Arduino:1.8.12 (Windows 10), 开发板:"Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 499576 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28032 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1472 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 5468 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 30136 ) - zeroed variables (global, static) in RAM/HEAP
项目使用了 534548 字节,占用了 (55%) 程序存储空间。最大为 958448 字节。
全局变量使用了37076字节,(45%)的动态内存,余留44844字节局部变量。最大为81920字节。
esptool.py v2.8
Serial port COM3
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 98:f4:ab:f8:59:9f
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Compressed 538704 bytes to 383435...
Writing at 0x00000000... (4 %)
Writing at 0x00004000... (8 %)
Writing at 0x00008000... (12 %)
Writing at 0x0000c000... (16 %)
Writing at 0x00010000... (20 %)
Writing at 0x00014000... (25 %)
Writing at 0x00018000... (29 %)
Writing at 0x0001c000... (33 %)
Writing at 0x00020000... (37 %)
Writing at 0x00024000... (41 %)
Writing at 0x00028000... (45 %)
Writing at 0x0002c000... (50 %)
Writing at 0x00030000... (54 %)
Writing at 0x00034000... (58 %)
Writing at 0x00038000... (62 %)
Writing at 0x0003c000... (66 %)
Writing at 0x00040000... (70 %)
Writing at 0x00044000... (75 %)
Writing at 0x00048000... (79 %)
Writing at 0x0004c000... (83 %)
Writing at 0x00050000... (87 %)
Writing at 0x00054000... (91 %)
Writing at 0x00058000... (95 %)
Writing at 0x0005c000... (100 %)
Wrote 538704 bytes (383435 compressed) at 0x00000000 in 34.1 seconds (effective 126.4 kbit/s)...
File md5: 26a4c01b63943bdc54929bb806a2b98b
Flash md5: df01c0f259bbe9ec9cbfa48a5254e010
MD5 of 0xFF is 62d5ca7e4803409adadfeb17320ec64e
Traceback (most recent call last):
File "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/Administrator/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/tools/esptool\esptool.py", line 2938, in main
operation_func(esp, args)
File "C:/Users/Administrator/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/tools/esptool\esptool.py", line 2403, in write_flash
raise FatalError("MD5 of file does not match data in flash!")
esptool.FatalError: MD5 of file does not match data in flash!
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
大神怎么解决呀!
