查看: 417|回复: 0
[分享] siri控制8266
    2020-4-28 19:15
  • 签到天数: 6 天
    发表于 2020-4-8 00:14 | 显示全部楼层 |阅读模式
    //本程序是操作8266的GPIO 0 口
    // 程序如下
    #include <ESP8266WiFi.h>
    const char* ssid = "TP-11222";               //路由器账号
    const char* password = "11000323";          //路由器密码
    WiFiServer server(80);  // 服务器端口号
      delay(10);
      pinMode(0, OUTPUT);                  //定义IO 0 输出
      digitalWrite(0, 0);                        //IO 0  上点低电频
      // Connect to WiFi network
      Serial.println();
      Serial.println();
      Serial.println(ssid);
      WiFi.begin(ssid, password);
        Serial.print(".");
      Serial.println("");
    cStart the server
      server.begin();
      Serial.println("Server started @ ");
      // Print the IP address & instructions
      //打印出IP地址,后期可以制作显示器来外部硬件显示ip
      Serial.println("To control GPIO, open your web browser.");
      Serial.println("To set GPIO 0 high, type:");
      Serial.print(WiFi.localIP());
      Serial.println("/gpio/1");
      Serial.println("To set GPIO 0 low, type:");
      Serial.println("/gpio/0");
      Serial.println("To toggle GPIO 0, type:");
      Serial.println("/gpio/4");
      // Check if a client has connected
      WiFiClient client = server.available();
      if (!client) {
        return;
      String req = client.readStringUntil('\r');
      Serial.println(req);
      client.flush();
      // Match the request
      int val;
      //      下面开始判断ip进行动作指令
      if (req.indexOf("/gpio/off") != -1)
        digitalWrite(0, 1);
      else if (req.indexOf("/gpio/on") != -1)
        digitalWrite(0, 0);
      else {
        Serial.println("invalid request");
        client.print("HTTP/1.1 404\r\n");
        client.stop();
        return;
      client.flush();
      // Prepare the response
      String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nWelcome wenzheng space! ";
      s += "</html>\n";
      // Send the response to the client
      client.print(s);
      delay(1);
      Serial.println("Client disonnected");
    程序下载好后
    打开串口监视器
    复位8266
    查看8622地址
    记住这个地址  192.168.1.112   我的是这个地址 ,每个人的都不一样,自己记住
    下面是ios捷径的配置(请用苹果内置浏览器打开):
    开灯
    https://www.icloud.com/shortcuts/738ab973d2024d6a97c2692638bbd809?from=singlemessage&isappinstalled=0
    关灯
    https://www.icloud.com/shortcuts/8e25019a47604bb794856e5317ca7a30?from=singlemessage&isappinstalled=0
    进入快捷指令编辑
    给这个地址改成自己的
    点右上角的完成就可以了
    体验siri控制灯吧
    唯一缺点内网控制  不能用外网
    求解用arduino 让WS2812全
    Arduino物联网开发实例教程
    Arduino物联网开发实例教
    萌新求助,小爱语音控制8266没有反应
    萌新求助,小爱语音控制82
    看了有大佬做的远程开机,就想自己试试,我用的是esp8266 nodemcu。程序烧进去以后,
