查看: 811|回复: 15
[未解决] 求助帖,ESP01S介入WS2812B,无法让灯
    2020-4-3 13:47
    发表于 2020-4-2 12:57 | 显示全部楼层 |阅读模式
    看抖音暴改车间着迷,但是无法调试出氛围灯,新手,有没有大神帮忙解决一下,感谢
    上图是主任发的电路图
    下图是我在面包板上改的,请帮忙检查下是否对
    ESP01S烧录如下:
    #define BLINKER_WIFI/////////////////// wifi
    #define BLINKER_MIOT_LIGHT ////////////语音助手
    char auth[] = "ec6ff6328965";//////////手机下载 blinker app 安卓应用商店 苹果在https://www.diandeng.tech/home   app-右上角+ DIY设备:Arduino 添加后得到该授权码
    char ssid[] = "THINK-001";/////wifi ssid
    char pswd[] = "123456qwe";///wifi 密码
    int openState = 0; ///默认为单色模式
    // Download Adafruit_NeoPixel library here:
    // https://github.com/adafruit/Adafruit_NeoPixel
    #define PIN            0   ////开发板的引脚编号 接WS2812 data  VCC--VCC  GND-GND DATA/DI(DATA INPUT)--17 具体看产品说明
    #define NUMPIXELS      3  ////开发板灯灯珠数量 位
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
    #define BUTTON_1 "ButtonKey"   ///////////////【APP内用来控制呼吸灯开关】app中添加 开关按键 数据键名ButtonKey  一致即可 注意大小写
    #define RGB_1 "RGBKey"              ///////////////【APP内用来控制颜色及亮度】app中添加调色盘 数据键名RGBKey  一致即可
    BlinkerRGB WS2812(RGB_1);
    uint8_t colorR, colorG, colorB, colorW;
    bool wsState;
    uint8_t wsMode = BLINKER_CMD_MIOT_DAY;
    void pixelShow()
      pixels.setBrightness(colorW);
      for (int i = 0; i < NUMPIXELS; i++) {
        pixels.setPixelColor(i, colorR, colorG, colorB);
      pixels.show();
    void ws2812_callback(uint8_t r_value, uint8_t g_value, uint8_t b_value, uint8_t bright_value)
      openState = 0;
      Button1.print("off");
      BLINKER_LOG("R value: ", r_value);
      BLINKER_LOG("G value: ", g_value);
      BLINKER_LOG("B value: ", b_value);
      BLINKER_LOG("Rrightness value: ", bright_value);
      colorR = r_value;
      colorG = g_value;
      colorB = b_value;
      colorW = bright_value;
      pixelShow();
        BLINKER_LOG("Toggle on!");
        Button1.print("on");
        openState = 1;
        BLINKER_LOG("Toggle off!");
        openState = 0;
    uint32_t getColor()
      uint32_t color = colorR << 16 | colorG << 8 | colorB;
      return color;
        BlinkerMIOT.powerState("on");
        BlinkerMIOT.print();
        wsState =true;
        if (colorW==0) colorW =255;
        wsState = false;
        if (colorW >0) colorW = 0;
      pixelShow();
    ///////////////////////////////////////////////////////呼吸灯
    uint32_t Wheel(byte WheelPos) {
      WheelPos = 255 - WheelPos;
      if (WheelPos < 85) {
        return pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
      if (WheelPos < 170) {
        WheelPos -= 85;
        return pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
      WheelPos -= 170;
      return pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
    void rainbow(uint8_t wait) {
      uint16_t i, j;
      for (j = 0; j < 256; j++) {
        for (i = 0; i < pixels.numPixels(); i++) {
          //time_show();
          // dhtShow();
          pixels.setPixelColor(i, Wheel((i + j) & 255));
        pixels.show();
        delay(wait);
    void miotColor(int32_t color)
      BLINKER_LOG("need set color: ", color);
      colorR = color >> 16 & 0xFF;
      colorG = color >>  8 & 0xFF;
      colorB = color       & 0xFF;
      BLINKER_LOG("colorR: ", colorR, ", colorG: ", colorG, ", colorB: ", colorB);
      pixelShow();
      BlinkerMIOT.color(color);
    void miotMode(uint8_t mode)
