查看: 294|回复: 5
[未解决] nRF24L01的库怎么弄
发表于 2020-3-30 23:56 | 显示全部楼层 |阅读模式
做毕设 求求大神帮帮解读
Arduino:1.8.9 (Windows 10), 开发板:"Arduino/Genuino Uno"
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'uint16_t RF24Network::read(RF24NetworkHeader&, void*, uint16_t)':
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:689:35: error: 'rf24_min' was not declared in this scope
   maxlen = rf24_min(maxlen,bufsize);
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write(RF24NetworkHeader&, const void*, uint16_t, uint16_t)':
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:789:79: error: 'rf24_min' was not declared in this scope
  uint16_t fragmentLen = rf24_min((uint16_t)(len-offset),max_frame_payload_size);
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:822:16: error: 'class RF24' has no member named 'txStandBy'
     ok = radio.txStandBy(txTimeout);
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write(uint16_t, uint8_t)':
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:969:11: error: 'class RF24' has no member named 'txStandBy'
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write_to_pipe(uint16_t, uint8_t, bool)':
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:1078:14: error: 'class RF24' has no member named 'writeFast'
   ok = radio.writeFast(frame_buffer, frame_size,0);
D:\zmx\Arduino\libraries\RF24Network\RF24Network.cpp:1081:16: error: 'class RF24' has no member named 'txStandBy'
exit status 1
 楼主| 发表于 2020-3-30 23:58 | 显示全部楼层
arduino uno开发板 R3 升级版本ATMEGA328P ch340 TTL芯片
    2019-7-29 00:08
  • 签到天数: 47 天
    发表于 2020-3-31 00:35 | 显示全部楼层
    直接选 UNO 就行了
    发表于 2020-3-31 08:06 | 显示全部楼层
    报错是你调用的库报错,和你用什么板子无关
     楼主| 发表于 2020-3-31 08:56 | 显示全部楼层
    那我要用nRF24L01  要用到什么库
     楼主| 发表于 2020-3-31 09:08 | 显示全部楼层
    我找的程序里面有
    #include <RF24Network.h>
    #include <RF24Network_config.h>
    #include <Sync.h>
    这几个
    求大神看看哪里有问题,设
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    Arduino 求助 串口接收数据不正确,数据丢失问题
    Arduino 求助 串口接收数
