 ...
    大哥 我是真不会弄啊 你把这个改成已解决 我也没解决啊    买的东西早就到了 就一直没法写进去啊! 之前他的教程 里代码 都可以的
    是:“已解答”,意思我是提供了最为准确的解答,我的同事看到这个帖子后,就不用解答了。 我的解答已经非常清楚了,原因和解决办法也都已经告诉你了。 不会使用代码编辑器的话,手动输入一次代码,就可以了。  详情 回复 发表于 2020-3-26 20:26
    发表于 2020-3-26 20:26 | 显示全部楼层
    no2yulu 发表于 2020-3-26 19:51
    大哥 我是真不会弄啊 你把这个改成已解决 我也没解决啊    买的东西早就到了 就一直没法写进去啊! 之前 ...
    2020-3-29 09:09
  • 签到天数: 4 天
     楼主| 发表于 2020-3-26 20:35 | 显示全部楼层
    我的解答已经 ...
    问题是 这个代码  是软件生成的一个文件 我是直接打开的 啊!所以就不是你说的 网页复制啊 !
    。。。请注意,我说的是:“通常” 原因是“你程序中有非ASCII的字符” 不想扯这种浪费时间的语文问题,你手动输入一次,就好了 至于'BlinkerAliGenie' was not declared in this scope 就是程序里没定义BlinkerAl  详情 回复 发表于 2020-3-26 20:49
    【Arduino】108种传感器模块系列实验(55)---DHT11温湿度传感器
    【Arduino】108种传感器模
    一个初级的hello world的问题
    一个初级的hello world的
    串口监视器不显示,第一个程序就这样,求大佬指点
    【Arduino】u8g2中文字库制作教程 小白请进
    【Arduino】u8g2中文字库