      BLINKER_LOG("need set mode: ", mode);
      if (mode == BLINKER_CMD_MIOT_DAY) {
        //日光模式   小爱同学的语音命令 模式中文名称参考 https://www.diandeng.tech/doc/xiaoai
      else if (mode == BLINKER_CMD_MIOT_NIGHT) {
        // Your mode function
      else if (mode == BLINKER_CMD_MIOT_COLOR) {
        openState = 0;
      else if (mode == BLINKER_CMD_MIOT_WARMTH) {
      else if (mode == BLINKER_CMD_MIOT_TV) {
      else if (mode == BLINKER_CMD_MIOT_READING) {
      else if (mode == BLINKER_CMD_MIOT_COMPUTER) {
        // 电脑模式
        openState = 1;
      wsMode = mode;
      BlinkerMIOT.mode(mode);
    void miotBright(const String & bright)
      BLINKER_LOG("need set brightness: ", bright);
      colorW = bright.toInt();
      BLINKER_LOG("now set brightness: ", colorW);
      pixelShow();
      BlinkerMIOT.brightness(colorW);
    void miotColoTemp(int32_t colorTemp)
      BLINKER_LOG("need set colorTemperature: ", colorTemp);
      BlinkerMIOT.colorTemp(colorTemp);
      switch (queryCode)
          BlinkerMIOT.powerState(wsState ? "on" : "off");
          BlinkerMIOT.color(0);
          BlinkerMIOT.mode(0);
          BlinkerMIOT.colorTemp(1000);
          BlinkerMIOT.brightness(1);
        case BLINKER_CMD_QUERY_COLOR_NUMBER :
          BLINKER_LOG("MIOT Query Color");
        case BLINKER_CMD_QUERY_MODE_NUMBER :
          BLINKER_LOG("MIOT Query Mode");
        case BLINKER_CMD_QUERY_COLORTEMP_NUMBER :
          BLINKER_LOG("MIOT Query ColorTemperature");
        case BLINKER_CMD_QUERY_BRIGHTNESS_NUMBER :
          BLINKER_LOG("MIOT Query Brightness");
        default :
      Blinker.vibrate();
      BLINKER_DEBUG.stream(Serial);
      BLINKER_DEBUG.debugAll();
      pinMode(LED_BUILTIN, OUTPUT);
      Blinker.attachData(dataRead);
      BlinkerMIOT.attachColor(miotColor);
      BlinkerMIOT.attachMode(miotMode);
      BlinkerMIOT.attachBrightness(miotBright);
      BlinkerMIOT.attachColorTemperature(miotColoTemp);
      pinMode(14, OUTPUT);
      digitalWrite(14, HIGH);
      pinMode(15, OUTPUT);
      digitalWrite(15, HIGH);
      colorR = 255;
      colorG = 255;
      colorB = 255;
      colorW = 0;
      wsState = true;
      pixels.begin();
      WS2812.attach(ws2812_callback);
      pixelShow();
      if (openState == 0)
        pixelShow();
        //Button1.print("off");
      else if (openState == 1)
        rainbow(15);/////////15呼吸灯的频率
        //Button1.print("on");
    2020-4-3 13:47
     楼主| 发表于 2020-4-2 12:58 | 显示全部楼层
    刷完后,可连接上wifi热点,可在点灯科技操作,但就是灯不亮
    2020-4-3 13:47
     楼主| 发表于 2020-4-2 13:07 | 显示全部楼层
    上图是淘宝购买的24位灯
    上图为供电后8266指示灯亮起后
    上图为点灯在线界面,已连接手机热点
    2020-5-9 23:03
  • 签到天数: 201 天
    发表于 2020-4-2 13:32 | 显示全部楼层
    #define NUMPIXELS      24
    2020-4-3 13:47
     楼主| 发表于 2020-4-2 14:10 | 显示全部楼层
    我弄了三个灯做了实验,还没正式接24
    2020-5-31 07:40
  • 签到天数: 18 天
    发表于 2020-4-2 17:11 | 显示全部楼层
    搞笑的山贼 发表于 2020-4-2 13:07
    上图是淘宝购买的24位灯
    上图为供电后8266指示灯亮起后
    RGB组件的数据键名没对上
    2019-1-17 09:55
    发表于 2020-4-3 00:12 | 显示全部楼层
    代码没看,第一眼感觉电源功率不够或者电路提供的功率不够
    2020-4-3 02:08
    发表于 2020-4-3 00:56 | 显示全部楼层
    引脚2,接io2
    2020-4-3 13:47
     楼主| 发表于 2020-4-3 08:06 | 显示全部楼层
    电源5V,测过
    2019-1-17 09:55
    发表于 2020-4-3 12:45 | 显示全部楼层
    5V几安,1A吗?
    求大神看看哪里有问题,设
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    Arduino 求助 串口接收数据不正确,数据丢失问题
    Arduino 求助 串口接收数
